开始神经网络的实验一个月了先前试验了传统卷积神经网络的结构在MNIST数据集上试验达到99.4%的test accuracy。
然后又试验了Network In Network (NIN)结构的卷积网络,在CIFAR-10数据集上有83%的test accuracy。 所有试验都
在tensorflow上用python实现。
使用CIFAR-10 训练的这个网络结构是以下这个样子的
32x32 image----
--->conv(5x5, 192)--->normaliz--->LRelu---->conv(1x1,160)-->normaliz--->LRelu---->conv(1x1,96)--->max_pool(2x2)--
-->conv(5x5, 192)--->normaliz--->LRelu---->conv(1x1,192)-->normaliz--->LRelu---->conv(1x1,192)--->max_pool(2x2)--
->conv(3x3, 192)--->normaliz--->LRelu---->conv(1x1,192)-->normaliz--->LRelu---->conv(1x1,10)--->global_avg_pool--
->softmax
这是一个9层的NIN结构的卷积网络
下图CIFAR-10数据集的train accuracy曲线
代码
import numpy as np
import matplotlib.pyplot as plt
import matplotlib.image as mpimg
import cPickle
import tensorflow as tf
import sys
def concatenate_kernel_map(kernel, kXSize, kYSize, outx, outy, padding):
"kernel: groups of kernel to display [xdim,ydim,1,batch]"
"kXSize: kernel x size"
"kYSize: kernel y size"
"outx: how many kernel patches in output kernel map x direction"
"outy: how many kernel patches in putput kernel map y direction"
"padding: number of padding of zero patches for the last row"
if padding!=0:
ZeroPad = tf.zeros([kXSize,kYSize,1,padding], dtype=tf.float32) #[5,5,1,4]
KernelGroup = tf.concat([kernel, ZeroPad],3) #[5,5,1,36]
else:
KernelGroup = kernel
print (KernelGroup.get_shape())
KernelLine = tf.split(KernelGroup, outy*outx, 3) #[5,5,1,1]
k_map = tf.concat([tf.concat(KernelLine[0*outx:(0+1)*outx],0), tf.concat(KernelLine[1*outx:(1+1)*outx],0)], 1)
for i in range(2,outy):
k_map = tf.concat([k_map,tf.concat(KernelLine[i*outx:(i+1)*outx], 0)], 1)
print (k_map.get_shape())
k_map = tf.reshape(k_map, [1,kXSize*outx,kYSize*outy,1])
return k_map
#input: shape of a weights
#return: initialized weight
def weight_variable(shape, std_value):
initial = tf.truncated_normal(shape, dtype=tf.float32, stddev=std_value)
return tf.Variable(initial)
def bias_variable(shape):
initial = tf.constant(0., shape=shape)
# input x and weight W
#return the conv result
def conv2d(x,W):
return tf.nn.conv2d(x, W, strides=[1,1,1,1], padding = 'SAME')
def max_pool_2x2(x):
return tf.nn.max_pool(x, ksize=[1,2,2,1], strides=[1,2,2,1], padding='SAME')
def lrelu(x, leak=0.2, name="lrelu"):
with tf.variable_scope(name):
f1 = 0.5 * (1 + leak)
f2 = 0.5 * (1 - leak)
return f1 * x + f2 * abs(x)
def mlpconv(x, x_channel, conv_k_size, conv_k_num, mlp1_k_num, mlp2_k_num, has_2x2_pooling, weight_std_value):
'construct mlp convolution layer'
'(conv+relu)-->(MLP+relu)-->(MLE+relu)'
'x : input image'
'x_channel : x input number of channel'
'conv_k_size: kernel x,y dimmension. x and y are same, so this is a scalar'
'conv_k_num : number of kernel'
'mlp1_k_num : mlp1 layer number of 1x1 kernel'
'mlp2_k_num : mlp2 layer number of 1x1 kernel'
'has_2x2_pooling: if do max pooling to the output 1 is yes 0 is no'
#conv layer weights
W_conv1 = weight_variable([conv_k_size, conv_k_size ,x_channel, conv_k_num], weight_std_value)
b_conv1 = bias_variable([conv_k_num])
W_mlp1 = weight_variable([1, 1 ,conv_k_num, mlp1_k_num], weight_std_value)
b_mlp1 = bias_variable([mlp1_k_num])
W_mlp2 = weight_variable([1, 1 ,mlp1_k_num, mlp2_k_num], weight_std_value)
b_mlp2 = bias_variable([mlp2_k_num])
#network cascade
h = conv2d(x, W_conv1) + b_conv1
h = tf.nn.local_response_normalization(h, depth_radius=5, bias=0.01 )
h = lrelu(h)
h = conv2d(h, W_mlp1) + b_mlp1
h = lrelu(h)
h = conv2d(h, W_mlp2) + b_mlp2
h = lrelu(h)
#h = tf.nn.dropout(h, 0.5)
if has_2x2_pooling==1:
h = max_pool_2x2(h)
return h
def global_ave_pool(x, x_shape):
'global average pooling the input x'
'x :input feature map [1,x,y,1]'
'x_shape :should be [1,x,y,1]'
return tf.nn.avg_pool(x, x_shape,[1,2,2,1], 'VALID')
def fc_relu_layer(x, in_length, out_length):
w = weight_variable([in_length, out_length])
b = bias_variable([out_length])
y = tf.nn.relu(tf.matmul(x, w) + b)
return y
def dropout_layer(x, rate):
return tf.nn.dropout(x, rate)
def GetCIFARBatch(dataset, batch_size, pick_range):
randomely get several image and label pairs from the dataset
dataset: dataset with format [image, label]
batch_size: batch size
return: [image, label]
import random
image = dataset[0]
label = dataset[1]
batch_image=[]
batch_label=[]
for i in range(batch_size):
idxf = random.random()
idxf = idxf*pick_range
idxint = int(idxf)
#print(idxint)
batch_image.append(image[idxint])
batch_label.append(label[idxint])
batch_image = np.array(batch_image)
batch_label = np.array(batch_label)
return (batch_image, batch_label)
def LoadCIFARName(file_name):
load CIFAT-10 data set
file_name: the cifar-10 data file path
return: [train_image, train_label]
train_image: image in shape [10000,3,32,32]
train_label: label of each image in shape [10000,10]. with each item
[0,0,0,0,0,0,0,1,0,0]
fo = open(file_name,'rb')
datadict = cPickle.load(fo)
fo.close()
train_image = datadict["data"]
train_array = datadict['labels']
train_image = train_image.reshape(10000, 3, 32, 32).transpose(0,2,3,1).astype("float")
train_array = np.array(train_array)
train_label=[]
for i in range(len(train_array)):
item=[0.,0.,0.,0.,0.,0.,0.,0.,0.,0.]
item[train_array] = 1.
train_label.append(item)
train_label= np.array(train_label)
return [train_image,train_label]
def ShowTenImage(data_set):
labels = data_set[1]
images = data_set[0]
for i in range(40):
plt.figure(1)
plt.imshow(images[i,:,:,:])
print(labels)
plt.show()
plt.show()
def image_normalize(img):
normalize an image with shape [x,y,channel]
mean = np.mean(img)
size = img.shape
img = img-mean
std = np.std(img)
img = img/std
return img
def image_set_normalize(img_set):
normalize an image set with shape [N,x,y,channel]
where N is number of image in the set
channel is color channels
size = img_set.shape
for i in range(size[0]):
img_set[i,:,:,:] = image_normalize(img_set[i,:,:,:])
return img_set
def display_image_blocked(img):
display a image in a new window program will be blocked until the wndows been close
plt.imshow(img, cmap='gray')
plt.show()
#['airplane', 0
# 'automobile', 1
# 'bird', 2
# 'cat', 3
# 'deer', 4
# 'dog', 5
# 'frog', 6
# 'horse', 7
# 'ship', 8
# 'truck'] 9
#[6 9 9 4 1 1 2 7 8 3]
#open data set
#fo = open('cifar10data/data_batch_1','rb')
#datadict = cPickle.load(fo)
#fo.close()
#train_image = datadict["data"]
#train_label = datadict['labels']
#train_image = train_image.reshape(10000, 3, 32, 32).transpose(0,2,3,1).astype("float")
#train_label = np.array(train_label)
#for i in range(10):
# plt.figure(i)
# plt.imshow(train_image[i,:,:,:])
#print(train_label[0:10])
#plt.show()
##image input 32x32
#command line arguments
# sys.argv[1] if initialize all the weights from a file
# when "0" do not initialize all the weights from a file
# when "file" initialize all the weights from file
# sys.argv[2] if write the final weights to a file
# when "0" do not
# when "file" write to file
#check the number of input parameter
if len(sys.argv)!=3:
print "too few arguement"
quit()
train_batch_size = 20
train_set = LoadCIFARName('cifar10data/data_batch_1')
train_set1 = LoadCIFARName('cifar10data/data_batch_2')
train_set2 = LoadCIFARName('cifar10data/data_batch_3')
train_set3 = LoadCIFARName('cifar10data/data_batch_4')
train_set4 = LoadCIFARName('cifar10data/data_batch_5')
#ShowTenImage(train_set4)
train_set[0]= np.concatenate((train_set[0], train_set1[0]), axis=0)
train_set[1]= np.concatenate((train_set[1], train_set1[1]), axis=0)
train_set[0]= np.concatenate((train_set[0], train_set2[0]), axis=0)
train_set[1]= np.concatenate((train_set[1], train_set2[1]), axis=0)
train_set[0]= np.concatenate((train_set[0], train_set3[0]), axis=0)
train_set[1]= np.concatenate((train_set[1], train_set3[1]), axis=0)
train_set[0]= np.concatenate((train_set[0], train_set4[0]), axis=0)
train_set[1]= np.concatenate((train_set[1], train_set4[1]), axis=0)
print(train_set[0].shape)
print(train_set[1].shape)
display_image_blocked(train_set[0][0,:,:,:])
image_set_normalize(train_set[0])
#train_set -= np.mean(train_set, axis=(1,2,3))
#train_set /= np.std (train_set, axis=(1,2,3))
#ShowTenImage(train_set)
#placeholders
#x : input pixel arrays
#y_: output result
x = tf.placeholder(tf.float32, shape=[None,32,32,3])
y_ = tf.placeholder(tf.float32, shape=[None, 10])
x_image = tf.reshape(x, [-1,32,32,3])
#Network structure
network1 = mlpconv(x_image, 3 , 5, 192, 160, 96, 1, 0.01)
network2 = mlpconv(network1, 96, 5, 192, 192, 192, 1, 0.01)
network3 = mlpconv(network2, 192, 3, 192, 192, 10, 0, 0.1)
ave_vec = global_ave_pool(network3, [1,8,8,1])
h = tf.reshape(ave_vec, [-1, 10])
y_conv = h
#h = fc_relu_layer(h, 128, 256)
#h = dropout_layer(h, 0.3)
#h = fc_relu_layer(h, 256, 10)
ave = tf.Print(ave_vec, [ave_vec])
#dropout
keep_prob = tf.placeholder(tf.float32)
#h_fc1_drop = tf.nn.dropout(h_pool2_flat, keep_prob)
#readout layer
#W_fc2 = weight_variable([10, 10])
#b_fc2 = bias_variable([10])
#y_conv = tf.matmul(h_pool2_flat, W_fc2) + b_fc2
#y_conv = tf.nn.softmax(y_conv, -1)
#training and model
cross_entropy = tf.reduce_mean(
tf.nn.softmax_cross_entropy_with_logits(labels=y_, logits=y_conv))
train_step = tf.train.AdamOptimizer(1e-4).minimize(cross_entropy)
#train_step = tf.train.GradientDescentOptimizer(0.0001).minimize(cross_entropy)
correct_prediction = tf.equal(tf.argmax(y_conv,1), tf.argmax(y_,1))
accuracy = tf.reduce_mean(tf.cast(correct_prediction, tf.float32))
saver = tf.train.Saver()
init = tf.initialize_all_variables()
sess = tf.Session()
#initialize from a file or not
if sys.argv[1]=="0":
sess.run(init)
print "Random initialize all weights bias"
else:
saver.restore(sess, sys.argv[1])
print "Restore weights and bias from file:",sys.argv[1]
#tb
#concatenate kernel map for conv layer1
#KernelMap1=concatenate_kernel_map(W_conv1, 5, 5, 6, 6, 4)#KernelMap0=concatenate_kernel_map(W_conv1)
#KernelMap1 = tf.reshape(KernelMap1, [1,30,30,1])
#output_fm = tf.split(output_fm,train_batch_size,0)
#output_fm = tf.concat([output_fm[0:10]],3)
# feature_map = tf.reshape(output_fm, [4,4,1,10])
# global_ave_fm = concatenate_kernel_map(feature_map, 4, 4, 1, 10, 0)
# fm_out = tf.summary.image("before global ave pooling 0", global_ave_fm, max_outputs=1)
#print(global_ave_fm.get_shape())
#global_ave_fm = tf.reshape(global_ave_fm, [1,35,14,1])
#fm_out = tf.summary.image("before global ave pooling", global_ave_fm, max_outputs=1)
#concatenate kernel map for conv layer2
#KernelMap2Group = tf.split(W_conv2, 32, 2)
#KernelMap2Group2 = KernelMap2Group[0]#tf.split(KernelMap2Group[0], 2, 3)
#print ('dimision kernelgroup2', KernelMap2Group2.get_shape())
#KernelMap2=concatenate_kernel_map(KernelMap2Group2, 5, 5, 8, 8, 0)#KernelMap20=concatenate_kernel_map(KernelMap2Group2[0])
#KernelMap2 = tf.reshape(KernelMap2, [1,40,40,1])
#conv1_k = tf.summary.image("conv1 kernels", KernelMap1, max_outputs=1)
#conv2_k = tf.summary.image("conv2 kernels", KernelMap2, max_outputs=1)
accuracy_chart = tf.summary.scalar("accuracy", accuracy)
#weights_conv1 = tf.summary.histogram("global average pooling", ave_vec)
merged_summary_op = tf.summary.merge_all()
summary_writer = tf.summary.FileWriter('/home/yuf/dev/deep_learning/prj/CIFAR/log', sess.graph)
label_name = ['airplane','automobile','bird','cat','deer','dog','frog','horse','ship','truck']
label_name = np.arange(len(label_name))
#training loop
for i in range(300000):
batch = GetCIFARBatch(train_set, train_batch_size, 50000)
if i%50 == 0:
train_accuracy = sess.run(accuracy, feed_dict={x:batch[0], y_: batch[1], keep_prob: 1.0})
summary_str = sess.run(merged_summary_op, feed_dict={x:batch[0], y_: batch[1], keep_prob: 1.0})
summary_writer.add_summary(summary_str, i)
print("step %d, training accuracy %g"%(i, train_accuracy))
print(batch[1][0,:])
ave_vec_num = sess.run(ave_vec, feed_dict={x:batch[0], y_: batch[1], keep_prob: 1.0})
print(ave_vec_num[0,0,0,:])
#plt.bar(label_name, ave_vec_num[0,0,0,:], alpha=0.5)
#plt.ion()
#plt.show()
#plt.pause(0.05)
if i%1000 == 0:
if sys.argv[2]=="0":
sess.run(init)
print "Discard all weights & bias"
else:
saver.save(sess, sys.argv[2])
print "Save weights and bias to file:",sys.argv[2]
sess.run(train_step, feed_dict={x: batch[0], y_: batch[1], keep_prob: 0.5})
test_set = LoadCIFARName('cifar10data/test_batch')
test_set[0] = image_set_normalize(test_set[0])
test_batch = GetCIFARBatch(test_set, 500, 10000)
print("test accuracy %g"%sess.run(accuracy, feed_dict={
x: test_batch[0], y_:test_batch[1], keep_prob: 1.0}))
sess.run(init)
else:
sess.close() |
