发表于 2015-10-29 10:46:35
LPC43xx dual core notes
The Keil uVision4 IDE was used with a Keil Ulink2 JTAG debugger on the Hitex LPC4350 board. The 10-pin JTAG connector was used on the board. When the IDE scans the JTAG bus via Ulink2, it will detect 2 cores. For each core's project, the JTAG needs to be setup for the core it will use. Each core can be indepdently debugged using it's uVision4 session.
For the M0 project, the JTAG should be configured as is shown in the following 2 images. The M0 debug sessions will always attempt to attach to the running image without altering the system or core context.
