大学时,喜欢上课猫在后排看天涯煮酒版块连载的历史文章,那时还在用nokia的功能机,只能把天涯上一页一页地把作者发表内容抠下来,保存为txt,导到手机中在里面看。后来知道了天涯脱水版,就是免费提供“只看楼主”功能,抠起来就方便多了。两三年下来也看了几十篇。。。
前两天在b站看到python的爬虫教程,照着做了一个,缅怀当时那个上了大学不认真听课也没心思泡妞的少年
源码如下:用python3.7.3 导入了requests模块,如果没有需要安装一下:pip install requests
运行后输入天涯论坛主贴的网址,比如:http://bbs.tianya.cn/post-no05-471093-1.shtml,就会在当前文件夹下建立新的文件夹,然后把每一页的楼主回复保存下来。没回复就不保存。
# -*- coding: UTF-8 -*-
import requests
import re
import os
# http://bbs.tianya.cn/post-no05-471093-1.shtml
paper_url = str(input('请输入天涯社区主贴网址:'))
def get_page_count(paper_url): # 获取页面数量
response = requests.get(paper_url)
response.encoding = 'utf-8'
result = response.text
reg = r'pageCount : (.*?),'
page_count = re.findall(reg, result)
# print(page_count)
return int((page_count[0]))
def get_paper_name(paper_url): # 获取文章名称+版块名称,建立文件夹用
reg = r'<title>(.*?)_论坛_天涯社区</title>'
paper_name = re.findall(reg, result)[0]
paper_name = paper_name.replace(' ', '_') # 文件夹名有空格情况下mkdir会不正常,用下划线替代
# print(paper_name)
return paper_name
def get_author_id(paper_url): # 获取作者ID,提取作者回复的内容用
reg = r'authorId : (.*?),'
author_id = re.findall(reg, result)
return author_id[0]
def get_author_content(paper_url):
page_count = get_page_count(paper_url)
author_id = get_author_id(paper_url)
paper_name = get_paper_name(paper_url)
os.system(r'mkdir' + r' ' + paper_name)
page_url = paper_url[0:-7] # http://bbs.tianya.cn/post-no05-471093- 截到这里
for i in range(1, page_count + 1): # 遍历所有页面
page_num = str(i)
page_url_i = page_url + page_num + '.shtml' # 拼凑为第i个页面
response = requests.get(page_url_i)
reg = r'hostid=' + author_id + r'.*?<div class="bbs-conte.*?">(.*?)<div class="atl-reply"'
author_bbs_content = re.findall(reg, result, re.S)
if author_bbs_content != []: # 本页作者有回复则保存
print('正在保存第%s页数据' % page_num)
# 保存第i个页面为html
fn = open('%s\\%s.html' % (paper_name, page_num), 'w', encoding='utf-8')
for j in author_bbs_content:
fn.write(j)
fn.close
