在使用STM8L与EEPROM芯片AT24C512通信的时候,出现了一点问题
因为STM8和STM32的库函数相似,所以参考了野火教程里EEPROM的代码,修改移植到STM8L上
读函数
void EEPROM_ReadBuffer(uint8_t* pBuffer, uint16_t ReadAddr, uint16_t NumByteToRead)
/*!< While the bus is busy */
while (I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
/*!< Send START condition */
I2C_GenerateSTART(I2C1, ENABLE);
/*!< Test on EV5 and clear it */
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
/*!< Send EEPROM address for write */
I2C_Send7bitAddress(I2C1, 0xa0, I2C_Direction_Transmitter);
/*!< Test on EV6 and clear it */
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_Cmd(I2C1, ENABLE);
I2C_SendData(I2C1, ReadAddr);
/*!< Test on EV8 and clear it */
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
/*!< Send STRAT condition a second time */
/*!< Send EEPROM address for read */
I2C_Send7bitAddress(I2C1, 0xa0, I2C_Direction_Receiver);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
/* While there is data to be read */
while (NumByteToRead)
if (NumByteToRead == 1)
/* Disable Acknowledgement */
I2C_AcknowledgeConfig(I2C1, DISABLE);
/* Send STOP Condition */
I2C_GenerateSTOP(I2C1, ENABLE);
/* Test on EV7 and clear it */
if (I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
/* Read a byte from the EEPROM */
*pBuffer = I2C_ReceiveData(I2C1);
/* Point to the next location where the byte read will be
68 saved */
pBuffer++;
/* Decrement the read bytes counter */
NumByteToRead--;
I2C_AcknowledgeConfig(I2C1, ENABLE);
写函数
void EEPROM_WriteBuffer(uint8_t* pBuffer, uint16_t WriteAddr, uint16_t NumByteToWrite)
uint8_t NumOfPage = 0, NumOfSingle = 0, count = 0;
uint16_t Addr = 0;
Addr = WriteAddr % I2C_PageSize;
count = (uint8_t)(I2C_PageSize - (uint16_t)Addr);
NumOfPage = (uint8_t)(NumByteToWrite / I2C_PageSize);
NumOfSingle = (uint8_t)(NumByteToWrite % I2C_PageSize);
if (Addr == 0)
if (NumOfPage == 0)
EEPROM_WritePage(pBuffer, WriteAddr, (uint8_t*)NumOfSingle);
EEPROM_WaitEepromStandbyState();
while (NumOfPage--)
EEPROM_WritePage(pBuffer, WriteAddr, (uint8_t*)I2C_PageSize);
WriteAddr += I2C_PageSize;
pBuffer += I2C_PageSize;
if (NumOfSingle != 0)
if (NumOfPage == 0)
NumByteToWrite -= count;
if (count != 0)
EEPROM_WritePage(pBuffer, WriteAddr, (uint8_t*)count);
WriteAddr += count;
pBuffer += count;
while (NumOfPage--)
写页函数
void EEPROM_WritePage(uint8_t* pBuffer, uint16_t WriteAddr, uint8_t* NumByteToWrite)
I2C_Send7bitAddress(I2C1, 0xA0, I2C_Direction_Transmitter);
I2C_SendData(I2C1, WriteAddr);
while (! I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
while (NumByteToWrite--)
/* Send the current byte */
I2C_SendData(I2C1, *pBuffer);
/* Point to the next byte to be written */
pBuffer++;
/* Test on EV8 and clear it */
/*!< Send STOP condition */
测试函数
void EEPROM_Test()
uint16_t i = 0;
for(i = 0; i < 5; i++)
printf("The Write Data is %d\n", test_Write);
EEPROM_WriteBuffer(test_Write, EEPROM_Firstpage, 5);
printf("Write success!\r\n");
delay_ms(50);
printf("Read Data\r\n");
delay_ms(10);
EEPROM_ReadBuffer(test_Read, 0x01, 5);
delay_ms(10);
printf("The Read Data is %d\n", test_Read);
但是出现写完成后,读数始终为ff的结果
现在有点迷糊,我该如何判断是写函数出问题还是读函数出问题,或者是都有问题呢?
请各位大大指教
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
