发表于 2016-11-17 14:58:57
VERSION 17.0.6
Build: 354 Date: 16 November 2016
3607 Fixed a bug causing 3D holes to appear in the board with zero edge thickness (BC:149).
6515 Fixed a bug that would not allow a STEP file to be exported to a folder whose name path includes Cyrillic symbols or an umlaut.
6554 Improved mixed simulation with added ability to duplicate an existing waveform chart.
6569 Fixed a bug where Splitlines were missing from the Board Planning view.
7597 Fixed a bug causing Paste and Solder information to be missing from Gerber exports.
7937 Added Zuken CR-5000 ASCII format PCB, schematic, and library files support for Import Wizard. (BC:1467)
8363 Improved Outjobs to support PDF/A for use as an Output Container.
8691 Fixed a bug that did not auto-delete Unions that contain 0 primitives.
8919 Fixed a bug causing incorrect IPC D 356 netlist generation.
8929 Fixed a bug causing board Cutouts on board edges to be missing from exported STEP files.
8948 Fixed an issue causing STEP 3D flex sections to remain unfolded in the output.
8956 Fixed a bug causing Polygon Thermal Conductors to extend beyond defined polygon outline (BC:3936).
9183 Improved BOMs exported to PDF, which now contain page breaks for increased readability and printing (BC:58).
9241 Improved mixed simulation with the addition of a Simulation Probe Manager to optimize the functionality and flexibility of simulation probes.
9476 Added support to automatically register all exporters and Save As formats as Export Outputs (BC:1324).
9516 Fixed a bug causing Special 008E symbols to be duplicated during read/save cycles in Schematic documents.
9583 Fixed a bug causing redundant hollows in the core to be displayed around through-holes on the bottom side of the board.
9598 Added support for simulation profiles to improve the functionality and flexibility of simulation runs.
9615 Improved Undo-Redo functions.
9624 Fixed a bug causing Drill Pair Properties to not refresh in Via Stitching/Shielding and Via dialogs in Win7 with Windows Classic theme.
9649 Improved PCB STEP with new option to export as a single part or as one model (BC:5582).
9736 Draftsman now supports Ordinate (single reference) dimensions.
9751 Added a new back drilling rule, as well as 2D & 3D representation and support for backdrilling output to main fabrication formats. Back drilling information is also available for display in the Drill Table.
9653 Fixed a bug causing zoom and scroll commands to behave incorrectly in a CAM document after importing Gerber files.
9676 Added a lasso selection tool for use in PCB documents (BC:962).
9966 Fixed a bug causing Altium Designer to crash on startup when username contains Korean characters.
10007 Fixed a bug causing DIP .xls template files from the IPC Footprints Batch Generator to be mis-named.
10127 Improved trace quality with addition of a new gloss command for use on selected tracks.
10235 Improved Polygon cutouts so they now produce corner-rounds for rectangular Pad objects and Internal Plane cutouts produce corner-rounds for rectangular Pad holes (BC:2940).
10296 Fixed a bug causing AD to crash during xDxDesigner import.
10338 Improved Primitives Clearances with the addition of an Add Hole constraint (BC:5744).
10340 Improved the Clearance rule so only frequently used items present in the matrix now.
10341 Improved Un-routed net rule with new option to 'Check for incomplete connections' (BC:1119).
10357 Improved Parallel Segment rule checks to exclude Diff Pairs.
10403 Fixed a bug causing catastrophic failure using Network Address.
10412 Fixed a bug causing Pitch1 parameter in SOT23 IPC Compliant Footprints Batch Generator to be handled incorrectly (BC:6245).
10679 Fixed a bug causing "Include Parameters from PCB" option in BOM Report Options to become unchecked (BC:2086).
10876 Fixed a bug causing Messages about Parallel Port to be displayed when Altium Designer is started.
10877 Fixed a bug in Eagle Importer, where schematic parameters were incorrectly imported.
11007 Draftsman has a new Show Silkscreen option for Assembly View.
11010 Fixed a bug causing Allegro v16.6 import designator to assign 'Designator1' for all components.
11201 Draftsman now has optimized speed in Assembly and other views.
11226 Improved PCB footprints so that all objects within the footprint are connected to the same Net (BC:3488).
11403 Improved Interactive routing to include the display of Net Class info in the Head's Up Display and the ability to swap to opposite route point while multi-routing and diff pair routing.
11407 Fixed a bug where invisible objects in single layer mode were able to be selected.
11425 Improved "Select Next" feature in PCB to be extended to apply when multiple traces are selected.
11440 Fixed a bug where the Interactive Route Auto Complete shortcut (Ctrl+Click) was not working correctly.
11446 Users can now swap to the opposite route point for Multi-Route and Diff Pair Route.
11455 Fixed a bug causing "Abstract Error" when searching for and removing an extension in the "Installed" section.
11554 Fixed a bug that caused a solder mask expansion to not generate in 3D and output files.
11689 Improved the Zoom factor specified in the PCB panel and Preferences so it can now be used for cross-probing from the Messages Panel for all PCB messages.
11722 Fixed an issue with loading the Ibis model after selection of the full file path.
11728 Fixed a bug that caused a 'Net with multiple names' violation to disappear.
11793 Fixed a bug where schematic design elements did not stay within the grid in DxDesigner Imports.
11838 Fixed a bug causing P-Cad pin lengths to import incorrectly.
11877 Improved the PCB editor with the implementation of Right and Left selection.
11878 Improved the Schematic editor with the implementation of Right and Left selection.
11879 Improved ability to use Tab key for expanded selection and Shift+Tab keys for iterating overlapped objects.
11880 Fixed a bug causing overlapped objects to be cancelled during group selection when using Shift+Tab.
11884 Fixed a bug where Horizontal Scroll Bar is not displayed in PCB String Editor (BC:6364)
11902 Fixed a bug where an exception occurred when attempting to import OLE objects.
11913 Fixed a bug causing the Electrical Clearance Rule for Via against Via to not work.
11915 Fixed a layer sequence inconsistency between Layer Stackup and ODB++.
11919 Improved SCH component parameters, so they now synchronize with PCB footprints (BC:477).
11954 Fixed a bug where modifying the parameters of a digital SIMCODE model resulted in simulation errors.
11967 Fixed a bug causing Snippet creation to crash when selection contains an Accordion.
11970 Improved ECO performance by optimizing the speed of Import Changes during the initial import on large designs.
11975 Fixed a bug causing Room Width Rule to work incorrectly during interactive routing when the Board Outline clearance rule is also active.
11996 Fixed a bug that caused the scrollbar for the PCB panel to work incorrectly.
11997 Fixed a bug where the Query Builder was missing entries when accessed from PCB.
11998 Fixed a bug where using the * key in Board Planning Mode behaved incorrectly.
12016 Fixed a bug causing 3D STEP export of Rigid-Flex stackupboards to occur incorrectly.
12051 Added a new Pick and Place generator to select pick and place options before generating output (BC:999; BC:2067).
12054 Fixed a bug, which caused analyzation to take a long time if the design includes From-to and accordion objects.
12059 Fixed - Folder Structure Settings "Use Custom output file name" option for all outputers.
12076 Fixed a bug causing Electrical Clearnance Rule to not check clearances between split planes as well as between cooper polygons on signal layers (BC:554).
12077 Improved Clearance Rules by adding an option to Ignore Pad to Pad clearances within a footprint (BC:1817).
12080 Fixed a bug where moving tracks behaves incorrectly with PCB panel open.
12082 Fixed a bug that caused overlapping text in the File Format window.
12092 Improved Smart copper editing to include options for merging and subtracting polygons, as well as the addition of improved editing (BC:1295).
12096 Improved thermal connection to include simple and advanced modes.
12109 Draftsman now supports 3DConnexion Space Navigator.
12112 Fixed a bug where schematic output changes net label and port names to uppercase.
12117 Draftsman - Added ability to use several FAB views in document template (BC:7140).
12131 Fixed a bug where the rule 'Silk to Silk Clearance' was incorrectly processing multline text.
12142 Fixed a bug causing Free 3D model positions to not store after STEP file changes.
12184 Improved ability to re-size unpinned panels to minimal dot size.
12212 Fixed a bug blocking global update due to Altium Vault network activity option.
12213 Fixed a bug causing Flip component command to not work correctly for test point properties (BC:2971).
12216 Several bugs in the Ibis model linking in the SI tool have been fixed.
12227 Draftsman documents have been improved to support Mouse Wheel Configuration (BC:6652)
12228 Improved mouse wheel configuration settings by merging them all into one Preferences page.
12234 Fixed a bug causing 'Toggle Select Sheet Ports IO Type" to only cycle through Input and Output port types.
12240 Improved Cross Select Mode now allows selection of various types of object and can be configured through the Preferences dialog.
12248 Fixed a bug causing Access Violations after deleting a variant with alternate parts created in a batch.
12249 Improved the Synchronize Ports to Sheet Entries window size to work more smoothly.
12252 Improved routing with a new constraint for checking Hole to Primitives Clearances.
12270 Fixed an issue causing IPC Compliant Footprint Wizard to generate BGA 3D models incorrectly.
12298 Improved ODB++ outputs by replacing spaces with underlines for object names.
12302 Fixed a bug causing a rules difference between 15.1 and newer versions of AD.
12304 Draftsman has added Dual Unit capability for Dimensions and for global Document Options (BC:6686).
12306 Fixed a bug that prevented Mechanical Layers 17-32 from being added to All Plots in ODB++ Setup (BC: 6573).
12310 Improved Polygon Pour to include a new constraint for checking Hole to Primitives Clearances.
12374 Improved software speed while using the PCB panel for object selection.
12390 Fixed a bug where probing waveforms during a transient simulation only displayed the Magnitude rather than Real value.
12419 Fixed a bug where SIM: Voltage source and inductor loops were reported incorrectly.
12500 Fixed a bug causing Access Violation to appear when exporting to PCB from CAMtastic and "Layer Physical Order" option isn't defined.
12542 Fixed a bug causing the use of Shift+V shortcut when selecting routing via for template to work incorrectly.
12569 Fixed a bug where redundant hyperlinks for Strings on PCB caused Access Violations.
12678 Improved support for latest version of .Net.
12741 Improved routing menu by combining all route commands together under Route menu.
12799 Improved Allegro footprints import so that ComponentClearance constraint works properly by building artificial 3D bodies for certain components.
12810 Fixed an issue when using "mm" in Report Rules.
12812 Fixed a bug where STEP model generated with IPC Compliant Footprint Wizard for BGA footprint imported incorrectly when BGA package included a large number of balls.
12846 Fixed a bug causing the xDxDesigner Importer to function incorrectly.
12887 Fixed a bug that caused the "Arrange Rooms" action to stop working (BC:7046).
12937 Fixed a bug where sheet blocks templates are missing parameters in Importer xDxDesigner.
12938 Fixed a bug causing a constant error for Z-axis distance measurement between the board and 3D body face.
12987 Improved query language with new function which allows for the conversion of engineering notation from string to number. For example, StrToNumber('2K5', Ohm) > 2500.
13019 Fixed a bug causing xSignals to break after updating from library.
13043 Fixed a bug where custom icons disappeared from the toolbar.
13082 Fixed a bug causing AD to lag while routing in 'Hug n Push Obstacles' mode.
13159 Improved components so they can be locked/unlocked from the PCB panel.
13341 Draftsman has changed the default font to Arial.
13348 Improved support for Eagle hierarchical schematic format.
13409 Draftsman bug causing incorrect bounding boxes for not-fitted components has been fixed.
13439 Improved FPGA by combining all FPGA and related technologies within one extension.
13440 Improved Templates and Annotation menus which have been grouped together on the Schematic Design and Tools Menus.
13469 Fixed a bug preventing Designator autoposition from updating after moving a selection (BC:3534).
13471 Improved confirmation dialog when deleting mixed group of vias and traces with option to Ignore Locked Primitives.
13503 Fixed a bug where PCB printout sets were not using the correct layer order.
13527 Fixed a bug causing layer order representation for blind vias to behave incorrectly.
13545 Fixed a problem in the Signal Integrity tool with using Ibis models of model type tristate.
13554 Fixed a bug causing EOSError STEP Library messages when opening PCBLIBs.
13634 Improved Parameter Manager to reduce delay time when clearing multiple cells or a column.
13644 Fixed a problem in the Signal Integrity tool causing false loops to be detected when arcs were present in the PCB routing.
13663 Fixed a bug causing Access Violation errors when generating reports for Embedded Board Array.
13664 Fixed a bug causing negation bar to shift in PDF output and Print Preview for Schematic prints.
13671 Improved the performance of multi-part components.
13704 Fixed a bug causing artifacts from right and left selection actions to display on schematic documents.
13725 Fixed a bug where F hotkey was duplicated; U hotkey is now used for Full Circle in the SchLib Editor (BC:7011).
13727 Draftsman - Fixed a bug preventing regions for Components from displaying properly when SilkScreen or AssemblyDrawing are selected as geometry source (BC:7009).
13728 Draftsman now shows Outer Contour only for body projection.
13769 Improved the method to modify/edit/finish polygon borders (BC:1031).
13807 Improved No Connect in Polygon Style settings by adding a field for Air Gap value (BC:1804).
13809 The SIMetrix/SIMPLIS extension was updated to support version 8.0 of the SIMetrix software.
13819 Fixed a bug causing Access Violations when opening the Differences Panel in an unsaved document.
13820 Draftsman: Added Default preferences for Ordinate Dimension.
13857 Draftsman now supports Backdrilling in the Drill Table.
14010 Fixed a bug in the Allegro importer that caused component origins to not match.
14059 Fixed an issue with Update From Libraries dialog: the 'Add models found in Library, but not in sheet' option does not work unless the 'Update which models are the current models' is enabled.
14074 Implemented standard CAD right and left rectangle selection display.
14141 Draftsman - Fixed an issue with the graphics draw order being ignored in a PDF export via the File menu.
14192 Fixed an issue where component pins of a schematic in PADS are in a different order after importing into Altium.
14308 Added a custom table for Draftsman.
14345 Fixed a bug where big files opened via SVN fail on slow-speed networks due to timeout errors.
14381 Fixed a bug that allowed selected pins of a locked component to be moved without a warning using Ctr+Arrow keys.
14383 Improved routing menu by combining all route commands together under Route menu.
14425 Cleaned up the graphic for the Dialog box button.
14428 Added "Show in library panel" action to the Preview grid popup menu, if the library is installed.
14466 Fixed a bug in cross select mode preferences. Zooming option is now correctly saved and restored. |
