发表于 2016-4-25 22:23:52
On Windows 7:
(You must be running Ultimate or Pro, a version of Windows 7 which supports Client for NFS)
Install "Client for NFS" feature (Control Panel / Programs and Features / Services for NFS / Client for NFS)
Disable Windows Firewall or other local firewall (open all required ports later)
Use "Regedit" and add anonymous UID and GID to 500,500 (or whatever user ID you want to have access on CentOS)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ClientForNFS\CurrentVersion\Default\AnonymousGid (new DWORD 32)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ClientForNFS\CurrentVersion\Default\AnonymousUid (new DWORD 32)
- Reboot
(or restart NFS Client from CMD line)
nfsadmin client stop
nfsadmin client start
- Make sure you can see the Linux NFS exports from Windows 7
showmount -e 192.168.146.131 (use your NFS Server's IP address)
- If showmount hangs, it's probably a firewall or network routing issue
mount -o anon 192.168.146.131:/devpool V:
If you get Error 53, the you must change the Network Priority order so that Client for NFS network provider is ABOVE the regular Windows Network provider (so NFS gets tried first; otherwise, you'll get prompted when trying to make connections and get Error 53, which will waste a LOT of your time as it did mine):
地址 http://www.sevenforums.com/netwo ... oblem-mounting.html |
