回复: 25
著名的菲尼克斯为树莓派设计了一款标准壳体
出5入0汤圆
发表于 2016-12-22 17:01:08 | 显示全部楼层 |阅读模式
Raspberry Pi gets a new home.
From Rachel Boyd | April 25, 2016
Written by Duncan Nicol – Market Segment Manager – Device Connections
The Raspberry Pi single board computer has just celebrated its 4th birthday and in its short life has reinvigorated the world of computing and, more specifically, computer programming for a new generation of school children, hobbyist and application engineers. The latter have come to realise that for around £30 you have a tried and tested core ingredient for an industrial IO system with a world of possibilities, without the need for expensive industrial controllers (just don’t tell the industrial controller bods).
Of course this is great news. However the Raspberry Pi was not originally intended for industrial applications and as such is not packaged for the control cabinet or industrial environment.
Not, that is, until now.
Raspberry Pi enclosure
Phoenix Contact is a world leader in Device Connectors and Electronics Enclosures for industrial applications and has just launched an extension to its well established BC enclosure portfolio with the new RPI-BC which has been specifically designed for Raspberry Pi.  (Watch video)
Unlike most enclosures for Raspberry Pi, the RPI-BC is a DIN rail or wall mountable enclosure that provides access to all the ports including the USB ports, GPIO pins and SD card without removing the lid. The enclosure can also be mounted adjacent to other modules on the DIN rail and still provide access to all ports.
And because the RPI-BC is part of the BC portfolio (watch video) of enclosures, expanding the system to add additional components is simple to achieve thanks to the integration of the DIN rail BUS connector and PTSM plugs and headers. The BUS connector provides high density connectivity to other BC modules mounted on the DIN rail. This turns the Raspberry Pi into the core of a truly integrated industrial solution.
The RPI-BC enclosure incorporates catches for securing to the DIN rail, but the very same catches can be used to mount the enclosure directly onto the wall or other flat surfaces. The optional BUS connector is mounted directly on the DIN rail allowing individual BC modules to be plugged and unplugged from the BUS system without losing connectivity to other modules.
Power can simply and conveniently be provided with the efficient STEP 5V, 2A power supply (part # 2320513). Sharing the same form factor but at just 18mm wide, the STEP power supply can be mounted alongside the RPI-BC enclosure on the DIN rail and connected to the USB-micro connector with a short cable.
Internal space has been provided within the RPI-BC to add
additional circuitry as required. Prototyping PCBs are available to order (part # 2202995 & 2202994) and connect directly to the GPIO pins of the Raspberry Pi and the enclosure’s optional BUS connector, and mount securely within the RPI-BC enclosure. The prototyping PCBs are aimed more towards the industrial than hobby markets as they provide more space for custom circuitry. PTSM headers (watch video) can be soldered directly to the GPIO expansion PCB enabling plug-in IO access from outside the enclosure (PTSM plugs).
DEV-KITSTo aid development of new projects, a development kit (Watch video) is available to order along with the prototyping PCBs and connector sets. The DEV-KIT (part # 2202525) includes the enclosure base and upper housing ready to fit the Raspberry Pi B+, B2 & 3 models with an optional adapted (part # 2202906) for the Raspberry Pi 1 Model A+.
As the Raspberry Pi becomes ubiquitous in industrial applications, the need to professionally enclose and integrate with other system components will naturally follow and the RPI-BC enclosure is the ideal solution. The RPI-BC enclosure is perfectly suited to stand alone applications, thanks to its wall mounting capability, or as part of a larger integrated control cabinet or distribution board solution.
For more information or to request a visit from one of our field sales engineers, please contact Duncan by telephone: 07799 072059 or email: dnicol@phoenixcontact.com
出5入0汤圆
 楼主| 发表于 2016-12-22 17:02:04 | 显示全部楼层
出10入18汤圆
发表于 2016-12-22 17:02:30 | 显示全部楼层
可能壳子比树莓派还贵好几倍
出5入0汤圆
 楼主| 发表于 2016-12-22 17:03:22 | 显示全部楼层
优势
安装无需工具
为矩阵板或其他电路板留足电路空间
GPIO端口可通过PTSM系列连接器连接
总线连接器和DIN导轨轻松实现模块间连接
主要特点
可在DIN导轨上并列安装
总宽度:107.6 mm
尺寸符合DIN 43880
适用于Raspberry Pi A+、B+、B2、B3
壁式或DIN导轨安装
可与HBUS和BC系列壳体配套使用
出5入0汤圆
 楼主| 发表于 2016-12-22 17:04:07 | 显示全部楼层
qtechzdh 发表于 2016-12-22 17:02
可能壳子比树莓派还贵好几倍
价格肯定不是一般的贵,,不过这说明树莓派有工业应用的趋势,,,
出5入0汤圆
 楼主| 发表于 2016-12-22 17:06:38 | 显示全部楼层
官网有个演示视频,尝试贴过来,貌似不行,请高手帮忙
https://www.phoenixcontact.com/o ... 9-af5c-fb2c57805e46
出5入0汤圆
 楼主| 发表于 2016-12-22 17:07:39 | 显示全部楼层
近日 ,服务于全球工程师的分销商 Electrocomponents plc 集团旗下的贸易品牌RS Components (RS) (LSE:ECM) 宣布提供来自Phoenix Contact的一系列外壳,将树莓派单板计算机引入工业领域。新的外壳系统提供了高水平的防护,以及可通过丰富的扩展选项实现更多功能,使树莓派计算机可满足工业环境的严苛要求。
Phoenix Contact 的RPI-BC DIN导轨外壳系统可容纳树莓派型号A+、型号B+、或者树莓派2和树莓派3的型号B。该系列可用于实现多个树莓派计算机和I/O模块的设置,并轻松地连接DIN导轨,即可通过HBUS形成完整的系统。此外,还有丰富的扩展可能性以提供更多功能,提升灵活性和便利性:例如,通过添加可选的洞洞板(Perfboard )或单独的PCB,将其插入树莓派的同一外壳中,并通过排针连接器连接到HBUS。
是次推出的外壳系统安装方便、省时与安全,毋需任何工具即可安装到 TS35 DIN 导轨上,或通过基座闩锁安装到墙上。该外壳还符合DIN43880标准,从而可以集成到分电器外壳中。该外壳还可以让用户将GPIO排针连接到传感器,或以PTSM连接器连接到电源上。即使仍然安装在外壳系统中,也可以对树莓派的microSD进行方便的更换和备份。
这个Phoenix Contact的产品组合目前提供了一系列选项,包括全套的RPI-BC外壳系统,其中包含一个用于DIN导轨安装或壁上安装的外壳下部部件、基座闩锁、外壳上部部件、外壳盖子以及用于安装树莓派电路板的PCB夹板。外壳下部部件和外壳上部部件也可以从RS单独购买。所有部件均为浅灰色聚碳酸酯材料,拥有 IP20 防护等级,适合在–40至+105°C的温度区间工作。
RS还可提供广泛系列的Phoenix Contact RPI-BC附件,其中包括用于连接洞洞板和兼容PCB板的适配器、插座和排针
发表于 2016-12-22 17:15:01 | 显示全部楼层
靠,楼主上链接啊,想买了
发表于 2016-12-22 17:27:21 | 显示全部楼层
价格好像不会便宜
发表于 2016-12-22 17:27:55 | 显示全部楼层
qiqirachel 发表于 2016-12-22 17:15
靠,楼主上链接啊,想买了
https://www.phoenixcontact.com/o ... tType=webcode_links
发表于 2016-12-22 17:51:19 | 显示全部楼层
像plc了,家里用不太适合啊
发表于 2016-12-22 17:55:59 | 显示全部楼层
高大上的节奏
发表于 2016-12-22 18:06:56 | 显示全部楼层
PLC版。不适合家居、娱乐类。
发表于 2016-12-22 18:27:36 | 显示全部楼层
看了下模具难度,考虑到树莓派的销量,可能不会有淘宝款。
出5入0汤圆
 楼主| 发表于 2016-12-23 10:29:01 | 显示全部楼层
大淘宝基本上都会涉及到吧,,
出5入0汤圆
 楼主| 发表于 2016-12-23 10:29:33 | 显示全部楼层
yzz163 发表于 2016-12-22 18:06
PLC版。不适合家居、娱乐类。
主要不是看壳子用途,算是一个风标,,,工业化应用的前景
出5入0汤圆
 楼主| 发表于 2016-12-23 10:29:59 | 显示全部楼层
ljy99731 发表于 2016-12-22 17:27
https://www.phoenixcontact.com/online/portal/cn/pxc/product_list_pages/!ut/p/b1/1ZVJjqNAEEXPUgegSE ...
链接应该是官方的,估计不好买,
发表于 2016-12-23 11:01:33 | 显示全部楼层
这个能在工业上用?得加点防护吧
发表于 2016-12-23 11:08:12 | 显示全部楼层
只要有足够的需求,像白光FX-951焊台的外壳淘宝就有开模出来卖。模具精度可以降低,复杂可以简化嘛。
发表于 2016-12-23 11:12:10 | 显示全部楼层
菲尼克斯大客户的话有人 申请样品了吗 ?
出5入0汤圆
 楼主| 发表于 2016-12-23 11:15:00 | 显示全部楼层
估计没那么快,,,
发表于 2016-12-23 11:29:43 | 显示全部楼层
没关系的 国内的三和壳体马上就会有同款的!价格会更亲民!
发表于 2016-12-23 12:45:05 | 显示全部楼层
这货的端子不是一般的贵,看看高正会不会引进
出5入0汤圆
 楼主| 发表于 2016-12-23 13:12:47 | 显示全部楼层
兄弟很熟悉套路啊,,哈哈哈
出5入0汤圆
 楼主| 发表于 2016-12-23 13:13:24 | 显示全部楼层
如果火起来,,国内立刻会出现大量高性价比的产品
出0入10汤圆
发表于 2018-11-2 19:37:42 | 显示全部楼层
这个外壳怎么样?
GMT+8, 2024-7-7 13:18
