---上次发帖说用 sip做一个呼叫系统,折腾得好痛苦,如果有意的坛友可以参考一下,节省点时间和表情。肯定可以运行。如果有其中的高手,请指教一下。代码比较精糙。。哈
dbh=freeswitch.Dbh("odbc://fwsql");
laststat=""; --最后状态 1.hasline 2.notline 有否空内线 2.5 linenot 有空线到最后被用 3.linebusy 4.lineready 有空线是否能接入
badinline="";
function waittoinc(tmpsession)
local waitTimes = 10;
while tmpsession:ready() == false and waitTimes > 0 do
waitTimes = waitTimes - 1;
end
return tmpsession:ready()
end
function playwavs(tmpsession,wavfiles)
tmpsession:sleep(50);
if tmpsession:ready() then
freeswitch.consoleLog("err", "\n starting play wav");
tmpsession:streamFile(wavfiles);
freeswitch.consoleLog("err", "\n play wav end");
end
end
function getoneinline(notline) --获得一条空闲内线在 inlineinfo 表内
local reinline="";
dbh:query("select top 1 inline from inlineinfo where busy=0 and inline<>'"..notline.."' order by [index] asc,calltime asc"
,function(row) reinline=row.inline end )
if reinline==nil or reinline=="" then
laststat="notline";
return "";
end
laststat="hasline";
badinline=reinline;
return reinline;
end
function zoneinline(notline,calldh,callid) --获内线后,设置为忙
local reinline;
local revv;
local ktnow=os.date("%Y-%m-%d %H:%M:%S", os.time());
reinline=getoneinline(notline);
if reinline==nil then
reinline="";
return reinline;
end
dbh:query("update inlineinfo set busy=1,outline='"..calldh.."',callid='"..callid.."',calltime='"..ktnow.."' where inline='"..reinline.."' and busy=0");
revv=dbh:affected_rows();
badinline=reinline;
if revv>0 then
return reinline;
laststat="linenot";
return "";
end
end
function callinline(notline,calldh,callid)
local reinline=zoneinline(notline,calldh,callid);
return "",nil;
end
badinline=reinline;
local tmpnum=reinline;
local tmpsession= freeswitch.Session("user/"..tmpnum);
if waittoinc(tmpsession) then
laststat="lineready";
return tmpnum,tmpsession;
dbh:query("update inlineinfo set busy=0,[index]=(select isnull(count(*),0) from inlineinfo where busy=0)+1 where inline='"..reinline.."'")
laststat="linebusy";
return "",nil;
end
end
local session1 = session;
local cid=session1:getVariable("caller_id_number");
local dest_num=session1:getVariable("destination_number");
local kt=os.date("%Y-%m-%d %H:%M:%S", os.time());
local ktms=os.time();
dbh:query("insert into new通话(电话,kt,zt)values('"..cid.."','"..kt.."','"..dest_num.."')");
--playwavs(session1,"d:\\ffg\\wel.wav");
--如果座席所在的那条通道还没准备好,则进行等待
--session1:sleep(1800);
--if session1:ready() then
-- session1:answer();
-- end
local session2;
local inline;
local timess=0;
inline,session2=callinline("",dest_num,cid);--toonecall();
if inline=="" then
session1:sleep(50);
if (laststat=='linenot' or laststat=='linebusy') and badinline~='' and session1:ready() then
freeswitch.consoleLog("err", "\n channels2 is not ready, try next. laststat:"..laststat);
inline,session2=callinline(badinline,dest_num,cid);
end
end
if inline=="" then
session1:sleep(50);
end
end
if inline=="" then
-- 接通客户与座席
-- session2:setVariable("destination_number",cid);
freeswitch.consoleLog("err", "\n channels2 is not ready, please check it. laststat:"..laststat);
timess=-1;
playwavs(session1,"d:\\ffg\\busy.wav");
session1:sleep(50);
freeswitch.bridge(session1, session2);
timess=-2;
end
end
local et=os.date("%Y-%m-%d %H:%M:%S", os.time())
local etms=os.time();
if timess==0 then
timess=etms-ktms;
end
dbh:query("update inlineinfo set busy=0,[index]=(select isnull(count(*),0) from inlineinfo where busy=0)+1 where inline='"..inline.."'")
dbh:query("insert into 通话(电话,kt,zt,st)values('"..cid.."','"..kt.."','"..et.."',"..timess..")")
dbh:release()
最后说明,用的是 ms sql 上面是代码,下面表结构
USE [fwdb]
GO
/****** Object: Table [dbo].[inlineinfo] Script Date: 07/25/2017 10:32:40 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[inlineinfo](
[id] [int] IDENTITY(1,1) NOT NULL,
[inline] [varchar](40) NOT NULL,
[outline] [varchar](40) NULL,
[calltime] [varchar](20) NULL,
[busy] [int] NOT NULL,
[index] [int] NULL,
[callid] [varchar](40) NOT NULL,
CONSTRAINT [PK_netinlineinfo] PRIMARY KEY CLUSTERED
[id] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
SET ANSI_PADDING OFF
GO
USE [fwdb]
GO
/****** Object: Table [dbo].[通话] Script Date: 07/25/2017 10:33:31 ******/
SET ANSI_NULLS ON
GO
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[通话](
[电话] [varchar](20) NULL,
[kt] [varchar](20) NULL,
[zt] [varchar](20) NULL,
[st] [int] NULL,
CONSTRAINT [PK_通话] PRIMARY KEY CLUSTERED
[id] ASC
) ON [PRIMARY]
GO
GO
USE [fwdb]
GO
/****** Object: Table [dbo].[new通话] Script Date: 07/25/2017 10:33:23 ******/
SET ANSI_NULLS ON
GO
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[new通话](
CONSTRAINT [PK_net通话] PRIMARY KEY CLUSTERED
[id] ASC
) ON [PRIMARY]
GO
GO
