发表于 2019-3-15 16:06:58
Error: 0 [main] bash 6256 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
Error: the public mailing list cygwin@cygwin.com
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Reading System ID at address 0x10002010: verified
Info:
Info: : Checksumming existing contents
Info:
Info: 00000000 : Verifying existing contents
Info:
Info: 00010000 : Verifying existing contents
Info:
Info: 00020000 : Verifying existing contents
Info:
Info: 00030000 : Verifying existing contents
Info:
Info: 00040000 : Verifying existing contents
Info:
Info: 00050000 : Verifying existing contents
Info:
Info: 00060000 : Verifying existing contents
Info:
Info: 00000000 : Reading existing contents
Info:
Info: 00010000 : Reading existing contents
Info:
Info: 00020000 : Reading existing contents
Info:
Info: 00030000 : Reading existing contents
Info:
Info: 00040000 : Reading existing contents
Info:
Info: 00050000 : Reading existing contents
Info:
Info: 00060000 : Reading existing contents
Info:
Info: Checksummed/read 34kB in 1.5s
Info:
Info: 00000000 ( 0%): Erasing
Info:
Info: 00010000 (14%): Erasing
Info:
Info: 00020000 (28%): Erasing
Info:
Info: 00030000 (42%): Erasing
Info:
Info: Erase failed at offset 30000
Info: Leaving target processor paused
Error: 0 [main] bash 6832 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
Error: Error code: 255 for command: nios2-flash-programmer "C:/Users/winter/Desktop/CIS_Sensor/flash/CIS_Sensor_epcs_flash.flash" --base=0x10001000 --epcs --sidp=0x10002010 --id=0x0 --timestamp=1552628211 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program
烧写不成功提示 |
