https://eagle-updates.circuits.io/downloads/latest.html
- Release notes for EAGLE 9.2.0
- * EXPORTSTEP Command:
- - This new command exports the board into a STEP model using the cloud service for FusionSync.
- * FANOUT Command:
- - The new FANOUT command performs fanout operations on selected devices (SMDs and BGAs) or
- signals, while providing control over the direction of the fanout and the via size. This
- command has an icon in the command toolbar and is also available from the command line.
- * NET Command:
- - Removed automatic label mode from NET command. Proper auto-label function comes with the
- NAME command for nets.
- * PINARRY, PADARRAY, SMDARRAY Commands:
- - New PINARRAY, PADARRAY, and SMDARRAY commands, available via CLI (command line) and from the PIN
- and PAD/SMD parameter toolbars, allow creation of an array of PINS, PADS, or SMDS in a regular pattern.
- These commands offer configurable naming options, and automatic NAME and VALUE text object
- and outline placement.
- * PAINTROLLER Command:
- - Transfers selected properties of a selected object to other similar objects.
- * PATTERN Command:
- - The PATTERN command creates multiple copies of an object and arranges them in a linear or circular pattern.
- * SMASH Command / Reposition Attributes:
- - The Smashed property has been removed from devices and elements, so instead all placed devices or
- elements are automatically smashed. Loading legacy designs will automatically smash any unsmashed
- devices or elements.
- * SPICE Simulation:
- - New digital and mixed-mode simulation feature.
- * Digital models enabled for simulation.
- * New library ngspice-digital contains simulation-ready digital parts and parts for use in
- mixed-mode simulations.
- * New examples provided using the new parts under /examples/ngspice/.
- * Re-organized examples into Analog, Digital, and MixedMode folders.
- * Check added to make sure analog and digital parts are not mixed on the same net.
- * Added new digital plotting mode for use with digital simulations.
- * Changed previously named SOURCESETUP command to have a description of "Analog Source Setup",
- and added new command DSOURCESETUP with description "Digital Source Setup". This command has a
- UI that allows the user to specify digital data for multiple source pins, either manually by
- entering in a table, or by importing a properly formatted csv file.
- - Measurement functionality added to plotter: click once at two locations and a table will popup
- to show the difference in x and y axis values for all plotted signals.
- - Added check for frequency of 0 when DEC type AC simulation is run.
- - Fixed bug to make sure simulation configurations parameters are saved for all fields, not
- only those corresponding to the chosen simulation type.
- * Library Editor:
- - When a new 3D package is copied into a library, it is now added to any device variants that reference
- the 3D package's footprint (if the device has no 3D package and no other 3D package in the library
- references the footprint).
- * CAM Processor:
- - Improvements and issues resolved when using the CAM Processor within EAGLE:
- * The CAM Processor dialog can now be resized.
- * A CAM Job File that specifies an output file containing a non-existent directory prefix now successfully
- creates the directory path.
- * The default Gerber format for Template CAM Job Files and newly created CAM Job File Gerber Items is RS274-X.
- * Seeed Studio CAM Job Files have been added to the CAM Processor Third Party category.
- * Beta Layout CAM Job Files have been added to the CAM Processor Third Party category.
- * The Negative Polarity checkbox has been added to CAM Processor's Gerber Item page. It affects the
- Preview display and Gerber output.
- * Some file function settings (e.g. Solder Mask) produce negative image polarity by default.
- * Display of Legacy Gerber CAM Item layers in CAM Processor has been improved, especially when operating
- from EAGLE Control Panel with no active PCB design.
- * Drill, Gerber, and Drawing Output Sections all have output file prefixes, with corresponding
- symbols for use in their Output Item's file name.
- * Size capacity of Output Section prefix fields and Output Item file name fields have been increased.
- - Several issues have been resolved when executing EAGLE CAM Processor from a command window:
- * The -dCAMJOB option to completely process a JSON CAM Job File is now fully documented in the user manual.
- * The -N option now completely suppresses all output messages.
- * DXF output generation using -dCAMJOB no longer produces an "unexpected condition" failure.
- * Design Rule Check:
- - Updated DRC engine, so that it does not flag wire stubs, if they are absorbed by copper pours (polygons).
- - Improved user interface for DRC > Layers tab.
- * Miscellaneous:
- - Added missing semicolon to eagle.dtd.
- - Added CUT command on keyboard shortcut Ctrl/Cmd+X. This operation copies the selected objects to the
- clipboard, and deletes them from the design.
- - Improved connectivity of wire segments in the schematic after some MOVE operations.
- - Improvement to coupling of buses and nets - changes in one will be reflected in other, where applicable.
- - Updated help for POLYGONIZE and MOVE updates.
- - Pins with Direction NC (Not Connected) are now marked with a distinct cross symbol.
- - Added support for XREF labels with PINBREAKOUT and NETBREAKOUT commands.
- - Placing a part with two unconnected pins on an existing net in the schematic will split the net in two
- parts instead of shorting it.
- - The wire bend icons and via shape icons have been consolidated into drop-down list boxes in the parameters
- toolbar to save space so that on smaller displays the parameter toolbar would fit within the window.
- - Stopped bundling 84 obsolete libraries with EAGLE. They are still available for download using the
- Library Manager. See the ChangeLog in the cache/lbr folder for a list of the libraries.
- * Bugfixes:
- - Fixed a bug that caused the REPLACE command to fail to update the library reference when replacing the
- second and subsequent parts/elements in a design with a device variant in a device of the same name and
- a library of the same name, but different URN (or a URN instead of no URN, or vice-versa).
- - Fixed a crash issue when opening a new simulation-ready design file after simulating another.
- - Fixed issues when BUS is started with a selection of nets made beforehand:
- * do not start from selection, if Group Default is not on,
- * do not start from selection of nets, if first click is on an existing bus,
- * should not have to click twice when drawing bus from selection of nets.
- - A number of issues related to the MOVE command have been solved:
- * Fixed issue where traces get removed unintentionally during GROUP MOVE.
- * Fixed crash that occurs sometimes when moving a via.
- * Fixed issue where moving a component using the DISCONNECT mode leaves the reference designator
- (>NAME text object) behind.
- * Fixed Ctrl+MOVE for rectangle and circle (adjust size) and Shift+MOVE for polygon (move entire polygon).
- - Fixed issue where live DRC does not update when global attributes are changed.
- - Fixed issue where DRC reports an error on placeholder instead of attribute value.
- - Fixed crash when opening board.
- - Fixed issue where polygon did not get reverted to outline when moving.
- - Fixed issue where moving a polygon edge could corrupt the polygon resulting in incorrect pour.
- - Fixed the OPTIMIZE function to work properly during LINE related command placement and during
- MOVE operations.
- - The import-gerber.ulp utility has been improved to operate correctly when the ULP's path contains spaces,
- and to update its dialog fields properly following Gerber file selection.
复制代码 |
