我的是模拟摄像头+TVP5150+S3C6410,驱动是正常的,我用开发板的卖家提供的可执行程序测试过了,就是在没有源码,想自己写个程序,顺便学习一下V4L2编程。
我参考的是V4L2官方那个程序,再接在他的基础上修改了]参数,但是现在总是在分配内存(mmap)时失败。
错误信息如下:
- <------------camera infomation------------->
- device driver=Samsung FIMC Dris3c-fimc0
- device name=s3c-fimc0
- bus_infomation=FIMC AHB-bus
- image_width=640
- image_height=480
- pixel_format=1448695129
- <------------screen infomation------------->
- id=s3cfb
- x=800
- y=480
- bpp=16
- redoffset=11,redlength=5,msb_right=0
- greenoffset=5,greenlength=6,msb_right=0
- blueoffset=0,bluelength=5,msb_right=0
- screensize=768000
- init_mmap
- buffers[n_buffers].length=0
- buffers[n_buffers].start=-1
- mmap error 22, Invalid argument
相关代码如下:
- static void init_mmap(void)
- struct v4l2_requestbuffers req;
- fprintf(stderr, "init_mmap\n");
- //VIDIOC_REQBUFS
- CLEAR(req);
- req.count = 4;
- req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
- req.memory = V4L2_MEMORY_MMAP;
- if(-1 == xioctl(fd1, VIDIOC_REQBUFS, &req))
- if (EINVAL == errno)
- fprintf(stderr, "%s does not support ""memory mapping\n", dev_name1);
- exit(EXIT_FAILURE);
- else
- errno_exit("VIDIOC_REQBUFS");
- if(req.count < 2)
- fprintf(stderr, "Insufficient buffer memory on %s\n",dev_name1);
- //VIDIOC_QUERYBUF
- buffers = calloc(req.count, sizeof(*buffers)); ///////////
- if (!buffers)
- fprintf(stderr, "Out of memory\n");
- for (n_buffers = 0; n_buffers < req.count; ++n_buffers)
- struct v4l2_buffer buf;
- CLEAR(buf);
- buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
- buf.memory = V4L2_MEMORY_MMAP;
- buf.index = n_buffers;
- if (-1 == xioctl(fd1, VIDIOC_QUERYBUF, &buf))
- errno_exit("VIDIOC_QUERYBUF");
- buffers[n_buffers].length = buf.length;
- buffers[n_buffers].start =mmap(NULL /* start anywhere */,buf.length,
- PROT_READ | PROT_WRITE /* required */,
- MAP_SHARED /* recommended */,
- fd1, buf.m.offset);
- fprintf(stderr, "buffers[n_buffers].length=%d\n", buffers[n_buffers].length);
- fprintf(stderr, "buffers[n_buffers].start=%d\n", buffers[n_buffers].start);
- if (MAP_FAILED == buffers[n_buffers].start)
- errno_exit("mmap");
- }//now n_buffers is 4
- //fbmmap
- fb_buffer=(char*)mmap(NULL,screensize,PROT_READ | PROT_WRITE,MAP_SHARED,fd2,0);
- if(MAP_FAILED == fb_buffer)
- //malloc the yuv_buffer
- yuv_buffer = (char*)malloc(screensize);
- if (!yuv_buffer)
- //malloc the rgb_buffer
- rgb_buffer = (char*)malloc(screensize);
- if (!rgb_buffer)
复制代码 |
