Fixed CCRs: SPB 17.2 HF015 03-16-2017
CCRID Product ProductLevel2 Title
1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol
1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model
1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function
1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file
1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting Padstack Editor results in incorrectly scaled forms
1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design
1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated in 30 degrees
1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled.
1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously
1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor
1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not
1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used
1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places
1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value
1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically
1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad
1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout
1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file
1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084
1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position
1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net
1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer
1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation
1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates
1712964 SIP_LAYOUT SYMBOL SiP Layout crashes when using Renumber Pins in Symbol Edit application mode
链接:http://pan.baidu.com/s/1kVmHGZ9 密码:smsv |
