3楼
发表于 2018-11-27 10:34:59
只看该作者
static void DoPrint( const char *fmt, va_list ap )
char ch;
char i;
long value;
bit fl_zero;
bit fl_num;
BYTE fl_len;
BYTE cnt;
DWORD mask=1;
char *ptr;
while(1) {
//----- Find Formatter % -----
switch( ch = *fmt++ ) {
case 0: return;
case '%': if( *fmt != '%' ) break;
fmt++;
default: _outchar( ch );
continue;
//----- Get Count -------------
fl_zero = 0;
fl_num = 0;
cnt = 0;
ch = *fmt++;
if( ch=='0' ) {
fl_zero = 1;
ch = *fmt++;
cnt = ch - '0';
ch = *fmt++;
else if( ch>='0' && ch<='9' ) {
cnt = ch - '0';
ch = *fmt++;
//----- Get char(B) / int / long(L) ----------------
fl_len = 2;
switch(ch) {
case 'l':
case 'L': ch = *fmt++; fl_len = 4; break;
case 'b':
case 'B': ch = *fmt++; fl_len = 1; break;
//----- Get Type Discriptor -----
switch( ch ) {
case 'd':
case 'u':
switch (fl_len) {
case 1:
if( ch=='d' ) value = (char)va_arg( ap, BYTE );
else value = (BYTE)va_arg( ap, BYTE );
case 2:
if( ch=='d' ) value = (int)va_arg( ap, WORD );
else value = (WORD)va_arg( ap, WORD );
case 4:
if( ch=='d' ) value = (long)va_arg( ap, DWORD );
else value = (DWORD)va_arg( ap, DWORD );
if( value<0 ) {
_outchar('-');
value = value*(-1);
if(cnt==0) {
if( value==0 ) { _outchar('0'); continue; }
for(cnt=0, mask=1; cnt<10; cnt++) {
if( (value/mask)==0 ) break;
mask = mask*10;
for(i=0, mask=1; i<cnt-1; i++) mask = mask*10;
while(1) {
ch = (value / mask) + '0';
if( ch=='0' && fl_zero==0 && mask!=1 ) ch=' ';
else fl_zero = 1;
_outchar(ch);
value = value % (mask);
mask = mask / 10;
if( mask==0 )
continue;
case 'x':
case 'X':
switch (fl_len) {
case 1: value = (BYTE)va_arg( ap, BYTE ); break;
case 2: value = (WORD)va_arg( ap, WORD ); break;
case 4: value = (DWORD)va_arg( ap, DWORD ); break;
if(cnt==0) cnt = fl_len*2;
for(i=0; i<cnt; i++) {
_outchar( Hex[(value >> (cnt-i-1)*4) & 0x000f] );
continue;
case 's':
ptr = (char *)va_arg( ap, BYTE* );
while(*ptr!='\0')
_outchar(*ptr++);
continue;
case 'c':
value = va_arg( ap, BYTE );
_outchar((BYTE)value);
continue;
default:
value = (WORD)va_arg( ap, int );
continue;
void Printf( const char *fmt, ... )
BYTE flg = 0;
va_list ap;
va_start(ap, fmt);
if(flg) DoPrint( fmt, ap );
va_end( ap );
!!!瑞萨给你发的种子?
你说的是这种实现方式吧?但是,我想了解Synergy平台怎样定义的,因为官方例程有用到printf,但是没有检测到哪个引脚有字符输出。 |
