从 https://github.com/OpenNuvoton/N32926_Linux_BSP 拉下来的最新代码。
使用的Nand型号为:MX30LF1G18AC
然后按照下面步骤编译下载到板子上:
1. tar zxvf rootfs-2.6.35.tar.gz
2. make w55fa92_defconfig
3. ./build nand
4. AutoWriter烧录到nand
重新断电启动后,打印如下:
- Initial RTC
- DRAM Init..2p
- SD Port 0 Booting Fail - No/Unknown Device
- NAND CS0 Booting 2K-Page(4) BCH T4 PPB 64
- Write - 0xB0000204 = 0xFFFFFFFF
- Write - 0xB0000208 = 0xFFFFFFFF
- Write - 0xB0003008 = 0x0000805A
- Write - 0xB0003028 = 0x2AFF3B4A
- Write - 0xB0003004 = 0x00000021
- Delay 256 us
- Write - 0xB0003004 = 0x00000023
- Write - 0xB0003004 = 0x00000027
- Delay 256 us
- Write - 0xB000301C = 0x00002402
- Delay 256 us
- Write - 0xB0003018 = 0x00000532
- Delay 256 us
- Delay 256 us
- Write - 0xB0003004 = 0x0000002B
- Delay 256 us
- Delay 256 us
- Write - 0xB0003018 = 0x00000432
- Delay 256 us
- Write - 0xB000301C = 0x00002782
- Delay 256 us
- Delay 256 us
- Write - 0xB0003004 = 0x00000020
- Delay 256 us
- Write - 0xB0003054 = 0x00000013
- Delay 4096 us
- Write - 0xB0003054 = 0x0000001E
- Delay 20480 us
- DRAM CMD0
- Delay 4096 us
- DRAM CMD2
- DRAM CMD2
- Write - 0xB0003054 = 0x0000001A
- Delay 8192 us
- Write - 0xB0000208 = 0x00008354
- Write - 0xB0000204 = 0x00E5011F
- Success
- Execute Address 0x00900000
- W55FA92 Nand Boot Loader entry (20181017).
- 0
- H
- 11111113.Ap3:
- System clock = 240,000,000Hz
- DRAM clock = 360,000,000Hz
- REG_SDTIME = 0x2ABF394A
- Enable RTC power off feature to 6 seconds.
- Get image information from block 0x0 ..
- Load file length 153,600, execute address 0x500000
- Load file length 4,348,128, execute address 0x0
- Nand Boot Loader exit. Jump to execute address 0x0 ...
- Linux version 2.6.35.4 (root@ubuntu) (gcc version 4.8.4 (GCC) ) #2 PREEMPT Mon Feb 25 09:41:45 CST 2019
- CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
- CPU: VIVT data cache, VIVT instruction cache
- Machine: W55FA92
- Memory policy: ECC disabled, Data cache writeback
- FB Buffer Size: 0x70800
- Decoder Instance-0, width = 1280, height = 720
- Decoder Instance-0, offset = 0x0, total buf size = 0x77b000
- Encoder Instance-0, width = 1280, height = 720
- Encoder Instance-0, offset = 0x0, total buf size = 0x42f000
- TOTAL_VDE_BUF_SIZE = 0xbaa000, dec_total=0x77b000, enc_total=0x42f000
- AVC Buffer Size: 0xbaa000
- VIN_DEV1 Buffer Size: 0x5bc800
- CPU type 0x00fad007 is W55FA92
- w55fa92_external_clock = 12.0 MHz
- w55fa92_apll_clock = 432000 KHz
- w55fa92_upll_clock = 240000 KHz
- w55fa92_mpll_clock = 360000 KHz
- w55fa92_system_clock = 240000 KHz
- w55fa92_cpu_clock = 240000 KHz
- w55fa92_ahb_clock = 120000 KHz
- w55fa92_apb_clock = 60000 KHz
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
- Kernel command line: root=/dev/ram0 console=ttyS1,115200n8 rdinit=/sbin/init mem=64M vt.global_cursor_default=0
- PID hash table entries: 256 (order: -2, 1024 bytes)
- Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
- Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
- Memory: 64MB = 64MB total
- Memory: 42304k/42304k available, 23232k reserved, 0K highmem
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- DMA : 0xff600000 - 0xffe00000 ( 8 MB)
- vmalloc : 0xc4800000 - 0xe0000000 ( 440 MB)
- lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
- modules : 0xbf000000 - 0xc0000000 ( 16 MB)
- .init : 0xc0008000 - 0xc00cf000 ( 796 kB)
- .text : 0xc00cf000 - 0xc0407000 (3296 kB)
- .data : 0xc0408000 - 0xc0425860 ( 119 kB)
- Hierarchical RCU implementation.
- RCU-based detection of stalled CPUs is disabled.
- Verbose stalled-CPUs detection is disabled.
- NR_IRQS:48
- Console: colour dummy device 80x30
- console [ttyS1] enabled
- w55fa92_avc_alloc_mem : Kernel allocate phy buf addr =0x4bb000, vir_addr = 0xc04bb000
- ENCODER_TOTAL_SIZE = 0x42f000, DECODER_TOTAL_SIZE = 0x77b000
- w55fa92_avc_alloc_mem,_ENCODER_BUF_START = 0x4bb000, _DECODER_BUF_START = 0x8ea000,
- Calibrating delay loop... 119.60 BogoMIPS (lpj=598016)
- pid_max: default: 32768 minimum: 301
- Mount-cache hash table entries: 512
- CPU: Testing write buffer coherency: ok
- devtmpfs: initialized
- NET: Registered protocol family 16
- bio: create slab <bio-0> at 0
- SCSI subsystem initialized
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- Advanced Linux Sound Architecture Driver Version 1.0.23.
- cfg80211: Calling CRDA to update world regulatory domain
- Switching to clocksource w55fa92-timer1
- NET: Registered protocol family 2
- IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
- TCP established hash table entries: 2048 (order: 2, 16384 bytes)
- TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
- TCP: Hash tables configured (established 2048 bind 2048)
- TCP reno registered
- UDP hash table entries: 256 (order: 0, 4096 bytes)
- UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- register clock device
- w55fa92_edma_init
- ROMFS MTD (C) 2007 Red Hat, Inc.
- msgmni has been set to 82
- io scheduler noop registered (default)
- ---w55fa92fb_init ----w55fa92 frame buffer init
- ###########w55fa92 frame buffer probe############
- 1*** fbi->fb->fix.smem_len = 0x70800
- check_var(var=c3c96020, info=c3c96000)
- w55fa92fb_set_par !!! =================
- var->width = 0x140 !!!
- var->bits_per_pixel = 0x10 !!!
- *** fbcon_prepare_logo: update_screen
- Console: switching to colour frame buffer device 40x30
- ### bind_con_driver: update_screen
- w55fa92 LCD driver has been installed successfully
- w55fa92 SysMgr driver has been initialized successfully!
- w55fa92 ROT driver has been initialized successfully! Phy addr = 0x3f00000
- fa92 vpe register char device Successful!
- w55fa92 VPE driver has been initialized successfully!
- W55FA92 uart driver has been initialized successfully!
- w55fa92-uart0: ttyS0 at MMIO 0xb8008000 (irq = 14) is a W55FA92
- w55fa92-uart1: ttyS1 at MMIO 0xb8008100 (irq = 30) is a W55FA92
- brd: module loaded
- loop: module loaded
- w55fa92_avc_init
- fa92 AVC Decoder Supported
- FAVC Decoder IRQ mode(33)v1.0
- fa92 AVC Encoder Supported
- FAVC Encoder IRQ mode(34)v1.0
- H264 Driver Version v1.0
- ### W55FA92 ether driver v2.1 has been initialized successfully!
- rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
- usbcore: registered new interface driver rtl8150
- ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- USBH2.0 Clock source is UPLL, divider is 5
- Over-current is Disabled - REG_OpModEn = 0x00000000
- w55fa92-ehci w55fa92-ehci: Nuvoton w55fa92 EHCI Host Controller
- w55fa92-ehci w55fa92-ehci: new USB bus registered, assigned bus number 1
- w55fa92-ehci w55fa92-ehci: irq 21, io mem 0xb100b000
- w55fa92-ehci w55fa92-ehci: USB 2.0 started, EHCI 0.95
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- USB device plug in
- ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- ohci_hcd_w55fa92_drv_probe
- usb_hcd_w55fa92_probe
- w55fa92-ohci w55fa92-ohci: Nuvoton W55FA92 OHCI Host Controller
- w55fa92-ohci w55fa92-ohci: new USB bus registered, assigned bus number 2
- w55fa92-ohci w55fa92-ohci: irq 22, io mem 0xb1005000
- ohci_w55fa92_start
- hub 2-0:1.0: USB hub found
- hub 2-0:1.0: 2 ports detected
- Initializing USB Mass Storage driver...
- usbcore: registered new interface driver usb-storage
- USB Mass Storage support registered.
- w55fa92_udc_probe 20180820
- <USBD - USBD plug>
- Register platform device for low battery detection
- input: W55FA92 TouchScreen as /class/input/input0
- ADC opening REG_TP_CTL1 = 0xc00
- ADC Close
- input: W55FA92 Keypad as /class/input/input1
- W55FA92 keypad driver has been initialized successfully!
- w55fa92-rtc w55fa92-rtc: rtc core: registered w55fa92-rtc as rtc0
- Check RTC Level Shift Status
- -> Level Shift is enabled!
- RTC Access Enable Check
- Not Change RTC H/W Power Off Function setting - 0x60005
- Init Nuvoton RTC!
- <RTC Clock Source is from External Crystal>
- i2c_adap_w55fa92_init
- w55fa92_i2c_probe()
- w55fa92-i2c w55fa92-i2c: bus frequency set to 100 KHz
- w55fa92-i2c w55fa92-i2c: Add W55FA92 I2C port adapter
- Linux video capture interface: v2.00
- Sensor power down
- Sensor power down
- Video capture device 1 initialize successful
- jpegcodec_init
- Last boot is caused by Power-On-Reset.
- W55FA92 MMC/SD driver (20161207) has been initialized successfully!
- SDHC card will run under 24MHz clock on SD port.
- W55FA92 MMC/SDIO driver (20161207) has been initialized successfully!
- SDHC card will run under 24MHz clock on SDIO port.
- After snd_soc_register_dai
- w55fa92-dac-i2c ret = 0x0
- ADC clock get OK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- w55fa92evb_asoc_dev = 0xc3eb6dc0 !!!
- asoc: W55FA92_DAC HiFi <-> w55fa92-spu mapping ok
- ret = 0x0 !!!, platform device added
- ******* global g_pw55fa92_adc_data address = 0xc3ebb4e0
- 0 = platform_driver_register
- asoc: w55fa92ADC HiFi <-> w55fa92adc_cpu_dai mapping ok
- ALSA device list:
- #0: W55FA92_SPU (W55FA92_DAC)
- #1: mach-w55fa92_ADC (W55FA92_ADC)
- TCP cubic registered
- NET: Registered protocol family 17
- w55fa92-rtc w55fa92-rtc: setting system clock to 2005-01-01 00:49:59 UTC (1104540599)
- Freeing init memory: 796K
- gnand: module license 'Proprietary' taints kernel.
- Disabling lock debugging due to kernel taint
- NAND: nand_init !!!!!
- W55FA92 NAND driver (20181029) has been initialized successfully!
- scsi0 : Nuvoton W55FA92 On Board NAND DRIVER!
- [GNAND] GNAND Library Version: V1.02.5
- NAND: Found SLC NAND, ID C2-F1-80-95, page size 2048, BCH T8
- NAND: fmiSMCheckBootHeader 1
- Nand0: uLibStartBlock=17
- SPU DAC ON !!!
- [GNAND] NAND flash chip detected, chip ID is 0xff-0xf1 !
- GNAND init failed !!!!!!!!
- scsi 0:0:1:0: Direct-Access NUVOTON GNAND DRIVER 2.00 PQ: 0 ANSI: 0
- sd 0:0:1:0: [sda] Unit Not Ready
- sd 0:0:1:0: [sda] Sense Key : 0x3 [current]
- sd 0:0:1:0: [sda] ASC=0x30 ASCQ=0x0
- sd 0:0:1:0: [sda] READ CAPACITY failed
- sd 0:0:1:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
- sd 0:0:1:0: [sda] Test WP failed, assume Write Enabled
- sd 0:0:1:0: [sda] Asking for cache data failed
- sd 0:0:1:0: [sda] Assuming drive cache: write through
- sd 0:0:1:0: [sda] Attached SCSI removable disk
到这里就卡住了,看串口打印信息提示:GNAND init failed !!!!!!!!
看了下 drivers/scsi/nuvoton_nand/w55fa92_NandDrv.c 应该已经对这个nand做过支持的,驱动里面有这个nand的ID
有遇到过类似问题的朋友吗?帮忙指点下。谢谢!~ |
