这是源程序当执行到PreApplicationMode(); 就会发生复位.查汇编代码也没有看到那里不正常.
备注:这个程序代码在IAR和Crossworks的MSP430编译运行正常。就是imagecraft icc430不正常。
下面是移植icc430的代码。
* main.c
* MSP-EXP430G2-LaunchPad User Experience Application
* Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* 1. Device starts up in LPM3 + blinking LED to indicate device is alive
* + Upon first button press, device transitions to application mode
* 2. Application Mode
* + Continuously sample ADC Temp Sensor channel, compare result against
* initial value
* + Set PWM based on measured ADC offset: Red LED for positive offset, Green
* LED for negative offset
* + Transmit temperature value via TimerA UART to PC
* + Button Press --> Calibrate using current temperature
* Send character '? via UART, notifying PC
* Changes:
* 1.2 + Updated register naming conventions to reflect latest standard by TI
* e.g.: CCR0 --> TACCR0, CCTL0 --> TACCTL0
* + Changed method to capture TAR value into TACCR0 by using capture a
* SW-triggered event. [Changing TACCR input from GND to VCC]
* 1.1 + LED1 & LED2 labels changed so that Green LED(LED2) indicates sampled
* temperature colder than calibrated temperature and vice versa
* with Red LED (LED1).
* + Turn off peripheral function of TXD after transmitting byte to
* eliminate the extra glitch at the end of UART transmission
* 1.0 Initial Release Version
* Texas Instruments, Inc.
#include "msp430g2553.h"
#define LED1 BIT0
#define LED2 BIT6
#define LED_DIR P1DIR
#define LED_OUT P1OUT
#define BUTTON BIT3
#define BUTTON_OUT P1OUT
#define BUTTON_DIR P1DIR
#define BUTTON_IN P1IN
#define BUTTON_IE P1IE
#define BUTTON_IES P1IES
#define BUTTON_IFG P1IFG
#define BUTTON_REN P1REN
#define TXD BIT1 // TXD on P1.1
#define RXD BIT2 // RXD on P1.2
#define APP_STANDBY_MODE 0
#define APP_APPLICATION_MODE 1
#define TIMER_PWM_MODE 0
#define TIMER_UART_MODE 1
#define TIMER_PWM_PERIOD 2000
#define TIMER_PWM_OFFSET 20
#define TEMP_SAME 0
#define TEMP_HOT 1
#define TEMP_COLD 2
#define TEMP_THRESHOLD 5
// Conditions for 9600/4=2400 Baud SW UART, SMCLK = 1MHz
#define Bitime_5 0x05*4 // ~ 0.5 bit length + small adjustment
#define Bitime 13*4//0x0D
#define UART_UPDATE_INTERVAL 1000
unsigned char BitCnt;
unsigned char applicationMode = APP_STANDBY_MODE;
unsigned char timerMode = TIMER_PWM_MODE;
unsigned char tempMode;
unsigned char calibrateUpdate = 0;
unsigned char tempPolarity = TEMP_SAME;
unsigned int TXByte;
/* Using an 8-value moving average filter on sampled ADC values */
long tempMeasured[8];
unsigned char tempMeasuredPosition=0;
long tempAverage;
long tempCalibrated, tempDifference;
void InitializeLeds(void);
void InitializeButton(void);
void PreApplicationMode(void); // Blinks LED, waits for button press
void ConfigureAdcTempSensor(void);
void ConfigureTimerPwm(void);
void ConfigureTimerUart(void);
void Transmit(void);
void InitializeClocks(void);
#ifdef __IMAGECRAFT__
void __delay_cycles(unsigned int x)
while(x != 0) x--;
void _MSP430Setup(void) //low level function for power on setup
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
unsigned int uartUpdateTimer = UART_UPDATE_INTERVAL;
unsigned char i;
InitializeClocks();
InitializeButton();
InitializeLeds();
PreApplicationMode(); // Blinks LEDs, waits for button press
/* Application Mode begins */
applicationMode = APP_APPLICATION_MODE;
ConfigureAdcTempSensor();
ConfigureTimerPwm();
__enable_interrupt(); // Enable interrupts.
/* Main Application Loop */
ADC10CTL0 |= ENC + ADC10SC; // Sampling and conversion start
__bis_SR_register(CPUOFF + GIE); // LPM0 with interrupts enabled
/* Moving average filter out of 8 values to somewhat stabilize sampled ADC */
tempMeasured[tempMeasuredPosition++] = ADC10MEM;
if (tempMeasuredPosition == 8)
tempMeasuredPosition = 0;
tempAverage = 0;
for (i = 0; i < 8; i++)
tempAverage += tempMeasured;
tempAverage >>= 3; // Divide by 8 to get average
if ((--uartUpdateTimer == 0) || calibrateUpdate )
ConfigureTimerUart();
if (calibrateUpdate)
TXByte = 248; // A character with high value, outside of temp range
Transmit();
TXByte = (unsigned char)( ((tempAverage - 630) * 761) / 1024 );
Transmit();
tempDifference = tempAverage - tempCalibrated;
if (tempDifference < -TEMP_THRESHOLD)
tempDifference = -tempDifference;
tempPolarity = TEMP_COLD;
LED_OUT &= ~ LED1;
else if (tempDifference > TEMP_THRESHOLD)
tempPolarity = TEMP_HOT;
LED_OUT &= ~ LED2;
TACCTL0 &= ~CCIE;
TACCTL1 &= ~CCIE;
LED_OUT &= ~(LED1 + LED2);
if (tempPolarity != TEMP_SAME)
tempDifference <<= 3;
tempDifference += TIMER_PWM_OFFSET;
TACCR1 = ( (tempDifference) < (TIMER_PWM_PERIOD-1) ? (tempDifference) : (TIMER_PWM_PERIOD-1) );
TACCTL0 |= CCIE;
TACCTL1 |= CCIE;
LED_DIR |= LED1 + LED2;
LED_OUT |= LED1; // To enable the LED toggling effect
LED_OUT &= ~LED2;
BCSCTL1 |= DIVA_1; // ACLK/2
BCSCTL3 |= LFXT1S_2; // ACLK = VLO
TACCR0 = 1200; //
TACTL = TASSEL_1 | MC_1; // TACLK = SMCLK, Up mode.
TACCTL1 = CCIE + OUTMOD_3; // TACCTL1 Capture Compare
TACCR1 = 600;
__bis_SR_register(LPM3_bits + GIE); // LPM0 with interrupts enabled
unsigned char i;
/* Configure ADC Temp Sensor Channel */
ADC10CTL1 = INCH_10 + ADC10DIV_3; // Temp Sensor ADC10CLK/4
ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;
__delay_cycles(1000/3-3); // Wait for ADC Ref to settle
#else
__delay_cycles(1000); // Wait for ADC Ref to settle
tempCalibrated = ADC10MEM;
for (i=0; i < 8; i++)
tempMeasured = tempCalibrated;
tempAverage = tempCalibrated;
TACCR0 = TIMER_PWM_PERIOD; //
TACTL = TASSEL_2 | MC_1; // TACLK = SMCLK, Up mode.
TACCTL0 = CCIE;
TACCR1 = 1;
timerMode = TIMER_UART_MODE; // Configure TimerA0 UART TX
TACCTL0 = OUT; // TXD Idle as Mark
TACTL = TASSEL_2 + MC_2 + ID_3; // SMCLK/8, continuous mode
P1SEL |= TXD + RXD; //
P1DIR |= TXD; //
// Function Transmits Character from TXByte
void Transmit(void)
BitCnt = 0xA; // Load Bit counter, 8data + ST/SP
/* Simulate a timer capture event to obtain the value of TAR into the TACCR0 register */
TACCTL0 = CM_1 + CCIS_2 + SCS + CAP + OUTMOD0; //capture on rising edge, initially set to GND as input // clear CCIFG flag
TACCTL0 |= CCIS_3; //change input to Vcc, effectively rising the edge, triggering the capture action
while (!(TACCTL0 & CCIFG)); //allowing for the capturing//updating TACCR0.
TACCR0 += Bitime ; // Some time till first bit
TXByte |= 0x100; // Add mark stop bit to TXByte
TXByte = TXByte << 1; // Add space start bit
TACCTL0 = CCIS0 + OUTMOD0 + CCIE; // TXD = mark = idle
while ( TACCTL0 & CCIE ); // Wait for TX completion
// Timer A0 interrupt service routine
#pragma interrupt_handler Timer_A:TIMER1_A0_VECTOR
void Timer_A (void)
#else
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A (void)
if (timerMode == TIMER_UART_MODE)
TACCR0 += Bitime; // Add Offset to TACCR0
if (TACCTL0 & CCIS0) // TX on CCI0B?
if ( BitCnt == 0)
P1SEL &= ~(TXD+RXD);
TACCTL0 &= ~ CCIE ; // All bits TXed, disable interrupt
TACCTL0 |= OUTMOD2; // TX Space
if (TXByte & 0x01)
TACCTL0 &= ~ OUTMOD2; // TX Mark
TXByte = TXByte >> 1;
BitCnt --;
if (tempPolarity == TEMP_HOT)
LED_OUT |= LED1;
if (tempPolarity == TEMP_COLD)
LED_OUT |= LED2;
TACCTL0 &= ~CCIFG;
#pragma interrupt_handler ta1_isr:TIMER1_A1_VECTOR
void ta1_isr(void)
#else
#pragma vector=TIMER0_A1_VECTOR
__interrupt void ta1_isr(void)
TACCTL1 &= ~CCIFG;
if (applicationMode == APP_APPLICATION_MODE)
LED_OUT ^= (LED1 + LED2);
BCSCTL1 = CALBC1_1MHZ; // Set range
DCOCTL = CALDCO_1MHZ;
BCSCTL2 &= ~(DIVS_3); // SMCLK = DCO = 1MHz
void InitializeButton(void) // Configure Push Button
BUTTON_DIR &= ~BUTTON;
BUTTON_OUT |= BUTTON;
BUTTON_REN |= BUTTON;
BUTTON_IES |= BUTTON;
BUTTON_IFG &= ~BUTTON;
BUTTON_IE |= BUTTON;
* Port Interrupt for Button Press
* 1. During standby mode: to exit and enter application mode
* 2. During application mode: to recalibrate temp sensor
#pragma interrupt_handler PORT1_ISR:PORT1_VECTOR
void PORT1_ISR(void)
#else
#pragma vector=PORT1_VECTOR
__interrupt void PORT1_ISR(void)
BUTTON_IFG = 0;
BUTTON_IE &= ~BUTTON; /* Debounce */
WDTCTL = WDT_ADLY_250;
IFG1 &= ~WDTIFG; /* clear interrupt flag */
IE1 |= WDTIE;
tempCalibrated = tempAverage;
calibrateUpdate = 1;
applicationMode = APP_APPLICATION_MODE; // Switch from STANDBY to APPLICATION MODE
__bic_SR_register_on_exit(LPM3_bits);
// WDT Interrupt Service Routine used to de-bounce button press
#pragma interrupt_handler WDT_ISR:WDT_VECTOR
void WDT_ISR(void)
#else
#pragma vector=WDT_VECTOR
__interrupt void WDT_ISR(void)
IE1 &= ~WDTIE; /* disable interrupt */
WDTCTL = WDTPW + WDTHOLD; /* put WDT back in hold state */
BUTTON_IE |= BUTTON; /* Debouncing complete */
// ADC10 interrupt service routine
#pragma interrupt_handler ADC10_ISR:ADC10_VECTOR
void ADC10_ISR (void)
#else
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR (void)
__bic_SR_register_on_exit(CPUOFF); // Return to active mode
