SuperView 串口屏是中科世为基于FlyThingsOS (OS介绍 [url= https://www.amobbs.com/thread-5693817-1-1.html] https://www.amobbs.com/thread-5693817-1-1.html[/url])开发的一款类串口屏的产品。
开发者页面:doc.zkswe.com;
这里我们讲解一下如何利用SuperView的显示模组实现sqlite数据库的操作。
新建好一个FlyThings Project 项目。
在jni代码目录中添加 db文件夹。放入从github上下载的sqlite3源码:sqlite3.c ,sqlite3.h
github 路径:https://github.com/zkswe/thirdPart/tree/master/sqlite
设计一个供应用开发使用的Database类
- #ifndef JNI_DB_DATABASE_H_
- #define JNI_DB_DATABASE_H_
- #include <vector>
- #include <string>
- #include "sqlite3.h"
- typedef struct{
- std::string name;
- std::string num;
- std::string age;
- std::string score;
- }S_INFOS;
- class Database {
- public:
- Database(std::string path);
- virtual ~Database();
- void recodeResult(std::string name,std::string num,std::string age,std::string score);
- std::vector<S_INFOS> getRecodes();
- void clear();
- void saveas(std::string path);
- private:
- sqlite3* pDB;
- std::vector<S_INFOS> dbs;
- #endif /* JNI_DB_DATABASE_H_ */
- 在Database.cpp 内添加
- * Database.cpp
- * Created on: 2018年5月27日
- * Author: Kwolve
- #include "Database.h"
- #include "utils/Log.h"
- #include "uart/ProtocolData.h"
- #include "uart/ProtocolParser.h"
- void Database::recodeResult(std::string name,std::string num,std::string age,std::string score) {
- std::string sqltestr ="";
- sqltestr += "insert into recode(name,num,age,score) values('"+name+"','"+
- num+"','"+
- age+"','"+
- score+"');";
- char* errmsg;
- LOGD("sqlite exec :%s",sqltestr.c_str());
- if(pDB != NULL){
- int ret = sqlite3_exec(pDB,sqltestr.c_str(),0,0, &errmsg);
- if(ret != SQLITE_OK){
- LOGD("sqlite exec err:%s",errmsg);
- std::vector<S_INFOS> Database::getRecodes() {
- const char* cmd = "select * from recode";
- char** result;
- int nRow;
- int nCol;
- char* errmsg;
- dbs.clear();
- dbs.empty();
- int ret = sqlite3_get_table(pDB, cmd, &result, &nRow, &nCol, &errmsg);
- LOGD("select * form recode ret:%s",errmsg);
- return dbs;
- std::string strOut;
- int nIndex = nCol;
- S_INFOS info;
- for(int i=0;i<nRow;i++)
- info.name = result[nIndex];
- ++nIndex;
- info.num = result[nIndex];
- ++nIndex;
- info.age = result[nIndex];
- ++nIndex;
- info.score = result[nIndex];
- ++nIndex;
- dbs.push_back(info);
- LOGD("read size %d",nRow);
- LOGD("read size %d",dbs.size());
- sqlite3_free_table(result);
- return dbs;
- Database::Database(std::string path) {
- // TODO 自动生成的构造函数存根
- int ret = sqlite3_open(path.c_str(), &pDB);
- LOGD("open sqlite ret:%d",ret);
- pDB = NULL;
- return;
- const char* cmd = "CREATE TABLE IF NOT EXISTS recode(name,num,age,score);";
- char* errmsg;
- sqlite3_exec(pDB,cmd,0,0, &errmsg);
- LOGD("create table ret:%s",errmsg);
- Database::~Database() {
- // TODO 自动生成的析构函数存根
- sqlite3_free(pDB);
- void Database::clear() {
- const char* cmd = "DELETE FROM recode";
- char* errmsg;
- int ret = sqlite3_exec(pDB,cmd,0,0, &errmsg);
- LOGD("create DELETE ret:%s",errmsg);
- void Database::saveas(std::string path) {
在Logic/mainLogic.cc 内添加数据库操作代码
定义数据库
- #include "db/Database.h"
- Database dbs("/mnt/extsd/test.db");
保存时操作
- static bool onButtonClick_ButtonSave(ZKButton *pButton) {
- //LOGD(" ButtonClick ButtonSave !!!\n");
- dbs.recodeResult(mEdittextNamePtr->getText(),
- mEdittextNoPtr->getText(),
- mEdittextAgePtr->getText(),
- mEdittextScorePtr->getText());
- return true;
数据库读取以及列表显示
新建一个data.ftu 的ui文件,用于展示数据库内容
代码中添加列表显示的部分
- extern Database dbs;
- static std::vector<S_INFOS> pVector;
- static int nRows;
- static int nSelectRow;
- const char* titileTab[]={
- "姓名","学号","年龄","分数"
- * 注册定时器
- * 在此数组中添加即可
- static S_ACTIVITY_TIMEER REGISTER_ACTIVITY_TIMER_TAB[] = {
- //{0, 6000}, //定时器id=0, 时间间隔6秒
- //{1, 1000},
- static void onUI_init(){
- //Tips :添加 UI初始化的显示代码到这里,如:mText1->setText("123");
- pVector = dbs.getRecodes();
- nRows = pVector.size()+1;
- static void onUI_quit() {
- static void onProtocolDataUpdate(const SProtocolData &data) {
- // 串口数据回调接口
- static bool onUI_Timer(int id){
- //Tips:添加定时器响应的代码到这里,但是需要在本文件的 REGISTER_ACTIVITY_TIMER_TAB 数组中 注册
- //id 是定时器设置时候的标签,这里不要写耗时的操作,否则影响UI刷新,ruturn:[true] 继续运行定时器;[false] 停止运行当前定时器
- return true;
- static bool ondataActivityTouchEvent(const MotionEvent &ev) {
- // 返回false触摸事件将继续传递到控件上,返回true表示该触摸事件在此被拦截了,不再传递到控件上
- return false;
- static int getListItemCount_Listview1(const ZKListView *pListView) {
- //LOGD(" getListItemCount_ Listview1 !!!\n");
- return nRows*4;
- static void obtainListItemData_Listview1(ZKListView *pListView,ZKListView::ZKListItem *pListItem, int index) {
- //LOGD(" obtainListItemData_ Listview1 !!!\n");
- if(index < 4){
- pListItem->setText(titileTab[index]);
- }else{
- int rindex = index-4;
- int row = rindex/4;
- S_INFOS info = pVector.at(row);
- int id = rindex%4;
- switch(id){
- case 0:
- pListItem->setText(info.name);
- break;
- case 1:
- pListItem->setText(info.num);
- break;
- case 2:
- pListItem->setText(info.age);
- break;
- case 3:
- pListItem->setText(info.score);
- break;
- static void onListItemClick_Listview1(ZKListView *pListView, int index, int id) {
- //LOGD(" onListItemClick_ Listview1 !!!\n");
- nSelectRow = index/4 - 1;
- S_INFOS info = pVector.at(nSelectRow);
- mEdittextNamePtr->setText(info.name);
- mEdittextNoPtr->setText(info.num);
- mEdittextAgePtr->setText(info.age);
- mEdittextSCorePtr->setText(info.score);
- mWindowTipPtr->showWnd();
样例代码下载
