发表于 2018-7-4 10:08:15
https://www.virtualhere.com/usb_server_software
Installation is simple, figure out the architecture of your server device
(for example x86_64), then on the linux server device:
wget http://www.virtualhere.com/sites ... server/vhusbdx86_64 (e.g x86_64, see list below)
chmod +x ./vhusbdx86_64 (to make that file executable)
sudo ./vhusbdx86_64 -b (to run it in the background)
Plug USB devices to share into your server and run the Client on the remote machines
See FAQ here
https://www.virtualhere.com/oem_faq
VirtualHere will run on any edition of linux including
Scientific Linux, Ubuntu, CentOS, RedHat, OpenSuse, Angstrom, Android, Raspbian, Debian, OpenWRT....
The trial version of the server will allow you to share 1 device without time restrictions using one of the Generic builds below.
To share more devices, resell VirtualHere on your own device, or use a CPU optimized build of VirtualHere please purchase a license
https://www.virtualhere.com/embedded_server_license
Version 3.6.6 (Changes) (SHA1SUM)
Generic VirtualHere USB Server Builds.
The Generic builds allow the sharing of one USB device in trial mode. They have no specific CPU optimizations and are good for general use
VirtualHere USB Server for Linux (i386) <-- 32-bit desktop pcs/servers/Intel Edison running any version of Linux
VirtualHere USB Server for Linux (AMD64) <-- 64-bit desktop pc's/servers running any version of Linux
VirtualHere USB Server for Linux (ARM) <-- Raspberry Pi, pi2, pi3,BeagleBone, Odroid, Angstrom, & any ARM 32-bit based Android
VirtualHere USB Server for Linux (ARM64) <-- Odroid-C2, Dragonboard 410c, PineA64, & any aarch64 based 64-bit Linux or Android device
VirtualHere USB Server for Linux (MIPS) <-- MIPS Big-Endian routers, embedded boards, etc...
VirtualHere USB Server for Linux (MIPSEL) <-- MIPS Little-Endian based routers, single board computers etc...
安装很简单,找出服务器设备的架构(例如x86_64),然后在linux服务器设备上:
wget http://www.virtualhere.com/sites ... server/vhusbdx86_64(例如x86_64,见下面的列表)
chmod + x ./vhusbdx86_64(使该文件可执行)
sudo ./vhusbdx86_64 -b(在后台运行)
插入USB设备以共享到您的服务器并在远程计算机上运行客户端
请参阅这里的FAQ
VirtualHere将在任何版本的Linux上运行,包括
Scientific Linux,Ubuntu,CentOS,RedHat,OpenSuse,Angstrom,Android,Raspbian,Debian,OpenWRT ....
该服务器的试用版将允许您使用以下通用版本之一共享1台设备而不受时间限制。
要共享更多设备,请在您自己的设备上转售VirtualHere,或使用CPU优化的VirtualHere版本,请购买许可证
版本3.6.6(更改)(SHA1SUM)
通用VirtualHere USB服务器构建。
通用版本允许在试用模式下共享一个USB设备。它们没有特定的CPU优化,适合一般用途
适用于Linux的VirtualHere USB服务器(i386)< - 32位台式机/服务器/运行任何版本Linux的英特尔Edison
https://www.virtualhere.com/site ... sbserver/vhusbdi386
适用于Linux的VirtualHere USB服务器(AMD64)< - 运行任何版本Linux的64位台式机/服务器
https://www.virtualhere.com/site ... server/vhusbdx86_64
适用于Linux的VirtualHere USB服务器(ARM)< - Raspberry Pi,pi2,pi3,BeagleBone,Odroid,Angstrom和任何基于ARM 32位的Android
https://www.virtualhere.com/site ... usbserver/vhusbdarm
适用于Linux的VirtualHere USB服务器(ARM64)< - Odroid-C2,Dragonboard 410c,PineA64和任何基于aarch64的64位Linux或Android设备
https://www.virtualhere.com/site ... bserver/vhusbdarm64
适用于Linux的VirtualHere USB服务器(MIPS)< - MIPS Big-Endian路由器,嵌入式主板等...
https://www.virtualhere.com/site ... sbserver/vhusbdmips
适用于Linux的VirtualHere USB服务器(MIPSEL)< - 基于MIPS Little-Endian的路由器,单板计算机等......
https://www.virtualhere.com/site ... server/vhusbdmipsel
