发表于 2016-9-1 00:01:34
以下是我自己写的测试软件的TDBGgridEh的spy++信息:
以下是目标软件的TDBGgridEh的spy++信息:
自己写的测试软件可以被获取到,而对于目标软件执行MyfindControl总是失败
以下是hook的dll的源码
- unit UHook;
- interface
- uses Windows, Messages, SysUtils, Controls, Grids, DBGrids, DBGridEh, Classes;
- procedure InstallHook(MainWnd, DestWnd: HWND); stdcall;
- procedure UninstallHook; stdcall;
- function GetHookedCell: PChar; stdcall;
- implementation
- uses UShare;
- var
- ControlAtom: TAtom;
- ControlAtomString: string;
- RM_GetObjectInstance: DWORD; // registered window message
- function MyFindControl_test(Handle: HWnd): TWinControl;
- type
- PObjectInstance = ^TObjectInstance;
- TObjectInstance = packed record
- Code: Byte; { 短跳转 $E8 }
- Offset: Integer; { CalcJmpOffset(Instance, @Block^.Code); }
- Next: PObjectInstance; { MainWndProc 地址 }
- Self: Pointer; { 控件对象地址 }
- end;
- var
- wc: PObjectInstance;
- begin
- Result := nil;
- wc := Pointer(GetWindowLong(Handle, GWL_WNDPROC));
- if wc <> nil then
- begin
- Result := wc.Self;
- end;
- end;
- function MyFindControl(Handle: HWnd): TWinControl;
- var
- OwningProcess: DWORD;
- begin
- Result := nil;
- if (Handle <> 0) and (GetWindowThreadProcessID(Handle, OwningProcess) <> 0) and
- (OwningProcess = GetCurrentProcessId) then
- begin
- if GlobalFindAtom(PChar(ControlAtomString)) = ControlAtom then
- Result := Pointer(GetProp(Handle, MakeIntAtom(ControlAtom)))
- else
- Result := Pointer(SendMessage(Handle, RM_GetObjectInstance, 0, 0));
- end;
- end;
- function MsgWndProc(hwnd: HWND; Msg: UINT; WParam: WPARAM; LParam: LPARAM): LRESULT; stdcall;
- var
- DG: TDBGridEh;
- aName: array [0..255] of Char;
- begin
- case Msg of
- CM_QUERYROW: //获取行数
- begin
- Result := -1;
- if P^.DestWnd <> 0 then
- begin
- GetClassName(P^.DestWnd, aName, 256);
- if string(aName) = 'TDBGridEh' then MessageBeep(MB_OK);
- DG := Pointer(MyFindControl(P^.DestWnd));
- if DG <> nil then Result := DG.RowCount;
- end;
- Exit;
- end;
- CM_QUERYCOL: //获取列数
- begin
- Result := -1;
- begin
- if DG <> nil then Result := DG.Columns.Count;
- end;
- Exit;
- end;
- CM_HOOKCELL: //获取内容
- begin
- if DG <> nil then MessageBeep(MB_OK);
- Exit;
- end;
- end;
- Result := DefWindowProc(hwnd, Msg, WParam, LParam);
- end;
- function GetMsgProc(Code: UINT; WParam: WPARAM; LParam: LPARAM): LRESULT; stdcall;
- begin
- if Code = HC_ACTION then
- begin
- end;
- Result := CallNextHookEx(P^.hkMsg, Code, WParam, LParam);
- end;
- begin
- if P^.hkMsg = 0 then
- P^.hkMsg := SetWindowsHookEx(WH_GETMESSAGE, @GetMsgProc, HInstance, 0);
- P^.HostWnd := MainWnd;
- P^.HostPID := GetCurrentProcessId;
- P^.DestWnd := DestWnd;
- end;
- begin
- if P^.hkMsg <> 0 then
- begin
- UnhookWindowsHookEx(P^.hkMsg);
- P^.hkMsg := 0;
- end;
- end;
- begin
- Result := P^.Text;
- end;
- var
- DoClear: Boolean;
- DestPID: DWORD;
- DestProcess: Boolean = False;
- UtilWindowClass: TWndClass = (
- style: 0;
- lpfnWndProc: @MsgWndProc;
- cbClsExtra: 0;
- cbWndExtra: 0;
- hInstance: 0;
- hIcon: 0;
- hCursor: 0;
- hbrBackground: 0;
- lpszMenuName: nil;
- lpszClassName: 'THookSGMsgWindow');
- initialization
- hMapFile := OpenFileMapping(FILE_MAP_WRITE, False, cMapFileName);
- DoClear := hMapFile = 0;
- if hMapFile = 0 then
- hMapFile := CreateFileMapping($FFFFFFFF, nil, PAGE_READWRITE,
- 0, SizeOf(TShareData), cMapFileName);
- P := MapViewOfFile(hMapFile, FILE_MAP_WRITE, 0, 0, 0);
- if DoClear then FillChar(P^, SizeOf(TShareData), 0);
- ControlAtomString := Format('ControlOfs%.8X%.8X', [GetModuleHandle(nil), GetCurrentThreadID]);
- ControlAtom := GlobalAddAtom(PChar(ControlAtomString));
- RM_GetObjectInstance := RegisterWindowMessage(PChar(ControlAtomString));
- begin
- GetWindowThreadProcessId(P^.DestWnd, DestPID);
- if DestPID = GetCurrentProcessId then
- begin
- DestProcess := True;
- UtilWindowClass.hInstance := HInstance;
- Windows.RegisterClass(UtilWindowClass);
- P^.MsgWnd := CreateWindowEx(
- WS_EX_TOOLWINDOW, // extended window style
- UtilWindowClass.lpszClassName, // pointer to registered class name
- UtilWindowClass.lpszClassName, // pointer to window name
- WS_POPUP, // window style
- 0, // horizontal position of window
- 0, // vertical position of window
- 0, // window width
- 0, // window height
- 0, // handle to parent or owner window
- 0, // handle to menu, or child-window identifier
- HInstance, // handle to application instance
- nil); // pointer to window-creation data
- PostMessage(P^.HostWnd, CM_MSGWNDCREATED, P^.MsgWnd, 1);
- end;
- end;
- finalization
- if DestProcess then
- begin
- DestroyWindow(P^.MsgWnd);
- PostMessage(P^.HostWnd, CM_MSGWNDCREATED, P^.MsgWnd, 0);
- end;
- GlobalDeleteAtom(ControlAtom);
- ControlAtomString := '';
- UnmapViewOfFile(P);
- CloseHandle(hMapFile);
- end.
复制代码 |
