- #include <iom16v.h>
- #include <macros.h>
- const unsigned char seg7_data[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};//0~F and "shut"
- void port_init(void)
- PORTA = 0xFF;
- DDRA = 0xFF;
- PORTB = 0x01; //PB0,是TIMER0的外部时钟输入脚(T0),需要设为输入,并且使能内部上拉
- DDRB = 0x00;
- PORTC = 0x00; //m103 output only
- DDRC = 0x00;
- PORTD = 0x00;
- DDRD = 0x00;
- //TIMER0 initialize - prescale:Falling edge
- // WGM: Normal
- // desired value: 1KHz
- // actual value: Out of range
- void timer0_init(void)
- TCCR0 = 0x00; //stop
- TCNT0 = 0x00; //set count
- OCR0 = 0x0A; //set compare十进制的十,十次按键后匹配,进入这里
- TCCR0 = 0x06; //start timer 时钟由T0 引脚输入,下降沿触发
- #pragma interrupt_handler timer0_comp_isr:20
- void timer0_comp_isr(void)
- //compare occured TCNT0=OCR0
- //按下键OCR0次后,会进入本中断
- TCNT0 = 0x00;
- //call this routine to initialize all peripherals
- void init_devices(void)
- //stop errant interrupts until set up
- CLI(); //disable all interrupts
- port_init();
- timer0_init();
- MCUCR = 0x00;
- GICR = 0x00;
- TIMSK = 0x02; //timer interrupt sources 允许定时器0,比较中断
- SEI(); //re-enable interrupts
- //all peripherals are now initialized
- void main(void)
- init_devices();
- while(1)
- PORTA = seg7_data[TCNT0]; //一直显示TCNT0的值
T0外部脉冲计数,低电平有效,按理说应该计数计到10然后再重新计数,结果一直累加,到10不归零。 |
