发表于 2019-5-13 19:30:42
LZ我用了你的文件可以启动了,但是会卡在mount root filesystem这里
- [ 1.306723] evm: HMAC attrs: 0x1
- [ 1.310126] hctosys: unable to open rtc device (rtc0)
- [ 1.320580] md: Waiting for all devices to be available before autodetect
- [ 1.327349] md: If you don't use raid, use raid=noautodetect
- [ 1.334083] md: Autodetecting RAID arrays.
- [ 1.338117] md: Scanned 0 and added 0 devices.
- [ 1.342578] md: autorun ...
- [ 1.345313] md: ... autorun DONE.
- [ 1.348802] Waiting for root device /dev/mmcblk0p2...
- [ 1.360999] mmc0: new high speed SD card at address 0260
- [ 1.366865] mmcblk0: mmc0:0260 SD 1.86 GiB
- [ 1.372866] mmcblk0: p1 p2
- [ 1.474443] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode.
- Opts: (null)
- [ 1.482512] VFS: Mounted root (ext4 filesystem) on device 179:2.
- [ 1.490154] devtmpfs: error mounting -2
- [ 1.494264] Freeing unused kernel memory: 312K (c0830000 - c087e000)
- [ 1.500624] Kernel panic - not syncing: No working init found. Try passing
- init= option to kernel. See Linux Documentation/init.txt for guidance.
- [ 1.513671] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.30-xillinux-2.0 #
- 1
- [ 1.520695] Hardware name: Xilinx Zynq Platform
- [ 1.525249] [<c0017128>] (unwind_backtrace) from [<c00128e0>] (show_stack+0
- x10/0x14)
- [ 1.532948] [<c00128e0>] (show_stack) from [<c02d7804>] (dump_stack+0x7c/0x
- 9c)
- [ 1.540158] [<c02d7804>] (dump_stack) from [<c00b424c>] (panic+0x84/0x1fc)
- [ 1.547016] [<c00b424c>] (panic) from [<c05cb8e4>] (kernel_init+0xb8/0xe4)
- [ 1.553866] [<c05cb8e4>] (kernel_init) from [<c000f238>] (ret_from_fork+0x1
- 4/0x3c)
- [ 1.561410] CPU0: stopping
- [ 1.564101] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.30-xillinux-2.0 #
- 1
复制代码 我的SD卡创建了两个分区:一个fat32分区放你的启动文件,一个ext4分区是空的。能共享一下你的ext4文件系统?
或者如何改uEnv.txt用别的根文件系统?
