发表于 2017-9-2 14:29:40
串口接收的数据按协议得到相应的值
- static float Vk=1.88;//分压电阻算出的值
- static float Ik=0.25;//根据采样电阻(4mR)算出的值
- static uint32_t VParam=0;
- static uint32_t VReg=0;
- static float V=0;
- static uint32_t IParam=0;
- static uint32_t IReg=0;
- static float I=0;
- static uint32_t PParam=0;
- static uint32_t PReg=0;
- static float P=0;
- static float PV=0;
- static float PF=0;
- static float PBuf[20];
- static float PMin=0;
- static uint8_t Windex=0;
- void Widget::WLW8032_DecodProtocol(uint8_t Data)
- static uint8_t status=0;
- static uint8_t index=0;
- static uint8_t sum=0;
- static uint8_t tempBuf[24];
- static uint8_t i;
- switch (status)
- case 0:
- if(Data==0x55)
- tempBuf[0]=Data;
- status=1;
- break;
- case 1:
- if(Data==0x5A)
- tempBuf[1]=Data;
- status=2;
- else status=0;
- index=2;
- sum=0;
- break;
- case 2:
- tempBuf[index]=Data;
- index++;
- if(index==24)
- if(sum==Data)
- //Tools_Printf("check sum OK\r\n");
- if(tempBuf[20]&(0x03<<4))
- VParam=(tempBuf[2]<<24)|(tempBuf[3]<<16)|tempBuf[4];
- VReg=(tempBuf[5]<<24)|(tempBuf[6]<<16)|tempBuf[7];
- IParam=(tempBuf[8]<<24)|(tempBuf[9]<<16)|tempBuf[10];
- IReg=(tempBuf[11]<<24)|(tempBuf[12]<<16)|tempBuf[13];
- PParam=(tempBuf[14]<<24)|(tempBuf[15]<<16)|tempBuf[16];
- PReg=(tempBuf[17]<<24)|(tempBuf[18]<<16)|tempBuf[19];
- V=(float)VParam/(float)VReg*Vk;
- I=(float)IParam/(float)IReg*Ik;
- P=(float)PParam/(float)PReg*Vk*Ik;
- PV=V*I;
- PF=P/PV;
- //Tools_Printf("V:%f\tI:%f\tP:%f\tPV:%f\r\n",V,I,P,PV);
- qDebug()<<"V:"<<V<<"I:"<<I<<"P:"<<P<<"PV:"<<PV<<"PF:"<<PF;
- //else Tools_Printf("check sum Fail\r\n");
- status=0;
- else
- sum+=Data;
- break;
- default:
- break;
复制代码 |
