发表于 2017-4-30 11:49:34
4.00.0086的已经出来了,求高手搬运
change:
Fix: Several errors fixed that can happen if your Windows user name contains Japanese or Chinese text, or any non-ANSI characters. This could cause error messages about not being able to create the project list, or open a project.
Fix: Lookup References: was not finding results if the string you entered was not a declared symbol name. For example, a word inside a comment. This was different than in version 3.5.
Fix: C++: In function declarations, using the pure virtual syntax "= 0" after certain keywords caused the function to not get recognized.
Fix: C++: Parsing error for Lambda functions with omitted parameter lists. Eg: [ capture-list ] { body }
Fix: Code Snippets: Sometimes when a snippet was inserted, the indentation was incorrect.
Fix: Bugs fixed in the Intelligent Paste function, which is supposed to paste new lines at the correct indent level.
