刚接触飞思卡尔的 用的是S12ZVM系列的开发板,现在碰到一个问题,软件编译正常,无警告报错,用Freescale CodeWarrior 10.7,软件下载程序会提示出错,是最后的程序校验报错。换其他的程序就能正确下载,硬件及连接都不会有问题。出错的程序换其他的硬件也还是报错,搞不懂了难道软件里面会有分配空间的冲突了?这个下载出错程序是将两个例子程序合在一起,大小14K.
附下载信息:
Starting 3rd party flash programming...
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : SPECIFY_NETWORKCARD_ENABLED, Value : 0, R) => DI_OK
INF: Copyright 2012 P&E Microcomputer Systems,Inc.
INF: Command Line :"D:\Freescale\CW MCU v10.7\eclipse\..\MCU\bin\de.exe" -noni -language en -ORBendPoint giop:tcp:127.0.0.1: -ORBtraceLevel 0
INF: CMD>RE
INF: Initializing.
INF: Target has been RESET and is active.
INF: CMD>CM D:\Freescale\CW MCU v10.7\MCU\bin\Plugins\support\s12z\gdi\P&E\freescale_9s12zvm128_1x16x64k_all.s12zp
INF: Initializing.
INF: (Bus Freq = 12487KHz)
INF: Initialized.
INF: ;version 1.05, 6/27/2014, Copyright P&E Microcomputer Systems, www.pemicro.com [freescale_9s12zvm128_pflash]
INF: ;device freescale, 9s12zvm128, 1x16x64k, desc=all
INF: ;begin_cs device=$00100000, length=$00020000, ram=$00001000
INF: Loading programming algorithm ...
INF: Done.
INF: CMD>EM
INF: Erasing.
INF: Module has been erased.
INF: Reloading programming algorithm ...
INF: done.
INF: CMD>PM
INF: Programming and Verifying.
INF: Processing Object File Data ...
INF: .
INF: Programmed.
INF: CMD>VC
INF: Verifying object file CRC-16 to device ranges ...
INF: block 00FE0000-00FE0050 ...
INF: Ok.
INF: block 00FE0054-00FE3637 ...
INF: Ok.
INF: block 00FFFE10-00FFFF0F ...
INF: CRC-16 Error in block. (File = $04AD, Device = $A4D0)
ERR: Error verifying flash of device
ERR: Error occured during Flash programming.
