最近在学习一个德国的BruGi的开源两轴云台的代码,他在姿态解算上参考了MWC的旋转矩阵计算方法。以下是部分代码:
void initIMU() {
// resolutionDevider=131, scale = 0.000133
// 102us
gyroScale = 1.0 / resolutionDevider / 180.0 * 3.14159265359 * DT_FLOAT;
// initialize complementary filter timw constant
setACCtc(config.accTimeConstant);
accMag = ACC_1G*ACC_1G; // magnitude = 1G initially
// initialize coordinate system in EstG
EstG.V.X = 0;
EstG.V.Y = 0;
EstG.V.Z = ACC_1G;
// Rotate Estimated vector(s) with small angle approximation, according to the gyro data
// needs angle in radian units !
inline void rotateV(struct fp_vector *v,float* delta) {
fp_vector v_tmp = *v;
v->Z -= delta[ROLL] * v_tmp.X + delta[PITCH] * v_tmp.Y;
v->X += delta[ROLL] * v_tmp.Z - delta[YAW] * v_tmp.Y;
v->Y += delta[PITCH] * v_tmp.Z + delta[YAW] * v_tmp.X;
void readGyros() {
int16_t axisRot[3];
char idx;
// 414 us
// read gyros
mpu.getRotation(&axisRot[0], &axisRot[1], &axisRot[2]);
axisRot[0] -= config.gyrOffsetX;
axisRot[1] -= config.gyrOffsetY;
axisRot[2] -= config.gyrOffsetZ;
idx = sensorDef.Gyro[0].idx;
gyroADC[ROLL] = axisRot[idx];
gyroADC[ROLL] *= sensorDef.Gyro[0].dir;
idx = sensorDef.Gyro[1].idx;
gyroADC[PITCH] = axisRot[idx];
gyroADC[PITCH] *= sensorDef.Gyro[1].dir;
idx = sensorDef.Gyro[2].idx;
gyroADC[YAW] = axisRot[idx];
gyroADC[YAW] *= sensorDef.Gyro[2].dir;
// get acceleration for 3-axis
void readACCs()
int16_t rawVal[3];
int16_t devVal[3];
mpu.getAcceleration(
&rawVal[0],
&rawVal[1],
&rawVal[2]
devVal[sensorDef.Acc[ROLL].idx] = rawVal[0] - config.accOffsetX;
devVal[sensorDef.Acc[PITCH].idx] = rawVal[1] - config.accOffsetY;
devVal[sensorDef.Acc[YAW].idx] = rawVal[2] - config.accOffsetZ;
for (int8_t axis = 0; axis < 3; axis++) {
accADC[axis] = devVal[axis]*sensorDef.Acc[axis].dir;
void updateGyroAttitude(){
uint8_t axis;
float deltaGyroAngle[3];
// 43 us
for (axis = 0; axis < 3; axis++) {
deltaGyroAngle[axis] = gyroADC[axis] * gyroScale;
// 111 us
rotateV(&EstG.V,deltaGyroAngle);
void updateACC(){
uint8_t axis;
float accMagSum = 0;
accLPF[axis] = accADC[axis];
accMagSum += accLPF[axis]*accLPF[axis];
// 24 us
accMagSum = accMagSum*100.0/(ACC_1G*ACC_1G);
utilLP_float(&accMag, accMagSum, (1.0f/ACC_LPF_FACTOR));
void updateACCAttitude(){
uint8_t axis;
// 80 us
// Apply complimentary filter (Gyro drift correction)
// If accel magnitude >1.4G or <0.6G and ACC vector outside of the limit range => we neutralize the effect of accelerometers in the angle estimation.
// To do that, we just skip filter, as EstV already rotated by Gyro
if (( 36 < accMag && accMag < 196 ) || disableAccGtest) {
//utilLP_float(&EstG.A[axis], accLPF[axis], AccComplFilterConst);
EstG.A[axis] = EstG.A[axis] * (1.0 - AccComplFilterConst) + accLPF[axis] * AccComplFilterConst; // note: this is different from MultiWii (wrong brackets postion in MultiWii ??.
void getAttiduteAngles() {
// attitude of the estimated vector
// 200us
angle[ROLL] = angleOffsetRoll + Rajan_FastArcTan2_deg1000(EstG.V.X , sqrt(EstG.V.Z*EstG.V.Z+EstG.V.Y*EstG.V.Y));
// 142 us
angle[PITCH] = angleOffsetPitch + Rajan_FastArcTan2_deg1000(EstG.V.Y , EstG.V.Z);
计算的原理可以理解,用陀螺仪积分和旋转矩阵求重力加速度分量,然后和加速度计测的加速度做互补滤波。但问题来了,按照代码中对EstG.V的赋值为(0,0,1g),如果用这个旋转矩阵算的话,不管IMU怎么翻转,算出来的Z轴的值都会是1g的值。因为 v->Z -= delta[ROLL] * v_tmp.X + delta[PITCH] * v_tmp.Y;而X和Y都是初始为0。
所以现在就很迷茫,是我对代码的理解有误,还是代码中对EstG.V的值赋错了,如果是值错了,那EstG.V应该是什么呢。
同时附上MWC的部分代码,里面也用上了EstG,但MWC里反而没有对EstG赋值,所以弄的我更糊涂了。
typedef struct fp_vector {
float X,Y,Z;
} t_fp_vector_def;
typedef union {
float A[3];
t_fp_vector_def V;
} t_fp_vector;
static t_fp_vector EstG;
void getEstimatedAttitude(){
uint8_t axis;
int32_t accMag = 0;
float scale, deltaGyroAngle[3];
uint8_t validAcc;
static uint16_t previousT;
uint16_t currentT = micros();
scale = (currentT - previousT) * GYRO_SCALE;
previousT = currentT;
// Initialization
deltaGyroAngle[axis] = imu.gyroADC[axis] * scale;
accLPF32[axis] -= accLPF32[axis]>>ACC_LPF_FACTOR;
accLPF32[axis] += imu.accADC[axis];
imu.accSmooth[axis] = accLPF32[axis]>>ACC_LPF_FACTOR;
accMag += (int32_t)imu.accSmooth[axis]*imu.accSmooth[axis] ;
rotateV(&EstG.V,deltaGyroAngle); |
