#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/NIOSII_/software/hello_world_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/NIOSII_/HELLO.sof" --output="
HELLO.flash"
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00000000 --cable='U
SB-Blaster [USB-0]' --device=1 --sidp=0x00001860 --id=0 --timestamp=1479827651 -
-instance=0 "HELLO.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00001860: verified
No EPCS layout data - looking for section [EPCS-FF]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="HELLO.flash" --input="hello_worl
d_0.elf" --output="epcs.flash"
# Programming flash with the project
-instance=0 "epcs.flash"
QUARTUS下载程序没问题,不晓得咋解决这个 |
