原理图就不贴了,就是两片STM32通过485连接,一主一从。设想是子机设定好地址后主机发送地址帧唤醒串口中断,然后接收后面的地址帧。实测发现无法唤醒。求指点原因。
程序如下:
void USART1_Config(void)
USART_InitTypeDef USART_InitStructure;
/* config USART1 clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
/* USART1 GPIO config */
/* Configure USART1 Tx (PA.09) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure USART1 Rx (PA.10) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USART1 mode config */
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_9b;//多发送一位,TB9
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
USART_ReceiverWakeUpCmd(USART1,ENABLE);//进入静默模式
USART_WakeUpConfig(USART1,USART_WakeUp_AddressMark);//设置唤醒模式为地址唤醒
/* 使能串口1接收中断 */
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_Cmd(USART1, ENABLE);
void USART1_IRQHandler(void)
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)//接收中断
int main(void)
USART1_Config(void)
USART_SetAddress(USART1,0x03);
发送部分:
void MasterToSlave_HandShake(unsigned char iSlaveID)
RS485BUS_Write;//485总线写状态
MasterToSlaveSendBuff[0]=0x5a;
MasterToSlaveSendBuff[1]=0xa5;
MasterToSlaveSendBuff[2]=4;
MasterToSlaveSendBuff[3]=0x10;
MasterToSlaveSendBuff[4]=0x01;
MasterToSlaveSendBuff[5]=iSlaveID;
MasterToSlaveSendBuff[6]=0x01;
MasterToSlaveSendBuff[7]=0x02;
MasterToSlaveSendLength=8;
MasterToSlaveSendCurrentByte=0;
MasterToSlave_SendStatus=MasterToSlave_SendStatus_Sending;
USART_SendData(USART1, (unsigned int)(MasterToSlaveSendBuff[0])|0x0100);//地址帧,TB9=1
USART_ITConfig(USART1, USART_IT_TC, ENABLE);//开发送中断
