事情是这样的,我有个表妹在澳大利亚留学,学的是生物医药,没有接触过单片机,但是这学期他们都是给安排了单片机课程,用的是MSP430FR5969,还安排了作业,采用的是TI官方开发板 MSP430FR5969,编写串口发送功能,因此想我请教,而我本人没有接触过这个单片机,手上也没有开发板,参考资料写了一个程序,表妹反馈程序下载指示灯正常,串口无数据,因此向各位大神请教一下代码是否有问题:
#include "msp430.h"
//void uart_putc(unsigned char byte);
//static void uart_putst(char string);
#define RX_BUFFER_LENGTH 100
static volatile int RXbuffer[RX_BUFFER_LENGTH];
static volatile int RXbufferIDX;
static volatile int RXbuffer_temp;
volatile unsigned int tx_flag;
//UART Definition
//USCI_A1
#define UART_TX_READY (UCA1IFG & UCTXIFG)
#define UART_TX_DONE (UCA1IFG & UCTXCPTIFG)
#define UART_RESET_TX_DONE (UCA1IFG &= ~UCTXCPTIFG)
//Functions for USCI_A0
static void uart_putc(char c)
//EUSCI_A_UART_transmitData(EUSCI_A1_BASE, c);
while(!UART_TX_READY);
UCA1TXBUF =c;
while (!UART_TX_DONE)
UART_RESET_TX_DONE;
void Delay(int num)
int a,b;
for(a = 0;a< num;a++)
for(b = 0;b<1000;b++)
static void uart_putst(char *str)
while(*str)
uart_putc(*str);
str++;
void initi_UART_A1(void)
// Disable the GPIO power-on default high-impedance mode to activate
// previously configured port settings
// PM5CTL0 &= ~LOCKLPM5;
// Configure USCI_A1 for UART mode
UCA1CTLW0 = UCSWRST; // Put eUSCI in reset
UCA1CTLW0 |= UCSSEL__SMCLK; // CLK = SMCLK
// Baud Rate calculation=9600
UCA1BR0 = 52; // 8000000/16/9600
UCA1MCTLW |=UCOS16 | UCBRF_5;
UCA1BR1 = 0;
UCA1CTLW0 &= ~UCSWRST; // Initialize eUSCI
UCA1IE |= UCTXIE; // Enable USCI_A1 TX interrupt
// UCA1IE |= UCRXIE; // Enable USCI_A1 TX interrupt
tx_flag =0;//unused
void initial_Clock(void)
// Startup clock system with max DCO setting ~8MHz
CSCTL0_H = CSKEY >> 8; // Unlock clock registers
//CSCTL1 = DCOFSEL_6;// Set DCO to 8MHz 20180417
//CSCTL2 = SELA__LFXTCLK | SELS__DCOCLK | SELM__DCOCLK;
CSCTL1 = DCOFSEL_3 | DCORSEL; // Set DCO to 8MHz
CSCTL2 = SELA__VLOCLK | SELS__DCOCLK | SELM__DCOCLK;
CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1; // Set all dividers
do
CSCTL5 &= ~LFXTOFFG;
SFRIFG1 &= ~OFIFG;
}while(SFRIFG1&OFIFG);
CSCTL0_H = 0; // Lock CS registers
//Transmit Interrupt
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCI_A1_VECTOR
__interrupt void USCI_A1_ISR (void)
#elif defined(__GNUC__)
__attribute__((interrupt(USCI_A1_VECTOR)))void USCI_A1_ISR(void)
#else
#error Compiler not supported!
UCA1IFG &= ~UCTXIFG;
UCA0IFG &= ~UCRXIFG;
UCA1RXBUF = UCA0TXBUF;
void Initial_GPIO(void)
P1OUT = 0;
P1DIR =0xFF;
P3OUT = 0;
P3DIR =0xFF;
P4OUT = 0;
P4DIR =0xFF;
PJOUT =0;
PJDIR=0xFFFF;
P2SEL1 |= BIT5 | BIT6; // USCI_A1 UART operation
P2SEL0 &= ~(BIT5 | BIT6);
//P2SEL1 |= BIT0 | BIT1; // 20180417
//P2SEL0 &= ~(BIT0 | BIT1);
PJSEL0 |=BIT4|BIT5;
//Main Function
int main(void)
volatile unsigned j;
WDTCTL = WDTPW | WDTHOLD; // Stop Watchdog
// Configure GPIO
//P1OUT &=~BIT0;
//P1DIR =BIT1;
Initial_GPIO();
initial_Clock();
initi_UART_A1();
_EINT();//enable interrupt
//_bis_SR_register(LPM0_bits); // Enter LPM3, interrupts enabled
P1OUT &=~BIT0;
P4OUT &=~BIT6;
while (1)
P1OUT |= BIT0;
P4OUT |= BIT6;
uart_putst((char *)"HELLO");
uart_putc(0x0D);
uart_putc(0x0A);//new line
__delay_cycles(2000000);
P1OUT &=~BIT0;
P4OUT &=~BIT6;
PS:按照规矩先上照片,但确实手机没有存,也没有拍过,有机会奉上,先帮忙解决问题,谢谢! |
