移植的UIP协议,TCP可以运行,但是UDP不能收不能发。代码如下。帮我看看哪边有问题?
main.c
int main(void)
unsigned int i;
uip_ipaddr_t ipaddr; /* local IP address */
struct timer periodic_timer, arp_timer;
// system init
SystemInit(); /* setup core clocks */
// clock init
clock_init();
// two timers for tcp/ip
timer_set(&periodic_timer, CLOCK_SECOND / 2); /* 0.5s */
timer_set(&arp_timer, CLOCK_SECOND * 10); /* 10s */
// ethernet init
tapdev_init();
// Initialize the uIP TCP/IP stack.
uip_init();
uip_ipaddr(ipaddr, 192,168,0,100);
uip_sethostaddr(ipaddr); /* host IP address */
uip_ipaddr(ipaddr, 192,168,0,1);
uip_setdraddr(ipaddr); /* router IP address */
uip_ipaddr(ipaddr, 255,255,255,0);
uip_setnetmask(ipaddr); /* mask */
udp_service_init();
// Initialize the HTTP server, listen to port 80.
//httpd_init();
uip_listen(HTONS(1200)); //¼àÌý1200¶Ë¿Ú,ÓÃÓÚTCP Server
udp_service_init();
/* receive packet and put in uip_buf */
uip_len = tapdev_read(uip_buf);
if(uip_len > 0) /* received
udp_demo.c
#include "uip.h"
#include "uipopt.h"
#include "uip_arch.h"
#include "tcp_demo.h"
#include <string.h>
#include <stdio.h>
//extern void tcp_demo_appcall(void);
//void myudp_appcall(void);
void udp_service_init(void)
uip_ipaddr(ipaddr, 192,168,0,5);
uip_udp_conn = uip_udp_new(&ipaddr, 1000);
if(uip_udp_conn != NULL)
uip_udp_bind(uip_udp_conn, 2000);
* º¯ÊýÃû: void myudp_send(char *str,short n)
* ²Î Êý:
* ·µ »Ø: ÎÞ
* ¹¦ ÄÜ: UDP Êý¾Ý°ü·¢ËÍ
char *nptr;
nptr = (char *)uip_appdata;
memcpy(nptr, str, n);
uip_udp_send(n); //·¢ËÍn¸öÊý¾Ý
* º¯ÊýÃû: void UDP_newdata(void)
* ²Î Êý:
* ·µ »Ø: ÎÞ
char *nptr;
short len;
len = uip_datalen(); //¶ÁÈ¡Êý¾Ý³¤¶È
if(strncmp(nptr,"ledon 1",7)==0)
myudp_send("LED1 ÁÁ\n",8);
/*else if(strncmp(nptr,"ledon 2",7)==0){
myudp_send("LED2 ÁÁ\n",8);
else if(strncmp(nptr,"ledon 3",7)==0){
myudp_send("LED3 ÁÁ\n",8);
else if(strncmp(nptr,"ledoff 1",8)==0){
myudp_send("LED1 Ãð\n",8);
else if(strncmp(nptr,"ledoff 2",8)==0){
myudp_send("LED2 Ãð\n",8);
else if(strncmp(nptr,"ledoff 3",8)==0){
myudp_send("LED3 Ãð\n",8);
else myudp_send("Unkown command!\n",16); */
* º¯ÊýÃû: void myudp_appcall(void) )
* ²Î Êý:
* ·µ »Ø: ÎÞ
* ¹¦ ÄÜ: UDPÖ÷º¯Êý
if(uip_poll())
else if(uip_newdata())
UDP_newdata();
