主要特点是:
由树莓派官方推出,官方的数据手册上分为三个版本:
Raspberry Pi Compute Module (CM1)
Raspberry Pi Compute Module 3 (CM3)
Raspberry Pi Compute Module 3 Lite (CM3L)
数据手册对于温度范围的说明:
The operating temperature range of the module is set by the lowest maximum and highest minimum of
any of the components used.
The eMMC and LPDDR2 have the narrowest range, these are rated for -25 to +80 degrees Celsius.
Therefore the nominal range for the CM3 and CM3L is -25C to +80C.
目前淘宝上只能找到CM1(核心板价格200出头),找不到新版本。
根据新闻,CM3年底上市:Raspberry Pi Compute Module 3 to be launched by the end of the year, used in NEC displays.
http://www.cnx-software.com/2016 ... ed-in-nec-displays/ |
