发表于 2017-2-21 23:08:21
Fix: Files encoded with non-Unicode code pages were not displayed correctly. There are new commands on the File menu to open, reload, and save files using a specific encoding. This affects files that use Japanese Shift-JIS, Chinese Big5, and other code pages. If you open a file and the encoding looks incorrect, please select File > Reload As Encoding and choose the correct encoding. See: File Encodings
New: In Options > Preferences: Files: A new option was added for "default file encoding". Source Insight assumes this character encoding when opening non-Unicode files, or when saving new files the first time.
Fix: The Input Method Editor (IME) was not working to insert characters and symbols.
Fix: In panel windows (such as the Project Symbol List), the list was not auto-completed if you pasted text from the clipboard.
Fix: Alt+G was not activating the Project Symbol List panel.
Fix: Custom Commands: error or crash could happen if you disabled both "Capture Output" and "Paste Output".
Fix: When saving a file to a network drive, you could get an erroneous message that the file has changed outside of Source Insight.
Fix: Temp files were not getting cleaned up and deleted in some cases.
Fix: Crash could happen if you used the Context Window, opened the file displayed in the context window, edited it, then closed the file without saving.
Fix: Python: was not handling the line-continuation back-slash at the end of lines.
Fix: File Compare window: some key commands were not working. |
