发表于 2016-11-2 07:16:31
呵呵,ADI在工业控制领域,成熟方案很多的(当然,TI的也不少,呵呵)
大家感兴趣,后续我会再传点比较罕见的内部资料的~
这是我当时做的一些笔记,分享给大家
Process and Factory ControllersAnalog Inputs
Low speed inputs (<5kHz)
PLC/DCS Quad Channel Voltage and Current Input with HART Compatibility (CN0364)
PLC/DCS Universal Analog Input Using Either 4 or 6 Pin Terminal Block (CN0325)
Fully Isolated Input Module Based On The AD7793 24-Bit Σ-Δ ADC, The ADuM5401 Digital Isolator, And A High Performance In-Amp (CN0067)
Software configurable, universal analog front end for industrial and sensor data acquisition (CN0209)
Flexible Signal Conditioning for PLC/DCS, AD8226, AD8475, AD7190 (CN0251)
High speed inputs (>5kHz)
Completely Isolated, Robust, 4-Channel, Multiplexed Data Acquisition System for Industrial Level Signals (CN0292)
18-Bit, 1.33 MSPS, 16-Channel Data Acquisition System (CN0269)
Complete 5 V, Single-Supply, 8-Channel Multiplexed Data Acquisition System with PGIA for Industrial Signal Levels (CN0201)
Precision 24-bit, 250 ksps Single-supply Sigma-Delta ADC System For Industrial Signal Levels (CN0310)
A complete high performance, high speed analog front end process control (CN0213)
Precision, Low Power, Single-Supply, Fully Integrated Differential ADC Driver For Industrial-Level Signals (CN0180)
24-Bit, 4-Channel, High Dynamic Range, 156kSPS per Channel (CN0157)
Layout Considerations For An Expandable Multichannel Simultaneous Sampling Data Acquisition System (DAS) Based On The AD7606 16-Bit, 8-Channel DAS (CN0148)
High Impedance, High CMR, ±10 V Analog Front End Signal Conditioner for Industrial Process Control and Automation (CN0225)
Process and Factory ControllersAnalog Outputs
Fully integrated DAC+Driver solutions
Completely Isolated 4-Channel Multiplexed HART Analog Output Circuit (CN0328)
16 Bit Isolated Industrial Voltage and Current Output DAC with Isolated DC-DC Supplies (CN0233)
Fully Isolated, Single Channel Voltage and 4 mA to 20 mA Output with HART (CN0321)
5 V Regulator Supplies High Transient Current for Dynamic Power Controlled DAC (CN0198)
16-Bit Fully Isolated Output Module Using The AD5422 Single Chip Voltage And Current Output DAC And The ADuM1401 Digital Isolator (CN0065)
Complete 4 mA to 20 mA HART solution with additional voltage output capability (CN0278)
Low voltage DAC with Output Driver
Flexible, High Accuracy, Low Drift PLC/DCS Analog Output Module (CN0202)
Flexible PLC and DCS Analog Output Module only using Two Analog Components (CN0203)
Flexible, High Voltage, High Accuracy, Low Drift PLC/DCS Analog Output Module (CN0204)
4 Channel, Flexible, configurable, voltage and current output circuit for i/o card and PLC applications (CN0229)
Low voltage DAC with discreet output solution
4-20 mA Low Power, 14-Bit, Process Control Current Loop Transmitter (CN0179)
Sample-And-Hold Circuit Using The ADG1211 Switch (CN0058)
16-Bit Fully Isolated Voltage Output Module Using The AD5662 DAC, ADuM1401 Digital Isolator, And External Amplifiers (CN0063)
16-Bit Fully Isolated 4 ma To 20 ma Output Module Using The AD5662 DAC, ADuM1401 Digital Isolator, And External Amplifiers (CN0064)
Process and Factory ControllersTemperature
Thermocouple and RTD
Channel-channel Isolated Temperature Input (Thermocouple/RTD) for PLC/DCS Applications (CN0376)
Precision, Low Power, 3 or 4-wire RTD or Thermocouple Measurement (CN0381,CN0383,CN0384)
12-Bit, 300 kSPS, Single-Supply, Fully Isolated RTD Temperature Measurement System with 3-Wire Compensation (CN0337)
Fully Isolated 4-Channel, Temperature Measurement Circuit Optimized for Performance, Robustness, and Low Cost (CN0287)
High Accuracy Multichannel Thermocouple Measurement Solution (CN0172)
Fully Isolated Input Module Based On The AD7793 24-Bit Σ-Δ ADC And The ADuM5401 Digital Isolator (CN0066)
Complete Thermocouple measurement System using the AD7793 24 Bit Sigma Delta ADC (CN0206)
USB-Based Thermocouple Temperature Monitor with Cold Junction Compensation (CN0214)
USB Based Temperature Monitor using the ADuCM360 Precision Analog Microcontroller and External Thermocouple (CN0221)
Field Instruments (Smart Transmitters)
Loop Powered Solutions
Complete Isolated 4-20 mA/HART Temperature and Pressure Industrial Transmitter (CN0382)
Configurable 4-20 mA Loop Powered Transmitter/Receiver using Instrumentation Amplifier (CN0314)
Complete 4-20 mA Loop Powered Field Instrument with HART Interface (CN0267)
14-Bit, 4-20 mA, Loop Powered, Thermocouple Measurement System Using ARM Cortex-M3 (CN0319)
Flexible,4-20 mA, Loop-Powered Pressure Sensor Transmitter with Voltage or Current Drive (CN0289)
12-Bit, 4-20 mA Loop-Powered Thermocouple Measurement System Using ARM Cortex-M3 (CN0300)
4-20 mA, Loop-Powered Temperature Monitor Using the ADuC7060 Precision Analog MCU (CN0145)
Non Loop Powered Solutions
Complete 4-20mA HART Solution (CN0270)
MEMS Wireless Vibration Solution, with remote sensing, FFT analysis and spectral alarms (ADIS16000, ADIS16229)
MEMS-Based Vibration Analyzer with Frequency Response Compensation (CN0303)
Flexible, 4-20 mA Pressure Sensor Transmitter with Voltage or Current Drive (CN0295)
4-20 ma Process Control Loop Using The AD5662 DAC (CN0009)
16-Bit Fully Isolated 4-20 ma Output (CN0064)
Low Cost, High Voltage, Programmable Gain Instrumentation Amplifier (CN0114)
Oversampled SAR ADC With PGA Achieving Greater Than 125 dB Dynamic Range (CN0260)
Digital Interface
Isolated USB to Isolated RS-485/Isolated RS-232 Interface (CN0373)
EMC Compliant RS-485 Transceiver Protection Circuits (CN0313)
Process Control and Industrial Automationwww.analog.com/processcontrol
Reference Circuitswww.analog.com/cftl
Cross Reference Searchwww.analog.com/cpsearch/CrossReferenceSearch.aspx
“Engineer Zone Resources” on analog.comez.analog.com
Design Centerhttp://www.analog.com/ADIsimPE
ADIsimPE Linear and Mixed-Signal Simulatorhttp://www.analog.com/ADIsimPE
ADIsimPowerwww.analog.com/adisimpower
PLC Demo Page on analog.com
http://www.analog.com/en/digital ... /resources/fca.html
Analog Dialogue Article
http://www.analog.com/library/an ... rocess_control.html
Process Control Microsite
http://processcontrol.analog.com/en/segment/pcia.html
