芯片: NRF52832 QF AA
SDK: SDK15.2
Softdevice: s132_nrf52_6.1.1_softdevice
参考资料
1、https://blog.csdn.net/weixin_41572450/article/details/83870623
2、nRF5_SDK_15.2.0_9412b96\examples\peripheral\flash_fstorage\pca10040\s132\arm5_no_packs
3、nrf5/lib_fstorage.html
写在前面:
存放位置:根据官方文档得知FDS区域范围在appication之后。
程序思路:
1、使用官方fstorage 库
2、 开机判断是否存在蓝牙名称然后再判断使用哪个蓝牙名称
3、每次通过蓝牙写完芯片名称后重启芯片
操作步骤:
第一步:项目中添加
nrf_fstorage.c
nrf_fstorage_sd.c
第二步:添加include 路径
第三步:头文件里包含 #include "nrf_fstorage.h" #include "nrf_fstorage_sd.h"
第四步:添加代码
//定义操作范围
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
/* Set a handler for fstorage events. */
.evt_handler = fstorage_evt_handler,
/* These below are the boundaries of the flash space assigned to this instance of fstorage.
* You must set these manually, even at runtime, before nrf_fstorage_init() is called.
* The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
* last page of flash available to write data. */
.start_addr = youraddressstart,
.end_addr = 0x78000,
//定义回调函数
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
if (p_evt->result != NRF_SUCCESS)
NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
return;
switch (p_evt->id)
case NRF_FSTORAGE_EVT_WRITE_RESULT:
NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
p_evt->len, p_evt->addr);
} break;
case NRF_FSTORAGE_EVT_ERASE_RESULT:
NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
} break;
default:
//定义操作指针
nrf_fstorage_api_t * p_fs_api;
//等待操作完成,由于我在写内容的时候不需要调度其他功能所以直接dump
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
/* While fstorage is busy, sleep and wait for an event. */
while (nrf_fstorage_is_busy(p_fstorage))
uint32_t nameadderss=youraddress;
//flash写名字
void writename(char * data)
ret_code_t rc;
p_fs_api = &nrf_fstorage_sd;
rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
APP_ERROR_CHECK(rc);
// nameadderss = nrf5_flash_end_addr_get();
//长度必须是4的倍数
rc = nrf_fstorage_write(&fstorage, nameadderss,data, 12, NULL);
wait_for_flash_ready(&fstorage);
NRF_LOG_INFO("Done.");
//定义名字变量
char DEVICE_NAME[yournamelength] = {yourname};
//定义默认名称
char* name="yourname";
//此函数开机调用 用于判断flash里面是否有内容用于确定使用默认名称还是flash名称
void read_name(void)
ret_code_t rc;
rc = nrf_fstorage_read(&fstorage, nameadderss, DEVICE_NAME, yournamelength);
if (rc != NRF_SUCCESS)
return;
//判断名称是否合法
if(yourrule)
memcpy(DEVICE_NAME,name,yournamelength);
在main.c中找到static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)函数
并添加以下代码:
case BLE_GATTS_EVT_WRITE:
if(p_ble_evt->evt.gatts_evt.params.write.uuid.uuid == BLE_UUID_GAP_CHARACTERISTIC_DEVICE_NAME)
char tempname[yournamelength];
if((p_ble_evt->evt.gatts_evt.params.write.len ==yournamelength) )
memcpy(tempname, p_ble_evt->evt.gatts_evt.params.write.data, p_ble_evt->evt.gatts_evt.params.write.len);
if((yourrule))
//断开连接
err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
APP_ERROR_CHECK(err_code);
memcpy(DEVICE_NAME, tempname, yournamelength);
//写flash
writename(DEVICE_NAME);
//重启
NRF_LOG_WARNING("System reset");
NVIC_SystemReset();
注意:
开机在gap_params_init()初始化前调用void read_name(void)函数。
手机端操作:
写入蓝牙名称
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
