1: Hikey Board 700包邮
业界首款廉价64位ARM开发板,8核Cortex-A53,1G内存,4G FLASH,有HDMI接口,支持Wifi和蓝牙。下面是96Board官网介绍。7月首发的时候第一时间在AVNET订购了一块,因为比较忙,一直没时 间玩,板子仅上电测试一次,算是全新的了。目前全球都断货,另一款同期发布的64位板子Dragonboard 410c目前也没有现货,很难买到。
The HiKey board is the first board to be certified 96Boards Consumer Edition compatible. This board is base around the HiSilicon Kirin 6220 eight-core ARM Cortex-A53 64-bit SoC running at 1.2GHz and delivering over 10,000 Dhrystone VAX MIPS total performance. The SoC also delivers high performance 3D graphics support with its ARM Mali 450-MP4 GPU.1GB 800MHz LPDDR3 DRAM, 4GB eMMC Flash Storage and the standard 96Boards microSD v3.0 socket provide high performance. Flexible storage options and connectivity are available through 802.11a/b/g/n WiFi, Bluetooth 4.0 LE, three high speed USB 2.0 ports (1 OTG), an HDMI 1.3 1080p video output with audio, and Maker, DSI display and CSI camera interfaces. The board is the standard 96Boards credit-card form factor powered by an 8-18V DC 2A power supply.
2: Jetson TK1 900包邮
9.99成新带原装电源和数据线。参数:CPU:TEGRA K1 (四核2.3Ghz Cortex-A15 + 192核CUDA GPU),RAM: 2G,FLASH: 16G eMMC。可作为CUDA和移动游戏开发平台,主板接口丰富,有SATA、PCIe、千兆网口、USB3.0、HDMI......外围接口应有尽有。
论坛还是相当给力的,已经出了 |
