发表于 2017-9-28 10:33:30
我也来分享我刚刚纯模拟的串口程序吧,已经调试成功,一次只能接收发送1字节数据,全双工
- [code]void TIM2_Init(void)
- TIM2->ARRH = 0x02; //自动重装载的值 255
- TIM2->ARRL = 0x2c; //自动重装载的值 255
- TIM2->PSCR = 0x00; //不分频
- TIM2->EGR = 0x01; //手动产生一个更新事件,用于PSC生效 注意,是手动更新
- TIM2->IER = 0x01; //使能溢出中断
- TIM2->CR1 = 0x01; //启动定时器
- //中断处理函数在TIM2_UPD_OVF_BRK_IRQHandler
- INTERRUPT_HANDLER(TIM2_UPD_OVF_BRK_IRQHandler, 13)
- UartSoft_Tim();
- TIM2_ClearITPendingBit(TIM2_IT_UPDATE);
- * @File :UartSoft.c
- * @Author :BLF
- * @Email :zhcj66@163.com
- * @Version :V1.0.0
- * @FileNewDate :2017-09-27
- * @FileChangeDate :2017-09-27
- * @Brief :软件模拟3倍波特率全双工串口
- :定时器中断频率=波特率*3
- :stm8 定时器设定值=定时器频率/(1/(波特率*3))=定时器频率/波特率/3=16000000/9600/3=555.5=556
- :测试间隔1ms收发一个数据,同时收发多个数据会出错
- #include "includes.h"
- #include "UartSoft.h"
- #define RXB_PORT GPIOD //工作状态指示LED
- #define RXB_PIN GPIO_PIN_4
- #define TXB_PORT GPIOD //工作状态指示LED
- #define TXB_PIN GPIO_PIN_2
- #define RXB GPIO_ReadInputPin(RXB_PORT,RXB_PIN) //define UART TX/RX port
- #define TXB(x) x==1?GPIO_WriteHigh(TXB_PORT,TXB_PIN):GPIO_WriteLow(TXB_PORT,TXB_PIN)
- typedef unsigned char BOOL;
- typedef unsigned char BYTE;
- BYTE TBUF,RBUF;
- BYTE TDAT,RDAT;
- BYTE TCNT,RCNT;
- BYTE TBIT,RBIT;
- BOOL TING,RING;
- BOOL TEND,REND;
- BYTE buf[16];
- void UartSoft_Init(void)
- GPIO_Init(RXB_PORT,RXB_PIN,GPIO_MODE_IN_PU_NO_IT);
- GPIO_Init(TXB_PORT,TXB_PIN,GPIO_MODE_OUT_PP_HIGH_FAST);
- TING = 0;
- RING = 0;
- TEND = 1;
- REND = 0;
- TCNT = 0;
- RCNT = 0;
- TIM2_Init();
- //读取串口手机
- //返回0 数据无效;返回1 数据有效
- //*s 当返回为1 *s数据有效
- //注:在车里程序需不停扫描数据,否则会丢数据
- unsigned char UartSoft_Getc(unsigned char *s)
- unsigned char St=0;
- if (REND)
- REND = 0;
- *s = RBUF;
- St = 1;
- else { *s=0xFF; }
- return St;
- //发送数据需间隔一定时间 否则出错
- void UartSoft_Putc(unsigned char s)
- if (TEND)
- TEND = 0;
- TBUF = s;
- TING = 1;
- //定时器中断读取程序
- void UartSoft_Tim(void)
- if (RING)
- if (--RCNT == 0)
- RCNT = 3; //reset send baudrate counter
- if (--RBIT == 0)
- RBUF = RDAT; //save the data to RBUF
- RING = 0; //stop receive
- REND = 1; //set receive completed flag
- UartSoft_Putc(RBUF);
- else
- RDAT >>= 1;
- if (RXB) RDAT |= 0x80; //shift RX data to RX buffer
- else if (!RXB)
- RING = 1; //set start receive flag
- RCNT = 4; //initial receive baudrate counter
- RBIT = 9; //initial receive bit number (8 data bits + 1 stop bit)
- if (--TCNT == 0)
- TCNT = 3; //reset send baudrate counter
- if (TING) //judge whether sending
- if (TBIT == 0)
- TXB(0); //send start bit
- TDAT = TBUF; //load data from TBUF to TDAT
- TBIT = 9; //initial send bit number (8 data bits + 1 stop bit)
- else
- // TDAT >>= 1; //shift data to CY
- if (--TBIT == 0)
- TXB(1);
- TING = 0; //stop send
- TEND = 1; //set send completed flag
- else
- if(TDAT&0x01){ TXB(1); }
- else { TXB(0); }
- TDAT >>= 1;
复制代码 |
