发表于 2017-4-12 09:38:52
大湿帮我瞄一眼,这个硬盘是不是快挂了?
smartctl 6.4 2014-10-07 r4002 [i686-linux-3.16.0-4-686-pae] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Caviar Blue (SATA 6Gb/s)
Device Model: WDC WD5000AAKX-001CA0
Serial Number: WD-WMAYU5941731
LU WWN Device Id: 5 0014ee 058418aa3
Firmware Version: 03.03B.2
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s (current: 1.5 Gb/s)
Local Time is: Tue Apr 11 22:35:14 2017 HKT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 42
3 Spin_Up_Time 0x0027 137 134 021 Pre-fail Always - 4116
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 956
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 1
7 Seek_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19000
10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0032 100 100 051 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 409
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 097 000 Old_age Always - 3
188 Command_Timeout 0x0032 100 082 000 Old_age Always - 25770262554
190 Airflow_Temperature_Cel 0x0022 068 051 000 Old_age Always - 32
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 58
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 885
194 Temperature_Celsius 0x0022 111 094 000 Old_age Always - 32
195 Hardware_ECC_Recovered 0x0036 200 200 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 199 199 000 Old_age Always - 1
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 1
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 19
200 Multi_Zone_Error_Rate 0x0009 200 200 051 Pre-fail Offline - 15
