前段时间ST推出了Value Line的STM32F750和H750两个系列,看了一下选型表,F750有LQFP144封装,正好适合我的STM32 linux板子。
于是,双十一买了几片。同时,我对我的linux板做了小幅改版:将SPI Flash容量扩大到32MB并连接到F750的QSPI BANK1,添加了CAN收发器和接口,增加了两个I2C外设(温湿度传感器和气压传感器)。板子做回来后先焊了一片,调试过程还算比较顺利,现在u-boot和Linux都工作起来了,下面是系统启动log,F750速度还是相当快的(427.62 BogoMIPS,F429跑Linux只有35.84 BogoMIPS),QSPI的加载速度也很给力。下一步我准备多测试几种STM32外设的Linux driver,emcraft现在的SDK比两三年前多了不少外设驱动,可以都试试看。
- U-Boot 2010.03 (Nov 26 2018 - 21:30:21)
- CPU : STM32F7 (Cortex-M7)
- Freqs: SYSCLK=216MHz,HCLK=216MHz,PCLK1=54MHz,PCLK2=108MHz
- Board: STM32F750 Rev 1.0, www.emcraft.com
- DRAM: 64 MB
- In: serial
- Out: serial
- Err: serial
- QSPI: 32 MB mapped at 0x90000000
- Net: miiphy_register done.
- eth hw init done.
- STM32_MAC
- Hit any key to stop autoboot: 0
- Booting from QSPI
- ## Booting kernel from Legacy Image at c0007fc0 ...
- Image Name: Linux-4.2.0
- Image Type: ARM Linux Multi-File Image (uncompressed)
- Data Size: 7496295 Bytes = 7.1 MB
- Load Address: c0008000
- Entry Point: c0008001
- Contents:
- Image 0: 7471388 Bytes = 7.1 MB
- Image 1: 24895 Bytes = 24.3 kB
- Verifying Checksum ... OK
- ## Flattened Device Tree from multi component Image at C0007FC0
- Booting using the fdt at 0xc0728128
- Loading Multi-File Image ... OK
- OK
- WARNING: legacy format multi component image overwritten
- Loading Device Tree to c3ff6000, end c3fff13e ... OK
- Starting kernel ...
- Booting Linux on physical CPU 0x0
- Linux version 4.2.0 (hw@localhost.localdomain) (gcc version 4.4.1 (Sourcery G++ Lite 2010
- q1-189) ) #90 Tue Dec 4 03:32:33 EST 2018
- CPU: ARMv7-M [410fc271] revision 1 (ARMv7M), cr=00000000
- CPU: WBA data cache, WBA instruction cache
- Machine model: EmCraft Systems STM32F7-SOM board
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
- Kernel command line: stm32_platform=stm32f7-disco console=ttyS0,115200 panic=10 ip=169.25
- 4.1.10:169.254.1.2:::stm32f7-disco:eth0:off
- PID hash table entries: 256 (order: -2, 1024 bytes)
- Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
- Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
- Memory: 56432K/65536K available (2523K kernel code, 181K rwdata, 588K rodata, 4000K init,
- 111K bss, 9104K reserved, 0K cma-reserved)
- Virtual kernel memory layout:
- vector : 0x00000000 - 0x00001000 ( 4 kB)
- fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- vmalloc : 0x00000000 - 0xffffffff (4095 MB)
- lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
- .text : 0xc0008000 - 0xc0312000 (3112 kB)
- .init : 0xc0312000 - 0xc06fa000 (4000 kB)
- .data : 0xc06fa000 - 0xc07277c0 ( 182 kB)
- .bss : 0xc072811c - 0xc0743e84 ( 112 kB)
- NR_IRQS:16 nr_irqs:16 16
- /interrupt-controller@40013c00: 24 External IRQs detected
- clocksource: arm_system_timer: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 27651335
- 8 ns
- ARM System timer initialized as clocksource
- /soc/timer@40000000: STM32 clockevent driver initialized (32 bits)
- sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 21474836475000000ns
- Calibrating delay loop... 427.62 BogoMIPS (lpj=2138112)
- pid_max: default: 4096 minimum: 301
- Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
- Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
- devtmpfs: initialized
- clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275
- 0000 ns
- pinctrl core: initialized pinctrl subsystem
- NET: Registered protocol family 16
- stm32-pinctrl pin-controller: nbanks = 11
- stm32-pinctrl pin-controller: nfunctions = 20
- stm32-pinctrl pin-controller: ngroups = 23
- stm32-pinctrl pin-controller: GPIOA bank added.
- stm32-pinctrl pin-controller: GPIOB bank added.
- stm32-pinctrl pin-controller: GPIOC bank added.
- stm32-pinctrl pin-controller: GPIOD bank added.
- stm32-pinctrl pin-controller: GPIOE bank added.
- stm32-pinctrl pin-controller: GPIOF bank added.
- stm32-pinctrl pin-controller: GPIOG bank added.
- stm32-pinctrl pin-controller: GPIOH bank added.
- stm32-pinctrl pin-controller: GPIOI bank added.
- stm32-pinctrl pin-controller: GPIOJ bank added.
- stm32-pinctrl pin-controller: GPIOK bank added.
- stm32-pinctrl pin-controller: Function[0 name:i2c_1, groups:1]
- stm32-pinctrl pin-controller: Function[1 name:i2c_2, groups:1]
- stm32-pinctrl pin-controller: Function[2 name:i2c_3, groups:1]
- stm32-pinctrl pin-controller: Function[3 name:mac, groups:2]
- stm32-pinctrl pin-controller: Function[4 name:sdio, groups:1]
- stm32-pinctrl pin-controller: Function[5 name:spi_2, groups:1]
- stm32-pinctrl pin-controller: Function[6 name:spi_4, groups:1]
- stm32-pinctrl pin-controller: Function[7 name:spi_5, groups:1]
- stm32-pinctrl pin-controller: Function[8 name:usart1, groups:1]
- stm32-pinctrl pin-controller: Function[9 name:usart6, groups:1]
- stm32-pinctrl pin-controller: Function[10 name:usart7, groups:1]
- stm32-pinctrl pin-controller: Function[11 name:usb_fs, groups:1]
- stm32-pinctrl pin-controller: Function[12 name:usb_hs, groups:1]
- stm32-pinctrl pin-controller: Function[13 name:can_1, groups:1]
- stm32-pinctrl pin-controller: Function[14 name:adc1_in0_pin, groups:1]
- stm32-pinctrl pin-controller: Function[15 name:dac_out2_pin, groups:1]
- stm32-pinctrl pin-controller: Function[16 name:ltdc, groups:1]
- stm32-pinctrl pin-controller: Function[17 name:sai_2, groups:1]
- stm32-pinctrl pin-controller: Function[18 name:i2c_4, groups:1]
- stm32-pinctrl pin-controller: Function[19 name:gpio, groups:3]
- stm32-dma 40026000.dma: STM32 DMA driver registered
- stm32-dma 40026400.dma: STM32 DMA driver registered
- SCSI subsystem initialized
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- soc:phy_hs supply vcc not found, using dummy regulator
- soc:phy_fs supply vcc not found, using dummy regulator
- pps_core: LinuxPPS API ver. 1 registered
- pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
- PTP clock support registered
- Advanced Linux Sound Architecture Driver Initialized.
- Bluetooth: Core ver 2.20
- NET: Registered protocol family 31
- Bluetooth: HCI device and connection manager initialized
- Bluetooth: HCI socket layer initialized
- Bluetooth: L2CAP socket layer initialized
- Bluetooth: SCO socket layer initialized
- clocksource: Switched to clocksource arm_system_timer
- NET: Registered protocol family 2
- TCP established hash table entries: 1024 (order: 0, 4096 bytes)
- TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
- TCP: Hash tables configured (established 1024 bind 1024)
- UDP hash table entries: 256 (order: 0, 4096 bytes)
- UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- Power Management for STM32
- futex hash table entries: 16 (order: -5, 192 bytes)
- jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
- fuse init (API version 7.23)
- Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
- io scheduler noop registered
- io scheduler cfq registered (default)
- stm32-pinctrl pin-controller: maps: function gpio group pwms num 2
- stm32-pwm pwm0: basing on TIM3.1(x16)
- stm32-pinctrl pin-controller: maps: function ltdc group ltdc-0 num 29
- stm32_lcdfb 40016800.ltdc: fb0: fb device registered successfully
- STM32 USART driver initialized
- stm32-pinctrl pin-controller: maps: function usart1 group usart1-0 num 3
- 40011000.serial: ttyS0 at MMIO 0x40011000 (irq = 34, base_baud = 6750000) is a stm32-usar
- t
- console [ttyS0] enabled
- stm32-pinctrl pin-controller: maps: function usart6 group usart6-0 num 3
- 40011400.serial: ttyS5 at MMIO 0x40011400 (irq = 35, base_baud = 6750000) is a stm32-usar
- t
- nbd: registered device at major 43
- stm32-pinctrl pin-controller: maps: function dac_out2_pin group dac-0 num 2
- stm32_dac 40007400.dac: dac1: no timer assigned, DMA functionality is not available
- stm32_dac 40007400.dac: created 1 character devices with MAJOR 248
- 2 ofpart partitions found on MTD device physmap-stm-flash.0
- Creating 2 MTD partitions on "physmap-stm-flash.0":
- 0x000000000000-0x000000020000 : "stm_flash_uboot"
- 0x000000040000-0x000000100000 : "stm_flash_unused"
- stm32-pinctrl pin-controller: maps: function spi_5 group spi_5-0 num 4
- stm32-spi 40015000.spi: SPI Controller 4 at 40015000,irq=38,hz=108000000
- CAN device driver interface
- stm32-pinctrl pin-controller: maps: function can_1 group can_1-0 num 3
- stm32-can 40006400.can: device registered (reg=40006400, irq=31)
- stm32-pinctrl pin-controller: maps: function mac group mac_rmii num 10
- stmmac - user ID: 0x10, Synopsys ID: 0x35
- Ring mode enabled
- DMA HW capability register supported
- Enhanced/Alternate descriptors
- Enabled extended descriptors
- RX Checksum Offload Engine supported (type 2)
- TX Checksum insertion supported
- Wake-Up On Lan supported
- Enable RX Mitigation via HW Watchdog Timer
- stm32-dwmac 40028000.ethernet eth0: No MDIO subnode found
- libphy: stmmac: probed
- eth0: PHY ID 0007c0f1 at 0 IRQ POLL (stmmac-0:00) active
- PPP generic driver version 2.4.2
- PPP BSD Compression module registered
- PPP Deflate Compression module registered
- usbcore: registered new interface driver rt2800usb
- stm32-pinctrl pin-controller: maps: function usb_hs group usb_hs-0 num 3
- dwc2 40040000.usb: DWC OTG Controller
- dwc2 40040000.usb: new USB bus registered, assigned bus number 1
- dwc2 40040000.usb: irq 56, io mem 0x00000000
- usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
- usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- usb usb1: Product: DWC OTG Controller
- usb usb1: Manufacturer: Linux 4.2.0 dwc2_hsotg
- usb usb1: SerialNumber: 40040000.usb
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- stm32-pinctrl pin-controller: maps: function usb_fs group usb_fs-0 num 3
- 50000000.usb supply vusb_d not found, using dummy regulator
- 50000000.usb supply vusb_a not found, using dummy regulator
- dwc2 50000000.usb: EPs: 6, dedicated fifos, 512 entries in SPRAM
- dwc2 50000000.usb: DCFG=0x08200000, DCTL=0x00000002, DIEPMSK=0000000b
- dwc2 50000000.usb: GAHBCFG=0x00000000, GHWCFG1=0x00000000
- dwc2 50000000.usb: GRXFSIZ=0x000000a0, GNPTXFSIZ=0x004000a0
- dwc2 50000000.usb: DPTx[1] FSize=32, StAddr=0x000000e0
- dwc2 50000000.usb: DPTx[2] FSize=64, StAddr=0x00000100
- dwc2 50000000.usb: DPTx[3] FSize=512, StAddr=0x00000800
- dwc2 50000000.usb: DPTx[4] FSize=512, StAddr=0x00000a00
- dwc2 50000000.usb: DPTx[5] FSize=512, StAddr=0x00000c00
- dwc2 50000000.usb: ep0-in: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep0-out: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep1-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep1-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep2-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep2-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep3-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep3-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep4-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep4-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep5-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: ep5-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x5abee5fb
- dwc2 50000000.usb: DVBUSDIS=0x000017d7, DVBUSPULSE=000005b8
- usbcore: registered new interface driver cdc_acm
- cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
- usbcore: registered new interface driver uas
- usbcore: registered new interface driver usb-storage
- g_serial gadget: Gadget Serial v2.4
- g_serial gadget: g_serial ready
- dwc2 50000000.usb: bound driver g_serial
- i2c /dev entries driver
- stm32-pinctrl pin-controller: maps: function i2c_4 group i2c_4-0 num 3
- bmp085 3-0077: Successfully initialized bmp085!
- stm32f7-i2c 40006000.i2c: I2C Controller i2c-3 at 40006000,irq=58
- Driver for 1-wire Dallas network protocol.
- usbcore: registered new interface driver btusb
- stm32-pinctrl pin-controller: maps: function sdio group sdio-0 num 7
- mmci-pl18x 40012c00.sdi: Got CD GPIO
- mmci-pl18x 40012c00.sdi: mmc0: PL180 manf 80 rev4 at 0x40012c00 irq 37,0 (pio)
- stm32-dma 40026400.dma: stm32_dma_of_xlate: unable to get channel 3 - was already request
- ed
- mmci-pl18x 40012c00.sdi: DMA channels RX dma1chan3, TX dma1chan3
- stm32_gpio_to_irq: Event line 3 now points to fire interrupts from bank G
- stm32-pinctrl pin-controller: maps: function gpio group outs num 2
- hidraw: raw HID events driver (C) Jiri Kosina
- usbcore: registered new interface driver usbhid
- usbhid: USB HID core driver
- stm32-pinctrl pin-controller: maps: function adc1_in0_pin group adc1-0 num 2
- stm32f4-adc 40012000.adc: registered
- stm32-pinctrl pin-controller: maps: function sai_2 group sai_2-0 num 5
- stm32-dma 40026400.dma: stm32_dma_of_xlate: unable to get channel 4 - was already request
- ed
- stm32-asoc-card sound: failed to find codec platform device
- stm32-asoc-card: probe of sound failed with error -22
- NET: Registered protocol family 17
- can: controller area network core (rev 20120528 abi 9)
- NET: Registered protocol family 29
- can: raw protocol (rev 20120528)
- can: broadcast manager protocol (rev 20120528 t)
- can: netlink gateway (rev 20130117) max_hops=1
- Bluetooth: RFCOMM TTY layer initialized
- Bluetooth: RFCOMM socket layer initialized
- Bluetooth: RFCOMM ver 1.11
- hctosys: unable to open rtc device (rtc0)
- vmmc: disabling
- ALSA device list:
- No soundcards found.
- Freeing unused kernel memory: 4000K (c0312000 - c06fa000)
- init started: BusyBox v1.24.2 (2018-11-22 20:35:58 EST)
- / # amixer: Mixer attach default error: No such file or directory
- stm32-dwmac 40028000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
- / # free
- total used free shared buffers cached
- Mem: 60432 8140 52292 0 0 4792
- -/+ buffers/cache: 3348 57084
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
