这是一个很简单的小脚本,输入一个带有元件参考编号的字符串,选取指定的那一组元件。
操作步骤是在 OrCAD 中选取元件组,复制它们的元件参考编号,在 PADS 中运行这个小脚本,
然后在弹出的对话框中粘贴,点 OK 钮,所有指定的元件将全部处于选中状态,此时可以移动或分组。
这在 PADS 刚导入 OrCAD 的网络表进行元件分组和摆件布局时特别有用。
- ' ChunJiu 2016-09-07
- Sub Main
- Begin Dialog UserDialog 400,175,.CallbackFunc ' %GRID:10,7,1,1
- TextBox 0,28,400,112,.TextBox1,1
- OKButton 260,147,140,21,.OK
- Text 10,7,380,21,"123",.Text1
- End Dialog
- Dim dlg As UserDialog
- Dialog dlg
- End Sub
- Function CallbackFunc%(DlgItem$, Action%, SuppValue%)
- Dim S_Components As String
- Select Case Action%
- Case 3 ' Value changing or button pressed
- S_Components = DlgText(TextBox1)
- If DlgItem$ = "TextBox1" Then
- 'Unselect all objects
- ActiveDocument.SelectObjects(ppcbObjectTypeAll, "", False)
- 'Components
- S_Components = Replace$(S_Components, Chr$(9), " ")
- S_Components = Replace$(S_Components, Chr$(13), " ")
- S_Components = Replace$(S_Components, Chr$(10), " ")
- S_Components = Replace$(S_Components, " ", " ")
- S_Components = Replace$(S_Components, " ", ",")
- S_Components = Replace$(S_Components, ",,,,,,,,,,", ",")
- S_Components = Replace$(S_Components, ",,,,,,,,,", ",")
- S_Components = Replace$(S_Components, ",,,,,,,,", ",")
- S_Components = Replace$(S_Components, ",,,,,,,", ",")
- S_Components = Replace$(S_Components, ",,,,,,", ",")
- S_Components = Replace$(S_Components, ",,,,,", ",")
- S_Components = Replace$(S_Components, ",,,,", ",")
- S_Components = Replace$(S_Components, ",,,", ",")
- S_Components = Replace$(S_Components, ",,", ",")
- MsgBox S_Components$
- 'Select component by given name
- ActiveDocument.SelectObjects(ppcbObjectTypeComponent, S_Components, True)
- End If
- End Select
- End Function
使用步骤举例:
1、在 OrCA D 中点击鼠标右键,选择 “选择过滤器”;
2、在过滤器中选中 “元件”,其余的统统不打勾;
3、在页面左上角摁住鼠标左键,拉到右下角,可以选中该页上所有元件;
4、再次点击右键,选择“编辑属性”;
5、在属性表里面看到“参考”一栏,注意!不是 “元件参考”那一栏;
6、从第一个参考开始往下拉到最后一个元件,然后 “Ctrl+C”来复制;
7、进入 PADS 调用本脚本;
关于如何将脚本加入 PADS 菜单,请参考我之前那个帖子:
http://www.amobbs.com/thread-5635268-1-1.html
8、脚本弹出一个对话框,请在对话框的文本窗内 “Ctrl+V” 粘贴那些元件参考标号;
9、可以看到所有的元件标号被整理成 PADS 识别的格式(用逗号分隔);
10、所有被指定的元件都点亮了,此时你可以对这些元件进行所需的操作。
