回复: 5
CSR8670配置ADC功能
发表于 2017-4-17 18:21:24 | 显示全部楼层 |阅读模式
如题,有一块CSR8670的评估板,想自己配置ADC功能,采集外部其他的一些数据,
请问有相关经验的指导下。
 楼主| 发表于 2017-4-18 14:34:40 | 显示全部楼层
  1. const TaskData ADC_Task = {adctask_handler};
  2. void adctask_handler(Task task, MessageId id, Message message)
  3. {
  4.         switch (id)
  5.         {
  6.                 case MESSAGE_ADC_READ_START :
  7.             printf("ADC request ...\n");
  8.                         break;
  9.
  10.                 case MESSAGE_ADC_RESULT :
  11.         {
  12.                         MessageAdcResult *result = (MessageAdcResult *)message;
  13.                         uint16 reading = result->reading;
  14.                         if(result->adc_source == adcsel_aio0)
  15.                         {
  16.                                    printf("%d,  Vref = %d\n", reading, VmReadVrefConstant());
  17.                     printf("ADC Reulst Success!\n");
  18.                         }
  19.                         else if (result->adc_source == adcsel_vref)
  20.                         {
  21.                                 printf("adcsel_vref = %d\n", reading);
  22.                         }
  23.
  24.         }
  25.                 break;
  26.         default :
  27.                         break;
  28.         }
  29. }
  30. void AioReadStart(void)
  31. {
  32.         if (AdcRequest((TaskData *)&ADC_Task, adcsel_aio0))
  33.         {
  34.                 MessageSendLater((TaskData *)&ADC_Task, MESSAGE_ADC_READ_START, NULL, 5000);
  35.         }
  36. }
发表于 2017-4-18 16:59:51 | 显示全部楼层
测过的代码:
#include <pio_common.h>
#include <adc.h>
#include <pio.h>
#include <stdlib.h>
#include <vm.h>
void Aio_Init(void);
void AIO_ReadStart(Task task, vm_adc_source_type adc_source, uint32 period);
void AIO_ReadReStart(Task task);
void Aio_Handler(Task task, MessageId id, Message message);
typedef struct
        TaskData        task;
        uint16        voltage_value;
    vm_adc_source_type        adc_source;
} AIO_TaskData_T;
AIO_TaskData_T aio_app;
#define AIO_READ_PERIOD 1000
#define MESSAGE_ADC_READ_START        (MESSAGE_ADC_RESULT+100)
void Aio_Init(void)
        aio_app.task.handler = Aio_Handler;
        aio_app.voltage_value = 0;
        aio_app.adc_source = adcsel_aio0;
        AIO_ReadReStart(&aio_app.task);
        /* Request ADC Reading */
        if(AdcRequest(task, adc_source))
                /* Successful request*/
                aio_app.adc_source = adc_source;
                MessageSendLater(task, MESSAGE_ADC_READ_START, NULL, period);
        AIO_ReadStart(task, aio_app.adc_source, AIO_READ_PERIOD);
        switch(id)
                case MESSAGE_ADC_READ_START:
                AIO_ReadReStart(task);
                case MESSAGE_ADC_RESULT:
                        const MessageAdcResult* const result  = (const MessageAdcResult*)message;
                        PRINT(("AIO: ADC msg source %u reading %u\n", result->adc_source, result->reading));
                        reading=0;
                        #if 0
                        uint16 res;
                        if (result->adc_source<adcsel_vref)
                        /* for aio inputs continue to use the VREF reading which comes from the same ADC as the aio inputs */
                                /* for AIOs voltage(mV) = reading(ADC counts) * (mv_per_count = VREF(mV)/VREF(ADC counts)) */
                                res = (uint16)(((uint32)VmReadVrefConstant() * reading) / power->vref);
                        PRINT(("POWER: BC7 res %u\n", res));
                default:
 楼主| 发表于 2017-4-19 16:12:53 | 显示全部楼层
liujinhan 发表于 2017-4-18 16:59
测过的代码:
#include
谢谢提供代码帮助,另外,我想咨询下,读取AIO的时候,它的基准电压只能是通过(uint32)((uint32)VmReadVrefConstant() * (uint32)reading)) / power->vref这种公式计算吗?
VmReadVrefConstant固定为700,
power->vref大致为531,
发表于 2017-4-19 16:59:38 | 显示全部楼层
没有仔细研究过,你看代码吧。
代码怎么用就怎么用。
发表于 2018-2-16 19:41:23 | 显示全部楼层
不错,点个赞。。。。
GMT+8, 2024-8-25 14:30
