回复: 4
MCO from ST-LINK: MCO output of ST-LINK MCU is used as input clock.
发表于 2019-1-21 22:20:44 | 显示全部楼层 |阅读模式
• MCO from ST-LINK: MCO output of ST-LINK MCU is used as input clock. This
frequency cannot be changed, it is fixed at 8 MHz and connected to PF0/PD0/PH0-
OSC_IN of STM32 microcontroller.
我手頭有片Nucleo STM32F411RE BOARD,外部晶振8MZ,固定不能改,我在Keil C/C++ 頁面定義:USE_STDPERIPH_DRIVER,STM32F411xE,我移值标准固件库,
SYSTEM_STMF32F4XX.H,下列藍色字體判斷STM32F411xE關鍵字有效,就會執行這句 #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz
就跟原廠定義8MHZ不同,我需要調整為: 8MHZ,還是不用理它!!!!
#if defined(STM32F40_41xxx) || defined(STM32F427_437xx)  || defined(STM32F429_439xx) || defined(STM32F401xx)  || defined(STM32F411xE)
#if !defined  (HSE_VALUE)
#endif /* HSE_VALUE */
#elif defined(STM32F446xx)
  #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* STM32F40_41xxx || STM32F427_437xx || STM32F429_439xx || STM32F401xx || STM32F411xE */
出0入24汤圆
发表于 2019-1-21 22:32:21 | 显示全部楼层
改成8000000
 楼主| 发表于 2019-1-22 17:33:55 | 显示全部楼层
感謝回答,那PLL_M 的值不用在調整嗎
出0入24汤圆
发表于 2019-1-22 18:43:03 | 显示全部楼层
这个就需要你自己确认时钟配置代码了 ,另外你这种需要把时钟输入设置为旁路
编辑原因:补充内容
 楼主| 发表于 2019-1-24 18:27:04 | 显示全部楼层
感謝幫忙,需要修改stm32f4xx.h  file 內容
//  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz
#define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */ //SKY
GMT+8, 2024-7-29 11:30
