采用tensorflow对35万个姓名和性别进行学习,学习完成保存模型。
用保存的模型对输入的姓名进行性别预测。
先贴个图:
开发环境:win10 64位
软件:pycharm, python3.6, tensorflow1.50, pyinstaller 3.3.1
用pyinstaller来打包
- pyinstaller test.py --hidden-import="pandas._libs.tslibs.timedeltas"
打包后的文件太大,放在网盘里,需要的可以下载。
链接:https://pan.baidu.com/s/1erAmMaYENdWE71dMnv07eQ 密码:dl0y
代码如下:
- #!/usr/bin/python3.6
- # -*- coding: utf-8 -*-
- import os
- import tensorflow as tf
- os.environ['TF_CPP_MIN_LOG_LEVEL'] = '2'
- NameDataSet = 'name.csv'
- train_x = []
- train_y = []
- with open(NameDataSet, 'r', encoding='UTF-8') as f:
- first_line = True
- for line in f:
- if first_line is True:
- first_line = False
- continue
- sample = line.strip().split(',')
- if len(sample) == 2:
- train_x.append(sample[0])
- if sample[1] == '男':
- train_y.append([0, 1]) # 男
- else:
- train_y.append([1, 0]) # 女
- # max_name_length = max([len(name) for name in train_x])
- # print("最长名字的字符数: %s" % max_name_length)
- max_name_length = 5
- # 词汇表(参看聊天机器人练习)
- counter = 0
- vocabulary = {}
- for name in train_x:
- counter += 1
- tokens = [word for word in name]
- for word in tokens:
- if word in vocabulary:
- vocabulary[word] += 1
- else:
- vocabulary[word] = 1
- vocabulary_list = [' '] + sorted(vocabulary, key=vocabulary.get, reverse=True)
- # print(len(vocabulary_list))
- # 字符串转为向量形式
- vocab = dict([(x, y) for (y, x) in enumerate(vocabulary_list)])
- train_x_vec = []
- name_vec = []
- for word in name:
- name_vec.append(vocab.get(word))
- while len(name_vec) < max_name_length:
- name_vec.append(0)
- train_x_vec.append(name_vec)
- input_size = max_name_length
- num_classes = 2
- batch_size = 64
- num_batch = len(train_x_vec) // batch_size
- X = tf.placeholder(tf.int32, [None, input_size])
- Y = tf.placeholder(tf.float32, [None, num_classes])
- dropout_keep_prob = tf.placeholder(tf.float32)
- def neural_network(vocabulary_size, embedding_size=128, num_filters=128):
- # embedding layer
- with tf.device('/cpu:0'), tf.name_scope("embedding"):
- W = tf.Variable(tf.random_uniform([vocabulary_size, embedding_size], -1.0, 1.0))
- embedded_chars = tf.nn.embedding_lookup(W, X)
- embedded_chars_expanded = tf.expand_dims(embedded_chars, -1)
- # convolution + maxpool layer
- filter_sizes = [3, 4, 5]
- pooled_outputs = []
- for i, filter_size in enumerate(filter_sizes):
- with tf.name_scope("conv-maxpool-%s" % filter_size):
- filter_shape = [filter_size, embedding_size, 1, num_filters]
- W = tf.Variable(tf.truncated_normal(filter_shape, stddev=0.1))
- b = tf.Variable(tf.constant(0.1, shape=[num_filters]))
- conv = tf.nn.conv2d(embedded_chars_expanded, W, strides=[1, 1, 1, 1], padding="VALID")
- h = tf.nn.relu(tf.nn.bias_add(conv, b))
- pooled = tf.nn.max_pool(h, ksize=[1, input_size - filter_size + 1, 1, 1], strides=[1, 1, 1, 1], padding='VALID')
- pooled_outputs.append(pooled)
- num_filters_total = num_filters * len(filter_sizes)
- # h_pool = tf.concat(3, pooled_outputs)
- h_pool = tf.concat(pooled_outputs, 3)
- h_pool_flat = tf.reshape(h_pool, [-1, num_filters_total])
- # dropout
- with tf.name_scope("dropout"):
- h_drop = tf.nn.dropout(h_pool_flat, dropout_keep_prob)
- # output
- with tf.name_scope("output"):
- W = tf.get_variable("W", shape=[num_filters_total, num_classes])
- b = tf.Variable(tf.constant(0.1, shape=[num_classes]))
- output = tf.nn.xw_plus_b(h_drop, W, b)
- return output
- # 训练
- def train_neural_network():
- output = neural_network(len(vocabulary_list))
- optimizer = tf.train.AdamOptimizer(1e-3)
- loss = tf.reduce_mean(tf.nn.softmax_cross_entropy_with_logits(logits=output, labels=Y))
- grads_and_vars = optimizer.compute_gradients(loss)
- train_op = optimizer.apply_gradients(grads_and_vars)
- saver = tf.train.Saver(tf.global_variables())
- with tf.Session() as sess:
- sess.run(tf.global_variables_initializer())
- for e in range(201):
- for i in range(num_batch):
- batch_x = train_x_vec[i * batch_size: (i + 1) * batch_size]
- batch_y = train_y[i * batch_size: (i + 1) * batch_size]
- _, loss_ = sess.run([train_op, loss], feed_dict={X: batch_x, Y: batch_y, dropout_keep_prob: 0.5})
- print("%s %s %s" % (e, i, loss_))
- if e % 50 == 0:
- saver.save(sess, "./name2sex.model", global_step=e)
- # train_neural_network()
- # 使用训练的模型
- def detect_sex(name_list):
- x = []
- for name in name_list:
- NameVec = []
- for word in name:
- NameVec.append(vocab.get(word))
- while len(NameVec) < max_name_length:
- NameVec.append(0)
- x.append(NameVec)
- # 恢复前一次训练
- ckpt = tf.train.get_checkpoint_state('.')
- if ckpt is not None:
- # print(ckpt.model_checkpoint_path)
- saver.restore(sess, ckpt.model_checkpoint_path)
- else:
- print("没找到模型")
- predictions = tf.argmax(output, 1)
- res = sess.run(predictions, {X: x, dropout_keep_prob: 1.0})
- i = 0
- print(name, '女' if res[i] == 0 else '男')
- i += 1
- if __name__ == '__main__':
- InputName = input("请输入姓名:")
- detect_sex([InputName])
- input("\n输入回车结束")
