1、这段程序中PWM_PERIOD的意思?
2、舍得同步AD采样的的作用和原理?
// ADC Syncronization setting value
if ((u16)(PWM_PERIOD-hTimePhA) > TW_AFTER)
hTimePhD = PWM_PERIOD - 1;
hDeltaDuty = (u16)(hTimePhA - hTimePhB);
3、穿越点的定于和原理
// Definition of crossing point
if (hDeltaDuty > (u16)(PWM_PERIOD-hTimePhA)*2)
hTimePhD = hTimePhA - TW_BEFORE; // Ts before Phase A
hTimePhD = hTimePhA + TW_AFTER; // DT + Tn after Phase A
if (hTimePhD >= PWM_PERIOD)
// Trigger of ADC at Falling Edge PWM4
// OCR update
//Set Polarity of CC4 Low
PWM4Direction=PWM1_MODE;
hTimePhD = (2 * PWM_PERIOD) - hTimePhD-1;
void SVPWM_3ShuntCalcDutyCycles (Volt_Components Stat_Volt_Input)
s32 wX, wY, wZ, wUAlpha, wUBeta;
u16 hTimePhA=0, hTimePhB=0, hTimePhC=0, hTimePhD=0;
u16 hDeltaDuty;
wUAlpha = Stat_Volt_Input.qV_Component1 * T_SQRT3 ;
wUBeta = -(Stat_Volt_Input.qV_Component2 * T);
wX = wUBeta;
wY = (wUBeta + wUAlpha)/2;
wZ = (wUBeta - wUAlpha)/2;
// Sector calculation from wX, wY, wZ
if (wY<0)
if (wZ<0)
bSector = SECTOR_5;
else // wZ >= 0
if (wX<=0)
bSector = SECTOR_4;
else // wX > 0
bSector = SECTOR_3;
else // wY > 0
if (wZ>=0)
bSector = SECTOR_2;
else // wZ < 0
if (wX<=0)
bSector = SECTOR_6;
else // wX > 0
bSector = SECTOR_1;
/* Duty cycles computation */
PWM4Direction=PWM2_MODE;
switch(bSector)
//#define T (PWM_PERIOD * 4)
//#define PWM_PRSC ((u8)0)
/* Resolution: 1Hz */
//#define PWM_PERIOD ((u16) (CKTIM / (u32)(2 * PWM_FREQ *(PWM_PRSC+1))))
//2^17 = 131072
case SECTOR_1:
hTimePhA = (T/8) + ((((T + wX) - wZ)/2)/131072);
hTimePhB = hTimePhA + wZ/131072;
hTimePhC = hTimePhB - wX/131072;
// OCR update
// ADC_InjectedChannelConfig(ADC1, PHASE_B_CHANNEL,1,
// SAMPLING_TIME_CK);
ADC1->JSQR = PHASE_B_MSK + BUS_VOLT_FDBK_MSK + SEQUENCE_LENGHT;
//ADC_InjectedChannelConfig(ADC2, PHASE_C_CHANNEL,1,
ADC2->JSQR = PHASE_C_MSK + TEMP_FDBK_MSK + SEQUENCE_LENGHT;
case SECTOR_2:
hTimePhA = (T/8) + ((((T + wY) - wZ)/2)/131072);
hTimePhC = hTimePhA - wY/131072;
if ((u16)(PWM_PERIOD-hTimePhB) > TW_AFTER)
hDeltaDuty = (u16)(hTimePhB - hTimePhA);
if (hDeltaDuty > (u16)(PWM_PERIOD-hTimePhB)*2)
hTimePhD = hTimePhB - TW_BEFORE; // Ts before Phase B
hTimePhD = hTimePhB + TW_AFTER; // DT + Tn after Phase B
// OCR update
//ADC_InjectedChannelConfig(ADC1, PHASE_A_CHANNEL,1,
ADC1->JSQR = PHASE_A_MSK + BUS_VOLT_FDBK_MSK + SEQUENCE_LENGHT;
// PHASE_C_CHANNEL,1,SAMPLING_TIME_CK);
case SECTOR_3:
hTimePhA = (T/8) + ((((T - wX) + wY)/2)/131072);
hTimePhB = hTimePhC + wX/131072;
hDeltaDuty = (u16)(hTimePhB - hTimePhC);
// OCR update
case SECTOR_4:
if ((u16)(PWM_PERIOD-hTimePhC) > TW_AFTER)
hDeltaDuty = (u16)(hTimePhC - hTimePhB);
if (hDeltaDuty > (u16)(PWM_PERIOD-hTimePhC)*2)
hTimePhD = hTimePhC - TW_BEFORE; // Ts before Phase C
hTimePhD = hTimePhC + TW_AFTER; // DT + Tn after Phase C
// OCR update
//ADC_InjectedChannelConfig(ADC2, PHASE_B_CHANNEL,1,
ADC2->JSQR = PHASE_B_MSK + TEMP_FDBK_MSK + SEQUENCE_LENGHT;
case SECTOR_5:
hDeltaDuty = (u16)(hTimePhC - hTimePhA);
// OCR update
case SECTOR_6:
hDeltaDuty = (u16)(hTimePhA - hTimePhC);
// OCR update
//ADC_InjectedChannelConfig(ADC1, PHASE_B_CHANNEL,1,
default:
if (PWM4Direction == PWM2_MODE)
//Set Polarity of CC4 High
TIM1->CCER &= 0xDFFF;
TIM1->CCER |= 0x2000;
/* Load compare registers values */
TIM1->CCR1 = hTimePhA;
TIM1->CCR2 = hTimePhB;
TIM1->CCR3 = hTimePhC;
TIM1->CCR4 = hTimePhD; // To Syncronyze the ADC
