发表于 2016-7-10 12:25:25
http://www.monolithicpower.com/D ... /GetDocument?id=246
Stable with Low ESR Output Ceramic Capacitors
Output Capacitor (C5)
The output capacitor is required to maintain the DC output voltage. Low ESR capacitors are preferred to keep the output voltage ripple low.
The characteristics of the output capacitor also affect the stability of the regulation control system. Ceramic, tantalum or low ESR electrolytic capacitors are recommended.
In the case of ceramic capacitors, the impedance at the switching frequency is dominated by the capacitance, and so the output voltage ripple is mostly independent of the ESR. The output voltage ripple is estimated to be:
Where VRIPPLE is the output ripple voltage, fLC is the resonant frequency of the LC filter, fSW is the switching frequency.
In the case of tantalum or low-ESR electrolytic capacitors, the ESR dominates the impedance at the switching frequency, and so the output ripple is calculated as:
Where VRIPPLE is the output voltage ripple and RESR is the equivalent series resistance of the output capacitors. |
