看到到家最近为了花钱烦恼,特地搜集了些许pi的资料,大家比较一下,也欢迎更新
主要收集高性能的。 ,还有特别贵的,便宜的就不说了
N卡加的性能一般的AI卡,当然了,豪可以拿来当通用cpu用嘛
这玩意有PCB 基板,功能很强,说白了,土豪来买吧
Jetson TX2 Module
https://www.nvidia.com/en-us/aut ... s-dev-kits-modules/
●This AI supercomputer features NVIDIA Maxwell™ architecture,
●256 NVIDIA CUDA® cores, 64-bit CPUs, power-efficient design.
●CPU HMP Dual Denver 2/2 MB L2 + ///Quad ARM® A57/2 MB L2
●8 GB 128 bit LPDDR4 59.7 GB/s
●2x DSI, 2x DP 1.2 / HDMI 2.0 / eDP 1.4
●32 GB eMMC, SDIO, SATA
●CAN, UART, SPI, I2C, I2S, GPIOs
●1 Gigabit Ethernet, 802.11ac WLAN, Bluetooth
//intel核心,已经很强了
LattePanda Alpha
https://www.lattepanda.com/
●windows10
●Intel 7th Gen Core m3-7Y30 1.6~2.6GHZ
●Intel HD Gpu 615
●8G LPDDR3 1866MHZ
●64G EMMC
●SSD/mKEY/m.2/ssd/ USB3.0
●WIFI 802.11AC./2.4G&5G Dual Band Bluetooth 4.2
●Arduino Leonardo
●i2c,i2s,usb,rs232,uart,rtc,power management,
//大家都知道,胜在软件支持多,图像识别可以意思意思,另外beaglebone black 因为和这个差不多,但是性能弱一些,就不介绍了
raspberrypi
https://www.raspberrypi.org/
不多介绍了?
ODROID-C2
https://www.hardkernel.com/main/ ... _code=G145457216438
//华硕家的,可以随便看看
Tinker Board S
https://www.asus.com/au/Single-Board-Computer/Tinker-Board-S/
● CPU Rockchip Quad-Core RK3288 processor
● Memory 2GB Dual Channel DDR3
● Graphic Integrated Graphics Processor
● Storage 16GB eMMC Micro SD(TF) card slot
● LAN RTL GB LAN
● Wireless Data Network 802.11 b/g/n, Bluetooth V4.0 + EDR
● Audio RTL ALC4040 CODEC
● USB Ports 4 x USB 2.0
● Internal I/O Ports
● 1 x 40-pin header : GPIO pins SPI bus I2C bus UART PWM PCM/I2S 2 x 5V power pins
2 x 3.3V power pins 8 x ground pinsPWMS/PDIF MIPI DSI MIPI CSI
● 3.37 inch x 2.125 inch ( 8.55 cm x 5.4 cm )
● Weight 55g
OrangePi 里面太多,不知道写哪个好
http://www.orangepi.org/
大概这样
●CPUH3 Quad-core Cortex-A7 H.265/HEVC 4K
●GPU·Mali400MP2 GPU @600MHz·Supports OpenGL ES 2.0
●Memory (SDRAM)1GB DDR3 (shared with GPU)
●Onboard StorageTF card (Max. 32GB) / MMC card slot 8GB EMMC Flash
//这个貌似也很强
Hikey 970
http://www.lemaker.org/product-guitar-specification.html
● High performance single board computer with low cost
● Quad-core ARM® Cortex™-A9R4 CPU;
● System on module design;
● 1GB/2GB DDR3 SDRAM;
● On-board 8GB eMMC NAND flash storage;
● 204 pins standard DDR3 SODIMM for connecting LeMaker™ Guitar base board;
● Hardware ADFU button;
● Android 5.0 and Linux support.
