大家好,
这是转来的一片文章,memory layout of Linux userspace,希望这些对你有所帮助。
原文地址:http://learnlinuxconcepts.blogspot.com/2014/03/memory-layout-of-userspace-c-program.html
PS:如果大家对用户空间和内核空间有不同理解的话,本人现在也在学习中,欢迎大家交流。
Memory Layout of Kernel and UserSpace in Linux.
1、Each process in a multi-tasking OS runs in its own memory sandbox.
2、This sandbox is the virtual address space, which in 32-bit mode is always a 4GB block of memory addresses.
3、These virtual addresses are mapped to physical memory by page tables, which are maintained by the operating system kernel and consulted by the processor.
4、Each process has its own set of page tables, but there is a catch. Once virtual addresses are enabled, they apply to all software running in the machine, including the kernel itself. Thus a portion of the virtual address space must be reserved to the kernel:
5、This does not mean the kernel uses that much physical memory, only that it has that portion of address space available to map whatever physical memory it wishes.
6、Kernel space is flagged in the page tables as exclusive to privileged code (ring 2 or lower), hence a page fault is triggered if user-mode programs try to touch it.
7、In Linux, kernel space is constantly present and maps the same physical memory in all processes.
8、Kernel code and data are always addressable, ready to handle interrupts or system calls at any time.
10、By contrast, the mapping for the user-mode portion of the address space changes whenever a process switch happens:
11、Blue regions represent virtual addresses that are mapped to physical memory, whereas white regions are unmapped.
12、In the example above, Firefox has used far more of its virtual address space due to its legendary memory hunger.
13、The distinct bands in the address space correspond to memory segments like the heap, stack, and so on.
14、These segments are simply a range of memory addresses and have nothing to do with Intel-style segments. Anyway, here is the standard segment layout in a Linux process:
15、When computing was happy and safe and cuddly, the starting virtual addresses for the segments shown above were exactly the same for nearly every process in a machine.
16、Now Linux randomizes the stack, memory mapping segment, and heap by adding offsets to their starting addresses.
17、Unfortunately the 32-bit address space is pretty tight, leaving little room for randomization and hampering its effectiveness.
18、The topmost segment in the process address space is the stack, which stores local variables and function parameters in most programming languages. Calling a method or function pushes a new stack frame onto the stack. The stack frame is destroyed when the function returns. This simple design, possible because the data obeys strict LIFO order, means that no complex data structure is needed to track stack contents – a simple pointer to the top of the stack will do. Pushing and popping are thus very fast and deterministic. Also, the constant reuse of stack regions tends to keep active stack memory in the cpu caches, speeding up access. Each thread in a process gets its own stack.
19、It is possible to exhaust the area mapping the stack by pushing more data than it can fit. This triggers a page fault that is handled in Linux by expand_stack(), which in turn calls acct_stack_growth() to check whether it’s appropriate to grow the stack. If the stack size is below RLIMIT_STACK (usually 8MB), then normally the stack grows and the program continues merrily, unaware of what just happened. This is the normal mechanism whereby stack size adjusts to demand.
20、However, if the maximum stack size has been reached, we have a stack overflow and the program receives a Segmentation Fault. While the mapped stack area expands to meet demand, it does not shrink back when the stack gets smaller. Like the federal budget, it only expands.
21、Dynamic stack growth is the only situation in which access to an unmapped memory region, shown in white above, might be valid. Any other access to unmapped memory triggers a page fault that results in a Segmentation Fault .Some mapped areas are read-only, hence write attempts to these areas also lead to segfaults.
22、Below the stack, we have the memory mapping segment. Here the kernel maps contents of files directly to memory. Any application can ask for such a mapping via the Linux mmap() system call (implementation) .
23、Memory mapping is a convenient and high-performance way to do file I/O, so it is used for loading dynamic libraries. It is also possible to create an anonymous memory mapping that does not correspond to any files, being used instead for program data.
24、In Linux, if we request a large block of memory via malloc(), the C library will create such an anonymous mapping instead of using heap memory. ‘Large’ means larger than MMAP_THRESHOLD bytes, 128 kB by default and adjustable via mallopt().
25、Speaking of the heap, it comes next in our plunge into address space. The heap provides runtime memory allocation, like the stack, meant for data that must outlive the function doing the allocation, unlike the stack.
26、Most languages provide heap management to programs. Satisfying memory requests is thus a joint affair between the language runtime and the kernel. In C, the interface to heap allocation is malloc() and friends, whereas in a garbage-collected language like C# the interface is the new keyword.
27、If there is enough space in the heap to satisfy a memory request, it can be handled by the language runtime without kernel involvement. Otherwise the heap is enlarged via the brk() system call (implementation) to make room for the requested block.
28、Heap management is complex, requiring sophisticated algorithms that strive for speed and efficient memory usage in the face of our programs’ chaotic allocation patterns. The time needed to service a heap request can vary substantially. Real-time systems have special-purpose allocators to deal with this problem. Heaps also become fragmented, shown below:
29、Finally, we get to the lowest segments of memory: BSS, data, and program text. Both BSS and data store contents for static (global) variables in C.
30、The difference is that BSS stores the contents of uninitialized static variables, whose values are not set by the programmer in source code. The BSS memory area is anonymous: it does not map any file. If we say static int cntActiveUsers, the contents of cntActiveUsers live in the BSS.
31、The data segment, on the other hand, holds the contents for static variables initialized in source code. This memory area is not anonymous. It maps the part of the program’s binary image that contains the initial static values given in source code. So if we say static int cntWorkerBees = 10, the contents of cntWorkerBees live in the data segment and start out as 10.
32、Even though the data segment maps a file, it is a private memory mapping, which means that updates to memory are not reflected in the underlying file. This must be the case, otherwise assignments to global variables would change our on-disk binary image. Inconceivable!
33、The data example in the diagram is trickier because it uses a pointer. In that case, the contents of pointer gonzo – a 4-byte memory address – live in the data segment. The actual string it points to does not, however.
34、’The string lives in the text segment, which is read-only and stores all of our code in addition to tidbits like string literals. The text segment also maps our binary file in memory, but writes to this area earn our program a Segmentation Fault. This helps prevent pointer bugs, though not as effectively as avoiding C in the first place. Here’s a diagram showing these segments and our example variables:
35、We can examine the memory areas in a Linux process by reading the file /proc/pid_of_process/maps. Keep in mind that a segment may contain many areas. For example, each memory mapped file normally has its own area in the mmap segment, and dynamic libraries have extra areas similar to BSS and data.
36、We can examine binary images using the nm and objdump commands to display symbols, their addresses, segments, and so on. Finally, the virtual address layout described above is the “flexible” layout in Linux, which has been the default for a few years. It assumes that we have a value for RLIMIT_STACK. When that’s not the case, Linux reverts back to the “classic” layout shown below:
Classic Process Address Space Layout In Linux
