入手一块EBAZ4205,今日测试,板子正常,芯片真烫!!
真希望获得一份源码好好研究研究!!!
原版打印消息。。。。。。。。。。。。。。。。。。。。。
1.0.0.46 (Nov 28 2017 - 20:56:04 +0800)
Model: Zynq Zed Development Board
DRAM: ECC disabled 256 MiB
NAND: 128 MiB
MMC: zynq_sdhci: 0
Invalid bus 0 (err=-1)
*** Warning - spi_flash_probe() failed, using default environment
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
Hit 'd' to stop autoboot(eric): 0
Copying Linux from NAND flash to RAM...
Device 0: nand0, sector size 128 KiB
Page size 2048 b
OOB size 64 b
Erase size 131072 b
subpagesize 512 b
options 0x 0
bbt options 0x 20000
NAND read: device 0 offset 0x2220000, size 0x300000
3145728 bytes read: OK
design filename = "top_ctrl;UserID=0XFFFFFFFF;Version=2016.4"
part number = "7z010clg400"
date = "2017/11/28"
time = "13:25:29"
bytes in bitstream = 2083740
zynq_align_dma_buffer: Align buffer at 100068 to 100000(swap 1)
NAND read: device 0 offset 0x300000, size 0x500000
5242880 bytes read: OK
NAND read: device 0 offset 0x800000, size 0x20000
131072 bytes read: OK
## Booting kernel from Legacy Image at 02080000 ...
Image Name: Linux-4.6.0-xilinx
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3820688 Bytes = 3.6 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Kernel Image ... OK
Loading Device Tree to 0f2fe000, end 0f303b90 ... OK
Starting kernel ... |
