发表于 2017-2-11 14:17:05
后来发现一个新问题,编程结果校验失败,错误的bit是随机的.
问题的根源是TCK/TMS/TDI/TDO没有和GND使用同一排跳线线,没有平行走线。
使用5根线的排线后编程顺利通过。
下面是一些随机的错误:
Device 1 LCMXO2-7000HC:
Operation: SRAM Erase,Program,Verify
File Date/time: 02/11/17 12:27:43
Connected to Lattice Cable Server.
Board with FTDI USB Host Chip detected.
Check configuration setup: Start.
JTAG Chain Verification. No Errors.
Check configuration setup: Successful.
Device1 LCMXO2-7000HC: SRAM Erase,Program,Verify
Sat Feb 11 13:01:18 2017 Bitstream pre-decompression size: 217528 bits.
Sat Feb 11 13:01:18 2017 Bitstream post-decompression size: 1546544 bits.
Sat Feb 11 13:01:18 2017 Bitstream decompression ratio: 610.96 percent.
--------------Row285--------------:
HDR 0
TDR 0
SDR 1992 TDI(000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000)
Expected TDO(000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000006804000000000002001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000)
Received TDO(FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE804000000000002001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000)
Bits Error 1992: Expected: 0 Received: 1
Bits Error 1991: Expected: 0 Received: 1
Bits Error 1990: Expected: 0 Received: 1
Bits Error 1989: Expected: 0 Received: 1
Bits Error 1988: Expected: 0 Received: 1
Bits Error 1987: Expected: 0 Received: 1
Bits Error 1986: Expected: 0 Received: 1
Bits Error 1985: Expected: 0 Received: 1
Bits Error 1984: Expected: 0 Received: 1
Bits Error 1983: Expected: 0 Received: 1
and more...
"Failed in Function VERIFY /see log file for more details/ "
Execution time: 00 min : 11 sec
Device1 LCMXO2-7000HC:Re-Initialize
Execution time: 00 min : 02 sec
Process Operation Failed.
Elapsed time: 00 min : 13 sec
Operation: unsuccessful.
Sat Feb 11 13:03:05 2017 Bitstream pre-decompression size: 217528 bits.
Sat Feb 11 13:03:05 2017 Bitstream post-decompression size: 1546544 bits.
Sat Feb 11 13:03:05 2017 Bitstream decompression ratio: 610.96 percent.
HDR 0
TDR 0
Received TDO(000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000002804000000000002001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000)
Bits Error 0771: Expected: 1 Received: 0
Execution time: 00 min : 10 sec
Execution time: 00 min : 03 sec
Elapsed time: 00 min : 14 sec
