发表于 2015-11-13 09:52:38
这段代码是很不错的,至于精度它能满足一般的要求
* \brief Fast Square root algorithm, with rounding
* This does arithmetic rounding of the result. That is, if the real answer
* would have a fractional part of 0.5 or greater, the result is rounded up to
* the next integer.
* - SquareRootRounded(2) --> 1
* - SquareRootRounded(3) --> 2
* - SquareRootRounded(4) --> 2
* - SquareRootRounded(6) --> 2
* - SquareRootRounded(7) --> 3
* - SquareRootRounded(8) --> 3
* - SquareRootRounded(9) --> 3
* \param[in] a_nInput - unsigned integer for which to find the square root
* \return Integer square root of the input value.
uint32_t SquareRootRounded(uint32_t a_nInput)
uint32_t op = a_nInput;
uint32_t res = 0;
uint32_t one = 1uL << 30; // The second-to-top bit is set: use 1u << 14 for uint16_t type; use 1uL<<30 for uint32_t type
// "one" starts at the highest power of four <= than the argument.
while (one > op)
one >>= 2;
while (one != 0)
if (op >= res + one)
op = op - (res + one);
res = res + 2 * one;
res >>= 1;
one >>= 2;
/* Do arithmetic rounding to nearest integer */
if (op > res)
res++;
return res;
