发表于 2016-4-27 11:22:15
这是stepcraft 2/420的技术指标。
Clamping Surface (X,Y): 12.28″ x 19.69″ (312 x 500mm)
Working Space (X,Y,Z): 11.81″ x 16.54″ x 5.51″** (300 x 420 x 140mm**)
Passage Height: 6.89″ (175mm)
Torsional Stiffness (20N) (XYZ): .0027″ – .0047″ (.07 x .12mm)
Repeatability: +- .0015 (.04mm)
Programmable Resolution: .00019″ (.005mm)
Backlash: Approx. .003″ (.08mm), With software adjustable to 0.0mm
Maximum Speed: 118.11 inch/min. (3,000 mm/min.)
Spindle: STEPCRAFT HF500, Dremel 4000 (or similar), Proxxon IBS/E, Dewalt DW611 (coming September 2015), Porter Cable 450 (coming soon)
Linear Guide: STEPCRAFT – Aluminum extrusion (EN AW-6063 T66) with roller guides
Drive: Stepper motors
Tool Holder Diameter: 1.69″ (43mm) (Optional smaller diameters)
Overall Size: 21.65″ x 16.93″ x 20.08″ (550 x 450 x 510mm)
Weight: 33.07 lbs. (15 kg)
Machine Table: HPL (formica laminate) – Optional Aluminum T-Slot
Input Voltage (AC): 100 – 240V
Output Voltage (DC): 30V
Power Consumption: 90W
Interface: USB or Parallel
Software: UCCNC (included), WinPC-NC (optional), Mach3/4 (optional) |
