链接:http://pan.baidu.com/s/1pLTb7YF 密码:be67
Version 16.1.11
Build: 255 Date: 20 July 2016
11409 Added support for the SOLIDWORKS 2016 parasolid file format.
12701
Fixed a critical issue in the PCB Editor where arcs were being multiplied during interactive routing, or track
modification (BC:6843).
12625
Fixed an issue in the PCB Editor where the 3D Lock option was not being taken into account properly for
rigid flex designs.
12708
Fixed an issue of duplicated leasing of on-demand licenses, which was otherwise possible when the software
startup time took more than 20 seconds.
12525 Fixed an issue where 3D Body Height Rule checking was not considering the real height of a STEP model.
12628
Fixed an issue where pads of components - with Alternate Parts in a defined Variant - were being incorrectly
displayed in Draft mode on the generated assembly drawing.
12522
Fixed an issue where special strings in footprints were not being correctly displayed as converted, after
generating a footprint comparison report.
11988
Fixed an issue where special symbols - in the User Name or PC Name - were causing a constant exception
during PCB Collaboration (after connecting to an Altium Vault and opening a PCB file).
12513 Fixed an issue with the incorrect rotation of the QFN and PQFN STEP models in the IPC Wizard (BC:6692). |
