DDR IP 约束要求 dqs_int_delay_in*" MAXDELAY = 580 ps;
- Timing constraint: NET "ddr2/ctrl/ip/top_00/dqs_int_delay_in<0>" MAXDELAY = 0.19 ns;
- 1 net analyzed, 1 failing net detected.
- 1 timing error detected.
- Maximum net delay is 2.235ns.
- Slack: -2.045ns ddr2/ctrl/ip/top_00/dqs_int_delay_in<0>
- Error: 2.235ns delay exceeds 0.190ns timing constraint by 2.045ns
- From To Delay(ns)
- J21.I SLICE_X79Y136.CLK 2.219
- J21.I SLICE_X79Y137.CLK 2.219
- J21.I SLICE_X79Y132.CLK 1.771
- J21.I SLICE_X79Y138.CLK 2.229
- J21.I SLICE_X79Y135.CLK 1.780
- J21.I SLICE_X79Y134.CLK 1.780
- J21.I SLICE_X76Y136.CLK 2.114
- J21.I SLICE_X78Y138.CLK 2.229
- J21.I SLICE_X78Y139.CLK 2.229
- J21.I SLICE_X78Y137.CLK 2.219
- J21.I SLICE_X78Y136.CLK 2.219
- J21.I SLICE_X78Y134.CLK 1.780
- J21.I SLICE_X78Y135.CLK 1.780
- J21.I SLICE_X76Y134.CLK 1.733
- J21.I SLICE_X76Y137.CLK 2.114
- J21.I SLICE_X78Y133.CLK 1.771
- J21.I SLICE_X76Y135.CLK 1.733
- J21.I SLICE_X76Y133.CLK 1.727
- J21.I SLICE_X78Y130.CLK 1.758
- J21.I SLICE_X78Y132.CLK 1.771
- J21.I SLICE_X78Y140.CLK 2.235
- J21.I SLICE_X78Y131.CLK 1.758
怎么解决?
已解决,对DDR2模块中的延时单位,进行绝对定位的约束。 |
